Help Me Please
krit86lr
Hello. This is my first time posting. Last night I ran ccleaner 1.26 on Windows XP. I can only boot up in safe mode now. I have restored the registry backups about 10 times now, and there isn't any change. If I boot in Normal Mode it takes about 15 minutes to bootup. After that opening anything takes about 10 minutes, and every times out. I don't have internet access anymore in Normal mode (I have a cable connection). Windows cannot start the Windows Firewall/Internet Connection Sharing (ICS) Service. In addition Services (Under System Tools) has stopped almost every service. When I manually try to start a service an error message appears stating that 'The plug and play service is not available'.
Can someone please help me? I'm using my roommates computer to post the message. I can't receive emails at this time, but I will keep the forum open. I've been trying to fix this for 10 hours now.
I know that ccleaner is a good program because everyone (Microsoft, etc...) reports that it is awesome. I must have done something wrong on my end. What can I do?
Thanks in advance for your help.
K- :o
Windows Pro Media 8.1 x64  |  8GB Ram  |  500G HDD 7200 RPM  |  All  that I know about my graphics is that it's Intel  :)
Link to comment
That's a new one and probably not cc. If you haven't made any major changes (hard drive, video,etc.) you should be able to boot in safe mode and go to last known good configuration, or restore the system to a time when all was well.
If it isn't broke, tweak it.
Link to comment
Hi gunner, thank you for your quick reply. First, as soon as ccleaner finished I rebooted my computer; my problems honestly began at that moment. My computer was almost running perfectly before that, I was testing to see if all of the hype was true, and I gave it a try. Is it possible that I didn't uncheck something that I should have?
In addition I have rebooted in safe mode, chose last time windows worked, and it says that no changes have been made. I've done this 5 times now. As for the system restore, I can't get it to turn on.
Thanks in advance for any further suggestions.
K ;)
Link to comment
K ;)
Okay, so I'm still not sure about something. Is it possible that I didn't use ccleaner properly? Could I have not done something correctly while operating the program?
So I have a new question now.
In Registry Editor
Folder HKEY_LOCAL_MACHINE
System (folder)
Setup (folder)
Allow Start (Within in here is DcomLaunch, PlugPlay, etc...) The data column for everything in the Allow Start folder shows 'value not set'. Is this right?
Thanks.
K <_<
Link to comment
Dear newcomer, welcome to the Internet!
This is a discussion board, also commonly called a forum.
When you start a thread on a forum, try to put an informal and useful text in the subject line so people know what the post is about, rather than "HELP!!" or in this case "Help Me Please".
Have a great time, and welcome to the Internet!
Link to comment
  • Moderators
Although you make a very valid point my twisted sense of humor has been enabled.
[enable twisted sense of humor]
Imagine crashing your vehicle that is on fire and about to explode. You yell "help." Just a few feet away another motorist with a fire extinguisher available suggests that you must be more specific as to what sort of help you need and suggests in the future when you crash and your vehicle is on fire and about to explode that you say exactly that so other motorist can promptly provide the correct type of assistance.
[/disable twisted sense of humor]
Link to comment
AMEN! Help is a valid request, especially for those of us that are only mere mortals. Pay no attention to the peanut gallery. It is our cross to bear. Now to your question: I don't have a clue other than you may have a virus and some parts were removed. If you can run a scan disk and click attempt to repair it might help. Anyone else have any ideas? Enclosed is a picture of our resident expert.
Link to comment
One last thought: Go to your device manager and see if you have any yellow question marks. If so, try to reinstall the drivers. Plug and play errors can at times be corrected that way.
Link to comment
What was your suggestion to my problem???
Thanks in advance
K
Link to comment
I just noticed your quote. I will never forget again. :P:D
:lol: You understand!!! THIS IS AN EMERGENCY!!! COMPUTER DOWN!!! THIS IS MY 911 CALL!!! :o
Many Thanks
K
Link to comment
How true. Is it fixed now? let us know.
Hi guys. From what I can tell I am not any closer. I'm not sure if I should cry or throw it out of the window.
Here is the update (I was hoping to post the solution).
All of my drivers are fine.
T
he solution from Microsoft is to manually enter each registry key. I honestly don't think that I have the patience to do that.
If I boot in Normal Mode I only have control through Task Manager. But I can't even open anything.
All of the downloads that I've tried to run from a disk says that I need to be in Normal Mode, but it isn't possible. I can't even use my printer.
I'm seeing an unistall coming on. I can't live too much longer without a PC.
Thanks so much for your support and concern!!
You all are awesome!!
K
:D
I'll keep you all informed. Hopefully I find the cure!!
I PROMISE FROM HERE ON THAT I'LL BACK UP ON A REGULAR BASIS..
Yeah, I wasn't poking fun at you, it was just my warped attempt using another type of situation as an example. Having a PC go kaput is no fun.
I knew what you meant. When I read it I was laughing so hard that I was crying.
Between your comment and gunner's picture my friends and I were thoroughly amused.
Many Thanks
K
Link to comment
Sorry about the late reply, krit86lr. I feel your pain; I've had to wipe hard drives (although not always my own) of irreplaceable files and such. Hopefully, you won't have to do that.
