rjo98 Posted December 2, 2013 Share Posted December 2, 2013 Any thought to adding some cleaning for Notepad++, like it's recent files and the old find/replace phrases you type in? Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 2, 2013 Share Posted December 2, 2013 they are sadly located in %AppData%\Roaming\Notepad++\config.xml so it'd remove settings if deleted.But if you open config.xml in windows notepad you can change it so it doesn't store recently opened and search phrases. near the bottom of config.xml look for these. nbMaxFindHistoryPath="0" nbMaxFindHistoryFilter="0" nbMaxFindHistoryFind="0" nbMaxFindHistoryReplace="0" History nbMaxFile="0" Link to comment Share on other sites More sharing options...
rjo98 Posted December 6, 2013 Author Share Posted December 6, 2013 that's a bad place to store them but thanks for letting me know how to get rid of that stuff anyway, I appreciate it. Link to comment Share on other sites More sharing options...
