thoste Posted April 29, 2013 Share Posted April 29, 2013 I want to let CCleaner AUTOMATICALLY run at user logoff event and at shutdown. NO, I don't want to use the /SHUTDOWN cmdline flag because - This would require one more shortcut icon on my desktop - I could accidentially forgot to click it and use the traditional "shutdown" in START menu - I have to explain the new shutdown shortcut method to other people using the computer - /SHUTDOWN does not work when user just switches but not full shutdown is performed So gpedit.msc is normally the best place to put such a logoff/shutdown task (see attached snapshot). Surprisingly it seems to me that CCleaner64 (under 64bit Win7) does only perform certains tasks (e.g. wiping Internet Temporary files) but not all (e.g. Cookies are NOT wiped). Why? Is there a way to tell CCleaner to show automatically up its main (progress) window at runtime? Currently it does its (partial) job silently in background at shitdown/logoff time. Thomas Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 29, 2013 Share Posted April 29, 2013 Do you have ccleaner configured to delete cookies? It will only delete what your default profile has selected for deletion. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
thoste Posted April 30, 2013 Author Share Posted April 30, 2013 Do you have ccleaner configured to delete cookies? It will only delete what your default profile has selected for deletion. Yes, I have. It works if I call it at startup but not at shutdown Link to comment Share on other sites More sharing options...
