Guest Keatah Posted January 24, 2013 Share Posted January 24, 2013 The files you put into CCleaner's list can be just about anything you want to delete.. 1- I have added such things as logs and empty directories created by applications. 2- A data recovery application I sometimes use; it makes copies of what I'm recovering straight to the main C drive. Pretty stupid. So I added that in. 3- Status reports from other utilities. 4- Some programs make their own cache, especially some cd burning tools and disk testing tools. These caches and logs are important only for the moment and serve no long-term purpose. 5- A couple of unruly programs insist on making duplicate settings files in the Documents & Settings folder, despite me specifying otherwise. The dev's say it's for "backup" purposes. Meh.. 6- Some Firefox and IE things that CCleaner doesn't go over. 7- I do a lot of photo and scientific work, and use programs that leave temp files behind, so those are added in. One time, at the end of 2 months, I ran my custom list and zapped 17GB! Link to comment Share on other sites More sharing options...
KCav Posted January 26, 2013 Author Share Posted January 26, 2013 I would like to express my appreciation for the good advice given about how to prepare a disk for backup. Here is my revised plan. I would appreciate your comments. 1. Custom configure CCleaner: a) specify cookies to keep b ) specify files to remove c) select folders and registry entries that CCleaner should exclude from removing Run CCleaner manually every night before shutting down the system 2. Custom configure Defraggler: a) move large files to end of drive during whole drive defrag b ) don’t move large files during Defrag Freespace Run Defraggler when adding/deleting programs 3. Schedule a Microsoft Security Essentials Full scan to run every M,W,F night 4. Once a month run SUPERAntiSpyware, Malwarebytes, Acronis System Cleaner, AVG Registry Optimizer; do not run simultaneouly, do not clean. a) print list of files reported as dangerous b ) Google file name to see if others have problems with a file c) adjust CCleaner custom settings Again, thank you for your help, and please send me comments on my revised plan. CCleaner is very efficient. I plan to make extensive use of it. Still chewing on how to position small files for optimal disk performance. KC. Link to comment Share on other sites More sharing options...
Guest Keatah Posted January 26, 2013 Share Posted January 26, 2013 That could work. As long as it's something you can live with. Link to comment Share on other sites More sharing options...
