keith1937 Posted October 31, 2011 Share Posted October 31, 2011 I am running W7 32bit. What should I tick in all of the boxes This is what I have "not" ticked Internet Explorer Autocomplete Form History Saved Paswords Windows Explorer Network Passwords System Windows Error Reporting DNS Cache Font Cache Start Menu Shortcuts Desktop Shortcuts Advanced Nothing is ticked in any of the boxes Registery cleaner All ticked Options > Advanced only two ticked Show prompt to back up registery isues Enable Windows Jump List Tasks. Your help would be greatly apppreciated thank you Keith Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 31, 2011 Moderators Share Posted October 31, 2011 this seems to be a question of personal judgment. really you need to figure out what you want and don't want deleted as far as the registry section clean nothing. . .well nothing that you don't know you want removed. Follow the advice below, in my signature ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted November 1, 2011 Moderators Share Posted November 1, 2011 I agree with Nergal, a lot of it is just personal choice. Why not just go with the defaults at ccleaner install ? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators DennisD Posted November 1, 2011 Moderators Share Posted November 1, 2011 Also bear in mind some of your on-line passwords for various sites may be stored in cookies, which you would need to keep if you want to retain the log-in information. Choosing "Cookies to keep": Link to comment Share on other sites More sharing options...
keith1937 Posted November 2, 2011 Author Share Posted November 2, 2011 DennisD Thank you very much for that infomation Keith Link to comment Share on other sites More sharing options...
taradiana Posted December 1, 2011 Share Posted December 1, 2011 After doing the other cleanings, I got to cookies. I put several things into the save column, but saw no button that would allow me to erase the ones I didn't want to save. Did I miss something? taradiana Link to comment Share on other sites More sharing options...
Alan_B Posted December 1, 2011 Share Posted December 1, 2011 There is a vertical bar down the middle with arrow buttons. Select any one of more cookies on one side and press the appropriate button to shift them to the other side. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 1, 2011 Moderators Share Posted December 1, 2011 The Cookie Section is cleaned within normal cleaning Scenerio: Place the cookies you want to keep in the right hand side within cleaner section of ccleaner place checkmarks in the cookies section of each browser listed and also in Applications>Multimedia>Adobe Flash Player Click Analyze and see that the cookies you wish to remove are now listed Click Clean and see that the cookies you wish to remove are now Gone Hope that helped (Alan, try to read the question better ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
