Super Fast Posted October 30, 2012 Share Posted October 30, 2012 Even easier, is if you have a mouse with a middle scroll wheel, you hold CTRL & spin the mouse wheel up or down to go in & out on a page. No, you do not need to manually locate the cookie. Follow my exact instructions, & it should be easy to configure: 1) After ensuring you downloaded/installed the latest CCleaner, open CCleaner & click Options (Cleaner, Registry, Tools, Options). 2) Click Cookies. 3) In the search box on the left, type forum & it should narrow it down to forum.piriform.com. 4) Select forum.piriform.com, & use the arrow to move it to the Cookies to Keep box. * It should work now for this site. So just repeat for your webmail cookie, & add it to the keep box, too. Link to comment Share on other sites More sharing options...
