FUD 0 Posted October 19, 2014 Share Posted October 19, 2014 Hello, I'm using CCleaner64 Free version 4.18.4844. Monitoring has been disabled: Both checkboxes under Options/Monitoring, Enable system monitoring and Enable Active Monitoring are unchecked. I created another shortcut to run "C:\Program Files\CCleaner\CCleaner64.exe" /AUTO (Like I have been doing for years). Every time I run it, the icon remains in the notification area. And I have to right-click on it and select any choice to make it vanish. Regardless, please be thanked for such an excellent piece of software. Link to post Share on other sites
Moderators Andavari 2 Posted October 19, 2014 Moderators Share Posted October 19, 2014 See if this topic helps any, someone with the same issue: http://forum.piriform.com/index.php?showtopic=41890 Link to post Share on other sites
FUD 0 Posted October 19, 2014 Author Share Posted October 19, 2014 Thank you for answering. I'm sorry to report that everything was set to the proper values: - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run: No sign of CCleaner - INI File: Monitoring=0 SystemMonitoring=0 - CCleaner runs normally - No orphaned process Moreover, I have at least 10 other machines (Win XP, 7 or 8) running CCleaner /AUTO directly or in batch files without any issue. Link to post Share on other sites
FUD 0 Posted October 19, 2014 Author Share Posted October 19, 2014 I uninstalled version 4.18.4844, d/l'd a fresh copy, then re-installed it: No go. Fully uninstalling using specialized software to remove any trace of CCleaner and Piriform from the registry, then re-installing: Still no joy. Thanks to FileHippo, you can still get CCleaner 4.17.4808: http://www.filehippo.com/download_ccleaner/58488/ I was never too keen on this monitoring feature anyway. Please close this thread. Thank you Link to post Share on other sites
Moderators hazelnut 8 Posted October 19, 2014 Moderators Share Posted October 19, 2014 Thread closed at members request. CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
