tony.br Posted September 27, 2014 Share Posted September 27, 2014 The latest version of CCLEANER has a monitoring facility This leaves a stub active to advise if the crud exceeds a certain amount However many users do not want this facility. If this sort of online monitoring was always mandatory, computers would be unuseable I went into the settings and turned it off I restarted ccleaner and the monitoring returned I used startup to disable the link but the minute ccleaner was restarted, it created a new one Sadly this forced me to return to the previous version I hope this can be corrected soon Link to comment Share on other sites More sharing options...
CSGalloway Posted September 27, 2014 Share Posted September 27, 2014 I suggest you look at this thread - a newer 4.18 has been released. http://forum.piriform.com/index.php?showtopic=41860 Link to comment Share on other sites More sharing options...
Noedels Posted September 28, 2014 Share Posted September 28, 2014 Exactly. I had the same problem and also turned back to the previous version 4.17. Link to comment Share on other sites More sharing options...
