An always false key for making our own cleaners
Andavari
  • Moderators
I'd like to see the implementation of an "AlwaysFalse" key for making our own cleaners in winapp2.ini. Basically what it would do is always have such cleaners with "AlwaysFalse" as the default setting to automatically get disabled/unticked when restarting CCleaner.
Example:
[some App (Logs)*]
LangSecRef=3024
Detect=HKCU\Software\Some App
Default=AlwaysFalse
FileKey1=%appdata%\Some App\Logs|*.*
Link to comment
  • 2 weeks later...
Default=False
You have to tick that entry first time you run CCleaner, and doesn't get unticked after closing/restarting CCleaner.
Default=AlwaysFalse
Entry resets to false/unticked everytime CCleaner is closed/restared.
Did this help? At least that's how I understood it.
Link to comment
  • Moderators
naw, by "custom cleaner" he means win*2.ini entries
Link to comment
Register a new account
Sign in
Important Information