You said that you tried to run System Restore, and it didn't work. Here is something else to try:
1. Hit F8 (over and over) whilst your computer is starting up, right after the BIOS has finished with the POST. If you aren't sure what I'm referring to, just start hitting F8 (maybe twice per second) as soon as you start up your computer.
2. If you do this correctly, a list should come up. This list will have options such as Safe Mode and Normal Mode.
3. Choose the option titled "Last Known Good Configuration (your most recent settings that worked)" and hit Enter.
Hopefully, this will work for you. Sorry once again for not getting this to you sooner. I hope that you haven't already formatted your hard drive!
Save a tree, eat a beaver.
Save a tree, wipe with an owl.
Every time a bell rings, a thread gets hijacked!
ding, ding!
Give Andavari lots of money and maybe even consider getting K a DVD-RW drive.
If it's not Scottish, IT'S CRAP!!!
Link to comment
Unfortunately I don't know what it means to format the hard drive. I'll look that up in a minute.
I have chosed "Last Known Good..." a few times. Everytime that I've chosen that a message is displayed that says "There Haven't Been Any Changes".
I'm at a loss. That message can't be possible. About 20X now I think that I've found the solution, and then it doesn't work. So now that you've mentioned it, I am going to research formatting the hard drive.
Thank you for your concern. Over 40 hours without PC is very very bad.
I'll take any further suggestions. I'll keep plugging along for another 24 hours. Then drastic measures will come into play.
Does anyone know about the Human Interface Device Access Service. When I try to start it I get this:
Error 126: The specified module could not be found.
I found the files hidserv.dll, mouhid.sys, and mouclass.sys on my computer. What else could cause the module to not be found?
Many Thanks,
K
Link to comment
  • Moderators
Before you go about formatting make sure you have available and know where it is either the Windows installation CD, or Windows Restore CD hence without it you'll really be in a mess. Note: Depending upon your computer manufacturer you may have received a Windows install CD, Windows Restore CD, or you may just have a Recovery Partition such as hard disk D:\. If you have a Recovery Partition DO NOT format it!
Link to comment
Okay, first off, formatting (as by now, you probably already know) is when you give your hard drive a file system. By doing this, you "erase" all of the information from your HD, including the OS and files. I say "erase" because most of the information is still technically there, but your computer just treats it like free space and writes over top of it. It is the same thing when you "delete" something from your computer; your OS just acts like the file isn't there, and writes over top of it later.
Most people (myself included) format their HD before installing an OS, even if the file system is already there, to make it a fresh clean install. That way, if your current FS contains any errors, they will be fixed when your reformat it. One thing you can try is putting in your Windows installation disk and just choosing to reinstall without erasing everything; I think you choose the Upgrade option, but I don't remember, since I usually just do full installs.
But if that doesn't work, it very well may be time that you do a clean install and start from scratch. Go into safe mode first and back up all of your important files. You can either do it manually, or use some sort of backup utility, such as the one included with WinXP (Start > All Programs > Accessories > System Tools > Backup). Burn your stuff to disks, or hook up an external HD and pop it onto that.
Then, put in your Windows install disk, and restart your computer. Hopefully, your BIOS is set to boot from your optical drive, in which case the installation will begin automatically. If Windows tries to boot from the HD, restart again and do the F8 thing I mentioned in my previous post. Select Boot From CD (or whatever the option is called; don't have a WinXP disk on hand right now to test it out). After the installation has started, just follow the instructions given on the screen; for the most part, they're pretty self explanatory.
ding, ding!
Link to comment
Thank you! Those are very good instructions. I'll be giving it a shot.
I'll keep you all updated!!
K :D
Link to comment
K :D
:D YEA!!! I have a computer again!! I'm so excited I wish that we all could go out for Happy Hour and celebrate.
To make a long story short: I couldn't retreive my XP installation disks from ex-boyfriend; had to reinstall my old ME program; going to buy new XP cd next week; then a friend of a friend (IT guy) is going to format for me, and show me how to make backups of everything (including regedit).
So, the solution to my problem has been found. Hope to see you all on the discussion board under better circumstances.
Good Times!! Great program!! :P:D
K
K
Thanks again to you all for your help and support. Much appreciated.
Hasta Luego!
K
Link to comment
Awesome! Glad to hear it; although I'm sorry you're stuck with WinME. :(
Try not to faint when you have to pay for WinXP; I just built a new PC for a friend, and when I got WinXP Home for her at Staples, it cost $200! Ouch. But it sure beats ME!
ding, ding!
Link to comment
If you have Win ME, you're eligible for the upgrade version of Win XP which should not cost more than $100 (and is often on sale). Note: If you want to do a clean install with the upgrade version, you supposedly need a retail Win ME CD (not just an OEM restore disk) during the install but I found this isn't always the case, e.g., Dell's restore disk seems to be accepted in lieu of a retail disk.
Link to comment
If you upgrade from ME to XP, aren't you stuck with the FAT32 file system? Or is the option to upgrade to NTFS given? I never use the upgrade option; I like to do a clean install. But you can save alot of money that way.
ding, ding!
Link to comment
The upgrade version allows either an upgrade or a clean install. For the latter you have to insert the old OS CD at one point to prove you qualify. If you opt for the clean install, you can format to NTFS.
I just did one last week.
Link to comment
Register a new account
Sign in
Important Information
