sju Posted April 15, 2012 Share Posted April 15, 2012 Hi, I will explain the context, the behavior of recuva 1.42 and the behavior of recuva 1.10 Context: I have deleted by mistake a folder of photos in a SDcard of 16GO (fat32) plug in an usb adapter. The disk appeares in window XP as removable drive, of course. Also, after this mistake, I don't write anything and start recuva directly. With recuva 1.42: after a scan, the directory is found with the correct name but all photos inside are NOT recoverable .... strangely overwrite by sector of other older files. No preview available. With recurva 1.10 after a scan, the directory is found with an incorrect name (named 'new folder' !!) but all photos inside are recoverable ! the recover is OK and the preview is ok also! Well everything was restored. The issue? the restore was available only with the 1.10 and not with the 1.42. Something goes wrong when the soft looks for fat sector table. (How I fin this bug? I have an old version. The folder name " frightens me and I download the lastest version. but the result was worst with this one Anyway, This tool is pretty useful. Thanks to the developer) Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 16, 2012 Moderators Share Posted April 16, 2012 the devs read all threads, though rarely comment, though I think they'll find this interesting and look into it (sorry I've no solution for you though, some member will come through soon with some immediate suggestions though I'm sure. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
