PC_SecurityGuard Posted August 30, 2012 Share Posted August 30, 2012 (edited) Overheating Solution? Can you Piriform Techs perhaps add a Anti-OS Overheat Feature on Defraggler & CCleaner? Because I've been having OS Overheat problems lately & that's why I'm asking . Edited September 7, 2012 by Nergal I've changed the title from"Suggestion on Anything" Link to comment Share on other sites More sharing options...
Corona Posted August 31, 2012 Share Posted August 31, 2012 I'm not a techie here. Do you mean a 'heat monitering app', or a coolant system? Speccy gives real time heat readings of processors. I don't think Piriform is into the coolant department. Link to comment Share on other sites More sharing options...
Super Fast Posted August 31, 2012 Share Posted August 31, 2012 PC_SecurityGuard, most overheating problems are caused by dust accumulation on the fans that cool the pc located on the case/GPU/CPU/power supply, or by very low amounts of RAM (computer is using the HDD a lot), or by being kept in a location that is too hot for normal computer operation. Blow out your dust with a blower while holding the blades of the fans with a q-tip so they don't over-RPM. Do this while the computer is OFF & UNPLUGGED. Check how much RAM you have with the crucial memory scanner. General rule is, anything less than 1 GB is inadequate. Many users need 2 or 3 GB MINIMUM. Reduce your startup items to a bare minimum. Swap Norton/McAfee for AVG free. CClean, then defragment your drive fully. Locate your PC in a cooler room (if necessary). * On older hardware, XP is the lowest you can go and still use modern programs. It may run slightly cooler. Modern hardware runs better on 7. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 31, 2012 Moderators Share Posted August 31, 2012 Is it a laptop? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 31, 2012 Moderators Share Posted August 31, 2012 superfast please use people's "names" not their titles. Calling somebody newbie is kinda rude ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
pwillener Posted September 5, 2012 Share Posted September 5, 2012 ... overheating problems are caused by dust accumulation on the fans ... Well, wouldn't it be just great if CCleaner could do that for us... Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 5, 2012 Share Posted September 5, 2012 Just use some Piriform© Pear Juice™ CPU Coolant winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 5, 2012 Moderators Share Posted September 5, 2012 Locate your PC in a cooler room (if necessary). Put it on a shelf in the refrigerator and pull up a comfy chair. Or put a refrigerator in the PC as seen here, beverages not included. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 7, 2012 Moderators Share Posted September 7, 2012 I have edited this topic's title ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
