Hard drive - Power On Count glitch
KristoZ
Update: It seems that the problem is related to Windows 64-bit version. On 32-bit Win7 Professional it seems fine:
By the way - one more thing - Speccy does not show which version of Windows 7 do I have (Professional) :
Link to comment
  • Moderators
Weird mine says MS Windows 7 Enterprise 32-bit SP1.
To make sure are you running the latest Speccy (as of this posting 1.13.276)
Link to comment
I am using Speccy v1.13.276 om my other computer too! Isn't it possible that this Windows version bug is just for Professional editions of MS Windows 7? It seems OK on Home Premium (32- and 64-bit) and, as you say, on Enterprise version.
Here is the whole screenshot including Speccy's version:
Link to comment
Register a new account
Sign in
Important Information
