LostMyfiles Posted July 7, 2015 Share Posted July 7, 2015 It seems like Advanced mode is much better. Can you ask as soon as Recuva starts "Would you like to use Advanced mode?" Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 7, 2015 Moderators Share Posted July 7, 2015 It's already in options (uncheck start in wixard mode if I recall correctly) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
