wrong temp. with ASUSTeK SABERTOOTH P6
hurnhu
  • Moderators
devs read all posts, though rarely comment til a fix is in.
thanks for your post (100° difference :blink: )
Link to comment
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
Just installed Speccy. My motherboard is an ASUS P8H67-M EVO.
Per ASUS, the CPU temp is 41C. Speccy say 40. That one is close enough.
However Speccy reports mobo temp as 98C, whereas the ASUS monitor says it is 38C. Looks like there is a slight misinterpretation of the bits with recent ASUS motherboards. <_<
Link to comment
Register a new account
Sign in
Important Information
