chemikalguy Posted August 3, 2012 Share Posted August 3, 2012 Currently, when recovering files (I'm using v1.43.623 64-bit on Windows) , if there are multiple nested folders, it simply won't run, giving you the Max Path Length error. It would be nice if rather than having to uncheck the box to just dump all the files into a single folder (I have many thousands), that there is an option to log the files with overlong names, but continue with the recovery job, so that the remainder of the files could be recovered into the folder structure. Then, after the recovery is finished, the log could be viewed so that then the user could recovery individual folders by unchecking the box. Thanks! Scott P.S. This is a great program! Link to comment Share on other sites More sharing options...
Super Fast Posted August 4, 2012 Share Posted August 4, 2012 Try it without the recover folder path option enabled and see if it still gives the same error. Link to comment Share on other sites More sharing options...
