CCleaner Community Forums
Registry Cleaner not fixing all issues
When I run the registry cleaner and click fix selected issues. Ccleaner seems  to delete all the selected issues. But when I click on scan for issues again the same active X issues and Missing TypeLib Reference issues show up again.
This has been happening for quite a while. I have tried to re-install CCleaner but to no avail. I have asked other people who use CCleaner but they are all stumped.
I am running windows 7, 64 bit. Would appreciate your input.
Link to post
  • Moderators
How can we help with no information
What are the entries? Often things like this relate to security software. What is your security software? Are you sure these items need removal. Please read the registry advice in my signature for more on that
Link to post
Register a new account
Sign in
