John D. Farr Posted December 18, 2011 Share Posted December 18, 2011 Greetings, and thanks for looking into this. I am using Cobian backup (ver 10.1.1.816). Cobian has a nice feature where you can execute a program before backup begins. There are two ways to execute a program. The first is just execute it. Cobian continues after the program starts. The other is "execute and wait." In this case, Cobian is supposed to wait until the executed program terminates before it continues. I have used Microsoft Task Scheduler to create a task called "autocleaner" which executes ccleaner with the /AUTO option and elevated privileges in order to get around being nagged by UAE. This works perfectly. I have added this task to Cobian to be run before backup begins using "execute and wait." Here's the problem. Cobian does not wait for ccleaner to terminate before it presses on with its backup. To compound the problem, Cobian creates a shadow copy of the drive first thing, ensuring that all the trash I wish to delete with ccleaner still goes into my backup. I have successfully used "execute and wait" for other programs without a problem. I would very much appreciate hearing from anyone who has solved this problem! thanks, John Other relevent info ccleaner ver v3.13.1600 64 bit Cobian backup ver 10.1.1.816 windows 7 64 bit basic edition Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 18, 2011 Moderators Share Posted December 18, 2011 I don't use Cobian so cannot really comment on your issue. Only mention I find of Cobian is forum search of posts is this thread http://forum.pirifor...showtopic=12878 If no answers here from members perhaps Cobian may have an answer, seen a post here that perhaps you have already noticed http://www.cobiansof...?g=posts&t=4305 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 19, 2011 Moderators Share Posted December 19, 2011 The Problem is you aren't telling cobian to run ccleaner your asking it to run a task. Once that task is finished (the task ONLY consists of launching ccleaner) Cobian continues, you'll need to find a different way to run ccleaner /auto before cobian. perhaps a script that launches a command window the command window then runs ccleaner/auto's task then after auto is down the script shuts down the command prompt and thus the script ends. This script ending can then trigger cobian someone who writes scripts will have to translate to actual work instructions but on run open cmd.exe echo c:\program files\ccleaner\ccleaner.task wait on end close cmd.exe note the above script will only get you errors don't follow the words in it just the idea (I'm sure alan_B will cook up an actual computer script for you, if you wait a bit) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Alan_B Posted December 21, 2011 Share Posted December 21, 2011 The magic Prefix is Start /Wait e.g., on my x64 system I use Portable CCleaner64 in folder H:\Utils\CCleaner\ On my old 32 bit XP I had a *.BAT script that concluded with the lines START /WAIT H:\Utils\CCleaner\CCLEANER /AUTO SHUTDOWN2.EXE Only after CCleaner had completed was the script able to move on to use the third party Shutdown2.exe utility. (My XP Home had a standard (and hence defective) Shutdown.exe and would only shutdown Windows but not the system when CCleaner arguments were "/AUTO /SHUTDOWN") On 64 bit Windows 7 there are no shutdown problems so I no longer need "Start /Wait" but it should should work the same with CCleaner64 I have just tested by launching CMD.EXE and issued this command C:\Users\Alan>START /WAIT H:\Utils\CCleaner\CCLEANER64 C:\Users\Alan> You cannot see it but after the command there was a delay until I closed CCleaner64, and only after that did I get the "command prompt" that followed. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 21, 2011 Moderators Share Posted December 21, 2011 Alan, thank you for you help. The OP isn't trying to shutdown though. Currently a Task is called by the backup program (the task's PID is killed the second it has performed it's duty) the issue is that he (IMHO) needs the script to open a command prompt > wait and run ccleaner auto > end ccleaner auto close command prompt this way the script's PID is the called by the backup program and won't finish until after the clean is done. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Alan_B Posted December 21, 2011 Share Posted December 21, 2011 Actually, on XP I needed to shutdown. On Windows 7 I have no such need because of other things I wish to do, BUT these things should work if I :- hit the bottom left Windows Start button; click Run...; type in the box to the right of Open : "CMD.EXE" and in the "DOS WINDOW" that opens I can type these commands H:\Utils\CCleaner\CCleaner64.exe H:\Utils\CCleaner\CCleaner64.exe /AUTO START /WAIT H:\Utils\CCleaner\CCleaner64.exe START /WAIT H:\Utils\CCleaner\CCleaner64.exe /AUTO The first two commands launch CCleaner, and control instantly returns to CMD.EXE in the "DOS WINDOW", and meanwhile CCleaner either waits for Analyse etc buttons or instantly cleans and then exits, all depending upon the trailing " /AUTO" argument The second two commands keep CMD.EXE on hold until CCleaner has not only launched but also completed and been closed. N.B. I have just confirmed the above work without /AUTO. I have no intention of risking my new Windows 7 with a blind /AUTO - I want to SEE what is about to go before I suffer regret Based on the above, and taking a wild guess that Microsoft Task Scheduler "autocleaner" fails when attempting something like c:\program files\ccleaner\ccleaner64 /AUTO You may be lucky if you try START /WAIT c:\program files\ccleaner\ccleaner64 /AUTO If that fails then you actually need the scheduler to run c:\program files\ccleaner\CLEAN.BAT and add to c:\program files\ccleaner\ a new CLEAN.BAT holding the code START /WAIT c:\program files\ccleaner\ccleaner64 /AUTO Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 21, 2011 Moderators Share Posted December 21, 2011 I thing the last part of what Alan put is getting there ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
