saurabhdua Posted August 17, 2016 Share Posted August 17, 2016 Hello Folks! This "Uninstaller" interface is associated to 'Clover', the Program which claims to add Tab-functionality to the Windows explorer interface! Iam done with it, & wish to Uninstall the same. However, the Foreign-Language interface is proving to be an impediment in this task! Can someone please help decipher the various Options listed out there against the enclosed reference, & guide further in this regard? I would always prefer a 'Total Uninstall' & would not like to retain any of the User-configuration, User-settings..etc. etc. Please suggest.... Thank you. Link to comment Share on other sites More sharing options...
login123 Posted August 18, 2016 Share Posted August 18, 2016 The author has a blog where you might try posting your screenshot. Its on the company website. Its multilingual. Not going to post the link here, looks iffy, but others who know more might post it. Also, if you can copy and paste the text from inside that popup, google translate might tell you what it means. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 18, 2016 Moderators Share Posted August 18, 2016 If all else fails version 3.1.2 has multi language support (15th August) Perhaps install it over the top and you may get the English version and then can uninstall. Make restore point/image first. http://www.techspot.com/downloads/5856-clover.html Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
saurabhdua Posted August 18, 2016 Author Share Posted August 18, 2016 Hello Hazelnut! Iam using the Latest version already!....as is evident against the attached reference. To login 123: I did post the query on the same a few days ago & there hasn't arrived a revert yet!? The text on the Uninstaller window cannot be copied & would probably require a suitable OCR App to uncover the same.. Therefore, please help Pool-in Volunteers support for the cause.. :-) Thanks. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 18, 2016 Moderators Share Posted August 18, 2016 So the top selection google translates to "Key fix 'to upgrade to the latest version upgrade to the latest version Fun new features." So maybe it's repair or keep settings The second choice says "● straight seam Thank you for using the 'we will strive to improve" maybe uninstall? I couldn't get translate apps to figure out the buttons and as 1 is c and the other n, they both could be the ok (with one being No or the other being cancel) edit: but based on the second shot I'd say the one on the left is ok ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
saurabhdua Posted August 20, 2016 Author Share Posted August 20, 2016 Thanks to all Dear members! I have been able to retrieve the reply from the Author's Blog, & here it goes for the common Good! Mission accomplished. :-) Link to comment Share on other sites More sharing options...
login123 Posted August 21, 2016 Share Posted August 21, 2016 Thanks for posting back how you fixed it. I really like your translations. Never knew the Chinese characters for "bla bla bla". :lol: The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to comment Share on other sites More sharing options...
saurabhdua Posted August 21, 2016 Author Share Posted August 21, 2016 Thanks for posting back how you fixed it. I really like your translations. Never knew the Chinese characters for "bla bla bla". :lol: Hello login123, The final screenshot is a handiwork of the Author/ or probably some other active member of that Community. This is how he narrated things to me. :-) Thanks. Link to comment Share on other sites More sharing options...
