LilBro Posted November 17, 2012 Share Posted November 17, 2012 Silly question, I know. While waiting for sites to load, MS software to open, and just putzing around, I like to play the standard Games in Win7. Unfortunately, I can't remember which setting in ccleaner wipes all of the game settings. I HATE the defaults of show animations, play sounds, show tips, etc. the idots in Redmond chose but every time I run ccleaner, my preferences are gone and the idiotic game defaults return. So, which / where is the setting in ccleaner to leave my preferred settings alone? Thank you. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 17, 2012 Moderators Share Posted November 17, 2012 Maybe [Game Explorer] ID=2174 LangSecRef=3025 DetectOS=6.0 DetectFile=%%LocalAppData%\Microsoft Games DetectFile2=%LocalAppData%\Microsoft\Windows\GameExplorer DetectFile3=%LocalAppData%\Microsoft\GFWLive Default=False FileKey1=%LocalAppData%\Microsoft Games|*.xml.bak|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\GameExplorer\GameStatistics|*.*|REMOVESELF FileKey3=%LocalAppData%\Microsoft\GFWLive|*.log|RECURSE ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 17, 2012 Share Posted November 17, 2012 If you have winapp2.ini installed, also [MS Windows Game Statistics] deletes settings.. I should rename it to Game Explorer More* winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
