krit86lr Posted February 5, 2006 Share Posted February 5, 2006 When I woke up this morning I turned on my computer, and received a white screen stating that there was a hardware problem (didn't catch the rest), my tower was making a loud bleeping noise, and it said something about a memory dump. I panicked and shut it down. It did the same thing in safe mode. I rebooted, again, in safe mode and the only thing that I could access was Task Manager (which was missing the taskbar/toolbar). I rebooted again in safe mode, and ran dxdiag which said that no problems were found. Then I rebooted Normal, and now it seems to be working. Does anyone know how I could troubleshoot this occurrence, and determine what happened? Thank you, K Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
krit86lr Posted February 6, 2006 Author Share Posted February 6, 2006 Anyone??? What other information can I post that might help you help me? Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
Moderators rridgely Posted February 6, 2006 Moderators Share Posted February 6, 2006 Does your computer boot right now? You said you got your process manager up what processes are running? Link to comment Share on other sites More sharing options...
krit86lr Posted February 6, 2006 Author Share Posted February 6, 2006 Does your computer boot right now? You said you got your process manager up what processes are running? spoolsv.exe svchost.exe lsass.exe services.exe winlogon.exe csrss.exe wdfmgr.exe smss.exe snmp tcpsvcs taskmgr soffice.bin soffice.exe msnmsgr WinColorReminder inetinfo TeaTimer gcasServ System System Idle Process firefox MSIMN devldr32 swcntfy alg cidaemon mqtgsvc CTsvcCDA cisvc explorer gcasDtServ Note. My Task Manager Screen only partially displays so that's all I can see. (Tabs are missing, etc...) Thank you rridgley. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
lokoike Posted February 6, 2006 Share Posted February 6, 2006 Note. My Task Manager Screen only partially displays so that's all I can see. (Tabs are missing, etc...) I thought you said it is working now? Is the Task Manager still missing tabs, etc., or is it in normal mode and working fine now? You said that it was beeping. Was it beeping over and over? And if so, does your case have any temperature sensors (it will look like a skinny cable with a little clear plastic tab on the end that has a small curved wire inside). If so, try going into your BIOS and checking to see if there are any alarm settings for computer's temperature. If there are, turn the off, because it is possible that your sensor went bad, and is relaying the wrong temerature to your BIOS, which in turn, warns you with those annoying beeps. This most likely isn't the case, but I did run into this problem once with a fairly new computer, so it isn't unheard of. Save a tree, eat a beaver. Save a tree, wipe with an owl. Every time a bell rings, a thread gets hijacked! ding, ding! Give Andavari lots of money and maybe even consider getting K a DVD-RW drive. If it's not Scottish, IT'S CRAP!!! Link to comment Share on other sites More sharing options...
krit86lr Posted February 6, 2006 Author Share Posted February 6, 2006 Okay. I think that it fixed itself (shrug) Event Mngr Listed * Source i8042 can't set keyboard indicator lights * Source i8042 can't set keyboard typematic rate & delay * Source i8042 the device sent an incorrect response following a keyboard reset I checked Device Manager, everything is updated, and it states that everything is working properly. 11 bootstart or system-start drivers failed to load. According to Microsoft this was due to an Update!! I didn't know that my computer could make such loud beeping noises. I'm glad that it stopped (for whatever reason). Thanks rridgley. I need beer now. Bye. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
zaphirer Posted February 7, 2006 Share Posted February 7, 2006 -- Link to comment Share on other sites More sharing options...
krit86lr Posted February 7, 2006 Author Share Posted February 7, 2006 For your task manager, if you have XP, double click on the task bar at the top, since the Process Manager has two views. As for your other problem... I don't really know... it's weird, to say the least. I don't understand what happened. I lucked out because somehow the problem fixed itself. The same thing happened to a lady on Majorgeeks forum, and it happened to both of us on the same morning. Her computer didn't fix itself, and now she's been without a keyboard for 2 days. Microsoft posted a security bulletin (MS05-051) about my error codes & warnings which stated that update KB909444 is the cause. This update had TONS of problems associated with it. It was hard to read through, and I didn't understand a lot of it. It had something to do with BIOS, COM, MSDTC & lots of other things. I finally rebooted today, and it went okay. I seriously lucked out because I wouldn't have known what to do otherwise. My computer is pretty old, and I thought that it had finally died. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
zaphirer Posted February 8, 2006 Share Posted February 8, 2006 -- Link to comment Share on other sites More sharing options...
krit86lr Posted February 8, 2006 Author Share Posted February 8, 2006 Huh. The Microsoft website basically said something along the lines of: "The critical files were messed up because they were renamed and not recognized by the computer." Or something like that. Maybe it said "Your computer is messed up because you were mean to it and it doesn't like you." Huh? What are you talking about? Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
gunner Posted February 8, 2006 Share Posted February 8, 2006 Krit, sounds like you dodged a microsoft bullet. Scan your disc and make sure you click "attempt to repair". When you are sure all is well run ERUNT {www.snapfiles.com} and save the results. It will mirror your registry and you can fix problems in a snap by restoring the registry. It has saved me on more than one occasion. If it isn't broke, tweak it. Link to comment Share on other sites More sharing options...
