trium 0 Posted February 26, 2015 Share Posted February 26, 2015 hi fans, i have a laptop with geforce 720m. occasional crashes the graphic card drivers and restarted. i have driver version 326 as recommended by asus download site. before I had the version 344-there was the same problem. now i will install the new version 347 and want to see if further those crashs happened. perhaps this was the same problem as with the "round 800 MB sized *.tmp"... I cant find the contribution as in the description "unsupported Hyprid saving mode" is disabled on my energie-settings. does anyone know what could something be? w8.1 64 bit i5 cpu 8 gb ram 1 tb harddisk intel 4000 graphic + geforce 720m Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
Moderators Nergal 0 Posted February 26, 2015 Moderators Share Posted February 26, 2015 You should always get Laptop drivers (especially graphics) from the Laptop manufacturer, and not the Nvidia/AMD website, make sure that's what you are doing. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Moderators Andavari 1 Posted February 27, 2015 Moderators Share Posted February 27, 2015 To add what Nergal stated you also want to avoid getting the drivers from the Microsoft Update website which always seems to want to install display drivers. Link to post Share on other sites
trium 0 Posted February 27, 2015 Author Share Posted February 27, 2015 i have download the asus-driver, but with this are equally driver crashes happened... it seems to be normal older driver of nvidia for 720m. windows update has not proposed updatesanyway thanks for your answer Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
