emeth Posted August 26, 2015 Share Posted August 26, 2015 Click Startup Menu on Windows->Click Settings, There is a thing pop up. On the left, at the very last line(bottom) you will see "Background Apps" click on "Background Apps" you will see a list of apps running on the background. There is Edges in there. On the right side of that app, there is an on/off button, just turn it off.(I turn off all the list->will save your battery) ME is not running in the background and CC still skips ME? Link to comment Share on other sites More sharing options...
titi2907 Posted August 26, 2015 Share Posted August 26, 2015 ME is not running in the background and CC still skips ME? Reboost after disabling ME running on background? It works for me since I did these. That's all I know. It's all working on my two laptops and my sister's laptop too. Thanks Link to comment Share on other sites More sharing options...
Guest MrJ Posted August 27, 2015 Share Posted August 27, 2015 Hi all, Just to let you know that we are aware that CCleaner is still skipping Edge in certain cases and are working on improving this functionality further. MrV's quote still applies - and it can still happen even when Edge is not running at all. HI, there are instances where CCleaner is skipping cleaning for Edge. This occurs when CCleaner has been unable to obtain access to the databases used by Edge. The team is aware of this issue and is working to identify and implement a solution. Link to comment Share on other sites More sharing options...
emeth Posted August 27, 2015 Share Posted August 27, 2015 Hi all, Just to let you know that we are aware that CCleaner is still skipping Edge in certain cases and are working on improving this functionality further. MrV's quote still applies - and it can still happen even when Edge is not running at all. Thank you, your assurance is very much appreciated. I would be interested in understanding what you are really up against with win 10? Link to comment Share on other sites More sharing options...
neiljs Posted August 27, 2015 Share Posted August 27, 2015 It also affects Chrome. It raises the question of what else CC is not cleaning Link to comment Share on other sites More sharing options...
emeth Posted August 28, 2015 Share Posted August 28, 2015 I noticed, after this AM's Win 10 update that CC was acting differently: 1. The 'Run Cleaner' button, (lower right), was grayed out for almost 15+ seconds, (has been doing that but for a much shorter time). 2. That it took an extended amount of time to clean, (very slow comparatively). Link to comment Share on other sites More sharing options...
Jazzycat Posted August 31, 2015 Share Posted August 31, 2015 Downloaded the latest update and as of August 31 having the same issue of CC cleaner skipping edge files on Windows 10 home Link to comment Share on other sites More sharing options...
cdflyer Posted September 26, 2015 Share Posted September 26, 2015 I find nothing at all about 'Edge running in background.' Link to comment Share on other sites More sharing options...
joopbraak Posted November 30, 2015 Share Posted November 30, 2015 Kill dllhost.exe process and keep the task manager open while you're running ccleaner to see if the process doesn't start up again, because this process has the habit of starting and stopping itself frequently. Link to comment Share on other sites More sharing options...
