Speccy Optical drive module - unknown error message
wtayo792
Have version 1.14.288 loaded and on a XP-SP3 computer the optical drive module gives this error message during the scan process.
Optical Drives
Unknown system error: 0x80041004
The drives (2) appear to be working ?? correctly as I can see them in Win Explorer. I would like to be able to see the details in Speccy. Any suggestions?
Link to comment
  • Moderators
Did you get this if you use an an earlier version of Speccy?
Older versions can be gotten from here on the right of the page
http://www.filehippo...download_speccy
Are there any errors which show up around the same time as you run it in any ofthe Windows Event Viewer areas (system or application?}
What make and model are your drives? (info can be found in the device manager)
Support contact
https://support.ccleaner.com/s/contact-form?language=en_US&form=general
or
support@ccleaner.com
Link to comment
Have taken the following steps;
Removed Speccy 1.14.288 and reinstalled same - no change
Both opticals are IDE so I changed the ribbon cable (80 connector type) - no change
Changed IDE from Primary to Secondary connector on MOBO, and checked BIOS settings - no change
Researched for any XP System event alerts - there are none
Removed Speccy 1.14.288 and installed 1.13.276 - no change
Ran WinUtilities app version 10.4 and can see both drives fine
CDR0 - AOpen 12x DVD-ROM
CDR1 - AOpen Com5232/AAH Pro (combo DVD-ROM/CD writer)
Link to comment
Register a new account
Sign in
Important Information
