Greenknight Posted January 2, 2006 Share Posted January 2, 2006 Nothing is faster an easier than what I do, which is:1. Dump a batch file such as "Check Disk.bat" into C:\Windows 2. Input the command line chkdsk parameters you want to use, mine are: CHKDSK.EXE /X /V /F D: CHKDSK.EXE /V C: 3. Create a shortcut on the Desktop that points to C:\Windows\Check Disk.bat and all I have to do is double click it to have my disks scanned for errors. I only have it clean indexes on C: which will report any errors because the fix command won't work for my C: drive for some reason. Instead to fix errors on C: I run: FSUTIL.exe DIRTY SET C: and then reboot. 25777[/snapback] That's fast and easy when you know how to do that stuff, but the average Joe Blow wouldn't have a clue how to create a batch file, and if he saw the Command Prompt window he'd be scared to death. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted January 2, 2006 Moderators Share Posted January 2, 2006 That's fast and easy when you know how to do that stuff, but the average Joe Blow wouldn't have a clue how to create a batch file, and if he saw the Command Prompt window he'd be scared to death. 25848[/snapback] Correct!!! Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
