LuLu 0 Posted April 16, 2015 Share Posted April 16, 2015 So I'm not sure if this is a software problem or a hardware problem. I used my laptop two days ago and everything was fine. Tonight I turn it on and there's a blue-green color that's taken over most areas that should be white. I tried shutting it down, letting it sit for a few minutes and turning it back on but it didn't seem to fix the problem. I'm not really sure what to do at this point. Any ideas from anyone out there? It's really giving me a major headache having to look at this. I'm here. What are your other two wishes? Link to post Share on other sites
Moderators hazelnut 6 Posted April 16, 2015 Moderators Share Posted April 16, 2015 If possible hook up an external monitor to the laptop and see if you get the same. Does the same thing happen in safe mode? Have any updates gone in for graphics? Do the hinges seem ok? Lid a bit loose? Do you open your laptop lid by the corner each time you open it? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
LuLu 0 Posted April 16, 2015 Author Share Posted April 16, 2015 The monitor I have isn't USB so I can't try that, unfortunately. Haven't tried safe mode but will do so shortly. No graphics updates. Hinges are great. As tight as the day I took this sucker out of the box. And it's always opened from the center of the screen. I couldn't open it from the corner even if I wanted to because it just won't budge that way lol I'm here. What are your other two wishes? Link to post Share on other sites
Moderators Andavari 1 Posted April 16, 2015 Moderators Share Posted April 16, 2015 Did this start after Microsoft Updates Tuesday on April 14th? Link to post Share on other sites
Corona 0 Posted April 16, 2015 Share Posted April 16, 2015 What did you know and when did you know it? I've never had a laptop so I'm no good at figgering out this sort of thing. Link to post Share on other sites
Moderators mta 0 Posted April 16, 2015 Moderators Share Posted April 16, 2015 LuLu, You don't need USB for an external monitor, as long as the laptop has some sort of 'video out' port, either DVI(digital), HDMI or VGA or D-SUB(analogue) and as long as you have an external screen with the matching port type then you can plug in an external monitor and see if it also looks the same way. If it does, it's your laptop with the issue, if it doesn't then it's your screen with the issue. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to post Share on other sites
LuLu 0 Posted April 17, 2015 Author Share Posted April 17, 2015 Did this start after Microsoft Updates Tuesday on April 14th? I don't have it set to auto-update so I don't think that would be the issue. But maybe something downloaded anyway? LuLu, You don't need USB for an external monitor, as long as the laptop has some sort of 'video out' port, either DVI(digital), HDMI or VGA or D-SUB(analogue) and as long as you have an external screen with the matching port type then you can plug in an external monitor and see if it also looks the same way. If it does, it's your laptop with the issue, if it doesn't then it's your screen with the issue. Well what I meant was I don't have an external laptop compatible with the connections on my laptop. The monitor I have is about 10 years old, maybe older soo....lol Finally got to check this issue in Safe Mode and the colors are messed up. Does anyone think that maybe this is because I haven't upgraded to 8.1 yet? What about just checking for a graphics update? Or does this just wreak of a hardware issue? I'm here. What are your other two wishes? Link to post Share on other sites
Moderators Nergal 0 Posted April 17, 2015 Moderators Share Posted April 17, 2015 Sounds like hazelnut is on the right path. I'd look up the "tear-down" instructions for your laptop (I know dell, hp and toshiba provide them on their websites, I assume the same is true for most laptop makers). In it look at how to disconnect the monitor (often it's a simple matter of removing a single piece of plastic) and check to see if the connecting wire (from monitor to laptop's body) isn't loose. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Moderators mta 0 Posted April 17, 2015 Moderators Share Posted April 17, 2015 grabbing an external monitor from somewhere (friend, neighbour) would be worthwhile as it would quickly pinpoint the problem. and just in the ever-so-slight chance, is the screen next to anything that could cause interference; speakers, microwaves (yeah I know), desk lamp etc? Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to post Share on other sites
Moderators Nergal 0 Posted April 17, 2015 Moderators Share Posted April 17, 2015 Speakers will only have an effect on magnetic screens (tube monitors/tv's) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
