dwooddii Posted January 9, 2015 Share Posted January 9, 2015 I am trying to see the information about me my system so i may get the proper drivers for each of my system components as this is a custum built system with out supplyed drivers where does speccy get the system information? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 9, 2015 Moderators Share Posted January 9, 2015 That's all speccy shows, I think I'm not understanding the question. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators mta Posted January 10, 2015 Moderators Share Posted January 10, 2015 without access to the code or comments from the Dev Team, I'd guess Speccy simply interrogates the Description or Properties or what-have-you fields from the firmware in question and just shows you what it finds. at less than 4MB is size, there can't be much internally processes going on. all your integrated drivers will be found on the motherboard manufacturers website download/support page. any add-on cards, like video and sound, will have to be sourced from those vendors websites. you shouldn't need Speccy to tell you what it finds (and maybe give you false info), just note the motherboard make/model and search for that on the appropriate website. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
dwooddii Posted January 11, 2015 Author Share Posted January 11, 2015 so where is this Description or properties file so i can restor so speccy WILL see it corectly? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 11, 2015 Moderators Share Posted January 11, 2015 I think you misunderstood. There is no description or property file. Speccy queries the Windows Management Interface service. The service, built into the operating system, allows hardware to announce status and other information to the software OS and the user. What exactly information are you trying to get? For example on my PC I can click on motherboard and see the Brand, Model and Version of my laptop. perhaps you can provide us with a shot of what you mean shows nothing. here's another with my graphics card (which would allow me to find the driver for that). are you trying to find information on devices that aren't correctly detected by windows (show-up as unknown?)? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
