Miniwinkel Posted July 10, 2016 Share Posted July 10, 2016 Hello, I'd like to suggest adding cleaning options for the following application: JDownloader 2 (Website: http://jdownloader.org/ ), a piece of software used to download (lots of) files (at once). It keeps all kinds of logs about stuff you've downloaded, and compressed files it has auto-extracted. According to their forums the logs are automatically cleaned upon closing the software. This feature does not seem to be present (or work) in JDownloader 2.0. The software logs are saved in: C:\Users\[uSER]\AppData\Local\JDownloader 2.0\logs And there is also a temporary files folder in: C:\Users\[uSER]\AppData\Local\JDownloader 2.0\tmp Thank you in advance. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 11, 2016 Moderators Share Posted July 11, 2016 It's already cleaned via the community winapp2.ini file, which must be downloaded separately: https://forum.piriform.com/index.php?showtopic=32310&page=1&do=findComment&comment=175835 Link to comment Share on other sites More sharing options...
Miniwinkel Posted July 31, 2016 Author Share Posted July 31, 2016 Hi, Thanks, that seems to have done the trick (after some modifying, since JDownloader is not installed in the default location). What is the reason for not including some of these bigger and important software in CCleaner by default? µTorrent is included, but Steam isn't for example. Link to comment Share on other sites More sharing options...
