slowday444 Posted June 18, 2012 Share Posted June 18, 2012 I don't see a peripheral categorie so here I am! I've built a desktop with an Asus P8Z77-M Pro mother board, a Core i5 3570K CPU and a SSD. I use an Asus VE 228h LED monitor. After a week or so with the dongle in any given port, the cursor becomes erratic and eventually it will actually freeze. Sometimes a change of ports rectifies it, other times only a reboot. Definitely not the batteries or drivers. Well I guess you can't always say definitely not the drivers. Any theories? Thank you! Link to comment Share on other sites More sharing options...
nodles Posted June 18, 2012 Share Posted June 18, 2012 Have you tried it in another PC? How you know it's not the drivers? Have you tested without drivers and/or removed drivers and reinstalled the latest? Which OS? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 18, 2012 Moderators Share Posted June 18, 2012 dust/hair in the eye? (use canned air on the lazer see if that helps) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Super Fast Posted June 18, 2012 Share Posted June 18, 2012 It is difficult to know how to help, until you know what is causing it. First, you want to eliminate possibilities, which I will list below. - Try a corded mouse. If this fixes it, something about wifi mouse isn't working right. Update driver/move receiver closer/exchange for another mouse/etc. - Check your BIOS settings to ensure USB power settings are correct. If not, correct it & save the settings, then reboot. - Check your power settings in Windows itself. Some computers have ability to shut off ports to conserve power for certain reasons. Go into power options & deselect powering down/standby. - Update your BIOS to the latest at the manufacturer website. - If still having problems after changing BIOS settings, try resetting it to default settings. Overclocks & other changes can cause problems for connected devices. - If worse comes to worse, try a USB add-in card & see how your mouse works with it. Save your onboard for other things that don't have that problem. - Try a different OS, or even Ubuntu to see how they handle USB under heavy use. What OS are you using? 32 or 64 Bit? How much RAM do you have? Are your CPU/GPU/Case fans clean & clear of dust? * Additionally, be sure your using a proper mouse pad. Some surfaces are difficult for lasers to track, & cause erratic tracking or jumping on the screen. Link to comment Share on other sites More sharing options...
slowday444 Posted June 18, 2012 Author Share Posted June 18, 2012 It is difficult to know how to help, until you know what is causing it. First, you want to eliminate possibilities, which I will list below. - Try a corded mouse. If this fixes it, something about wifi mouse isn't working right. Update driver/move receiver closer/exchange for another mouse/etc. - Check your BIOS settings to ensure USB power settings are correct. If not, correct it & save the settings, then reboot. - Check your power settings in Windows itself. Some computers have ability to shut off ports to conserve power for certain reasons. Go into power options & deselect powering down/standby. - Update your BIOS to the latest at the manufacturer website. - If still having problems after changing BIOS settings, try resetting it to default settings. Overclocks & other changes can cause problems for connected devices. - If worse comes to worse, try a USB add-in card & see how your mouse works with it. Save your onboard for other things that don't have that problem. - Try a different OS, or even Ubuntu to see how they handle USB under heavy use. What OS are you using? 32 or 64 Bit? How much RAM do you have? Are your CPU/GPU/Case fans clean & clear of dust? * Additionally, be sure your using a proper mouse pad. Some surfaces are difficult for lasers to track, & cause erratic tracking or jumping on the screen. Nice reply. Especially like the Power Settings! It is 64 bit Windows 7. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 19, 2012 Moderators Share Posted June 19, 2012 After a week or so with the dongle in any given port, the cursor becomes erratic and eventually it will actually freeze. I had that problem earlier this year and eventually the mouse just died. Link to comment Share on other sites More sharing options...
slowday444 Posted June 20, 2012 Author Share Posted June 20, 2012 It is difficult to know how to help, until you know what is causing it. First, you want to eliminate possibilities, which I will list below. - Try a corded mouse. If this fixes it, something about wifi mouse isn't working right. Update driver/move receiver closer/exchange for another mouse/etc. - Check your BIOS settings to ensure USB power settings are correct. If not, correct it & save the settings, then reboot. - Check your power settings in Windows itself. Some computers have ability to shut off ports to conserve power for certain reasons. Go into power options & deselect powering down/standby. - Update your BIOS to the latest at the manufacturer website. - If still having problems after changing BIOS settings, try resetting it to default settings. Overclocks & other changes can cause problems for connected devices. - If worse comes to worse, try a USB add-in card & see how your mouse works with it. Save your onboard for other things that don't have that problem. - Try a different OS, or even Ubuntu to see how they handle USB under heavy use. What OS are you using? 32 or 64 Bit? How much RAM do you have? Are your CPU/GPU/Case fans clean & clear of dust? * Additionally, be sure your using a proper mouse pad. Some surfaces are difficult for lasers to track, & cause erratic tracking or jumping on the screen. So indeed, under advanced power settings and USB there was a "Selective Suspend" setting that was enabled. I've disabled it and so far so good, although it's hard for me to believe that an active port would be involved. I also read where fans can interfere with the connection. There are three plus the CPU fan. If it occurs again I'll try a M to F USB cable and put the dongle up on the desk, away from the case. If that fails I'll try the same with a powered hub as there like five bucks on ebay. I love this mouse. It's big and it doesn't have a segmented scrolling wheel and that is the reason I bought it for the old XP machine. It is a little harder to middle click admittedly. I still haven't checked the BIOS yet. It did work fine the first several weeks so perhaps it is dying as Andavari suggested! Link to comment Share on other sites More sharing options...