LuLu 0 Posted April 17, 2015 Author Share Posted April 17, 2015 Sounds like hazelnut is on the right path. I'd look up the "tear-down" instructions for your laptop (I know dell, hp and toshiba provide them on their websites, I assume the same is true for most laptop makers). In it look at how to disconnect the monitor (often it's a simple matter of removing a single piece of plastic) and check to see if the connecting wire (from monitor to laptop's body) isn't loose. That's exactly what I was hoping to avoid. lol My brother thinks he got the extended warranty on it when he bought it for me so if he can find the paperwork for that, I may just go that route. But if he didn't, then I'll definitely give that a shot. grabbing an external monitor from somewhere (friend, neighbour) would be worthwhile as it would quickly pinpoint the problem. and just in the ever-so-slight chance, is the screen next to anything that could cause interference; speakers, microwaves (yeah I know), desk lamp etc? Yeah no one has a monitor that I can use. We all have the very old ones because everyone basically jumped ship to a laptop. As far as interference, nope. I store it under my bed so it's out of harm's way and when I use it, it's while sitting on my bed or on the couch and it sits on a wooden TV tray thing. I'm here. What are your other two wishes? Link to post Share on other sites
Corona 0 Posted April 17, 2015 Share Posted April 17, 2015 (looks at LuLus' laptop) Oh here's the problem. You've got this thing set to "evil". (flips switch to "good") Link to post Share on other sites
Moderators hazelnut 6 Posted April 17, 2015 Moderators Share Posted April 17, 2015 Lulu what about your TV, can you connect the laptop to that? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
login123 0 Posted April 18, 2015 Share Posted April 18, 2015 Cheap, quick, & easy thing to try (might not work, but worth 5 minutes ). Turn it off, take out the battery, press and hold the power button for 30 seconds. Then open & close the lid a few times. Then put it all back, turn it on, & check. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
trium 0 Posted April 18, 2015 Share Posted April 18, 2015 The monitor I have isn't USB so I can't try that, unfortunately. no monitor have usb you need vga, hdmi or so Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted April 18, 2015 Share Posted April 18, 2015 Lulu what about your TV, can you connect the laptop to that? nice :-) Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
LuLu 0 Posted April 19, 2015 Author Share Posted April 19, 2015 (looks at LuLus' laptop) Oh here's the problem. You've got this thing set to "evil". (flips switch to "good") Ha if only! I'm here. What are your other two wishes? Link to post Share on other sites
LuLu 0 Posted April 19, 2015 Author Share Posted April 19, 2015 Lulu what about your TV, can you connect the laptop to that? Ummm not sure. Probably not since I'm sure it requires a cable I don't have lol But I'll check. Cheap, quick, & easy thing to try (might not work, but worth 5 minutes ). Turn it off, take out the battery, press and hold the power button for 30 seconds. Then open & close the lid a few times. Then put it all back, turn it on, & check. I'm gonna give that a go! I'm here. What are your other two wishes? Link to post Share on other sites
LuLu 0 Posted April 19, 2015 Author Share Posted April 19, 2015 no monitor have usb you need vga, hdmi or so Actually there are. A friend in Maryland has one. It's similar to this. http://www.bestbuy.com/site/aoc-15-6-widescreen-flat-panel-usb-powered-portable-led-monitor-piano-black/3698548.p?id=1218428680308&skuId=3698548 I'm here. What are your other two wishes? Link to post Share on other sites
LuLu 0 Posted April 19, 2015 Author Share Posted April 19, 2015 Cheap, quick, & easy thing to try (might not work, but worth 5 minutes ). Turn it off, take out the battery, press and hold the power button for 30 seconds. Then open & close the lid a few times. Then put it all back, turn it on, & check. Gave it the ol' college try and it didn't work. But thanks! I'm here. What are your other two wishes? Link to post Share on other sites
trium 0 Posted April 19, 2015 Share Posted April 19, 2015 Actually there are. A friend in Maryland has one. It's similar to this. http://www.bestbuy.c...&skuId=3698548 :-) this is only for power, not for picture-signal you need vga-cord, hdmi-cord or so Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted April 19, 2015 Share Posted April 19, 2015 for tv you need hdmi-cord too... Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted April 19, 2015 Share Posted April 19, 2015 may i ask you how long you use your laptop? Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
LuLu 0 Posted April 19, 2015 Author Share Posted April 19, 2015 Lulu what about your TV, can you connect the laptop to that? I found an HDMI and tried it. The picture on the TV was great. So I guess it's the screen or it's connection. Just once more reason why I hate laptops LOL may i ask you how long you use your laptop? I've had it for almost two years but don't use it often at all..maybe once a week...sometimes just once or twice a month. It definitely does not get heavy usage, so this issue has definitely pissed me off to some degree. I'm here. What are your other two wishes? Link to post Share on other sites
trium 0 Posted April 19, 2015 Share Posted April 19, 2015 usually produced cheaper (made in china or so) and the device should only works until the end of the warranty of the manufacturer ;-) and on a laptop you can not change the monitor/display :-( I found an HDMI and tried it. The picture on the TV was great. So I guess it's the screen or it's connection. Just once more reason why I hate laptops LOL nice to read this :-) Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
