Moderators hazelnut Posted May 14, 2016 Moderators Share Posted May 14, 2016 Important: All users who have cyberfox 46.0.2 installed DON'T UNINSTALL the browser, We are very sorry but there is a CRITICAL issue with change set for "Generate RegisteredApplications registry key" during the uninstall process it may remove "RegisteredApplications registry key" causing an empty default programs list. https://8pecxstudios.com/Forums/viewtopic.php?f=6&t=1476#p9732 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
login123 Posted May 14, 2016 Share Posted May 14, 2016 Thanks for the warning, Hazelnut. For a long time I have used a sort of a workaround that should prevent this sort of thing. I use a portable browser, running in Sandboxie, running on a virtualized operating system. I use Powershadow for win xp, also available are Returnil, Shadow Defender, maybe others. No changes are made to the "real" system. If a problem occurs in the sandbox, just shut the browser off and delete it. If a problem occurs with the OS. just restart and its gone. Ok, maybe everybody on earth knew about this, but maybe there is one newbie out there that didn't . . . The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to comment Share on other sites More sharing options...
