Quartermass Posted January 3, 2013 Share Posted January 3, 2013 Hello. First of all...let me say that I love this software. I've been using if for years. BUT....I have lately been noticing a strange anomally (this a NON registry cleaner issue). When I open CCleaner (on "Cleaner" setting) and click "Analyze" I'll often get a pile of things listed. Then when I click "Run Cleaner" quite often only a very small portion of the items listed actually get "cleaned". Maybe this is normal(?). I'm running CCleaner V3.26.1888 on XP SP3. I've attached a couple of photos for reference. Any clues? Thanks in advance. Cheers. Link to comment Share on other sites More sharing options...
kroozer Posted January 3, 2013 Share Posted January 3, 2013 For me, sometimes CC leaves some files uncleaned, and a second clean finishes the job. If a second clean doesn't finish it I recommend a total uninstall, and install anew cos your program may be corrupted. Link to comment Share on other sites More sharing options...
Ishi Posted January 4, 2013 Share Posted January 4, 2013 My suggestion is that I would tick the boxes you have left unticked as shown from the screenshot. EXCEPT Start Menu Shortcuts, DEsktop Shortcuts and WIPE FREE SPACE. This would allow CCleaner to clean more than what it cleans now. There are files that have to stay in there longer, maybe longer than 24-48 hours before they can be safely cleaned. I would also suggest, if you like to use Winapp2.ini that can be found here: http://forum.piriform.com/index.php?showtopic=32310 After you download the files you just copy and and paste it to C:\Program Files\CCleaner directory. The next time you open CCleaner, it will take more time to load but when you go to the Applications tab in the cleaner section of CCleaner, you will see many more checkboxes added that you can chose to clean. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
