Olav the Viking 0 Posted October 20, 2011 Share Posted October 20, 2011 I have a Dell Latitude D830 with 2 batteries; the standard 9-cell battery plus a 2nd media bay battery that goes into the DVD drive slot when the drive is removed. Both batteries are reported correctly on my desktop background with the Sysinternals BGInfo program: • Battery Name(s): DELL 00 DELL 00 • Battery Charge(s): 100 105 % The following tags are being used to report this data: <Battery Name> WMI Query SELECT Name FROM Win32_Battery <Battery Charge> WMI Query SELECT EstimatedChargeRemaining FROM Win32_Battery Specy reports the battery data like this in the Operating System section: Battery AC line Online Battery full time Unknown Battery Charge % 100 % Battery State High Amount of time remaining (sec) Unknown It should be a simple matter to incorporate the WMI Query into Speccy. Hope this info helps. Silverstone SST-TJ06-B Case, Corsair HX750 P/S, XP Pro SP3, KIS2016Intel D925XECV2 MB w P4 560J (3.6Ghz), 4GB Crucial DDR2 PC2-5300 Ram3 x 750 MB HDs, Teac FD-235HF Floppy, 2 Plextor PX-716SA DVD's (SATA)ATI Radeon X1800XT (512Mb 256-bit GDDR3), 2 Dell 2405FPW 24" 1920x1200 LCDs2 Dell AS500 14W Soundbars, configured to give L, C & R Audio ChannelsAdaptec AHA-2930CU PCI Ultra SCSI Ctrlr, HP4C SCSI Scanner (NOT Chinese) Link to post Share on other sites
