nybnl_njgtb 0 Posted October 19, 2011 Share Posted October 19, 2011 When I run SPECCY a window pops up informing me that the program encountered a problem and needs to shut down. Please let me know if the trouble is in my computer. Link to post Share on other sites
Alan_B 0 Posted October 19, 2011 Share Posted October 19, 2011 What is Your Operating System and Service Patch Level ? What is the exact message, including especially any error codes. Link to post Share on other sites
Super Fast 0 Posted October 19, 2011 Share Posted October 19, 2011 It would be so helpful if you would post the following: - OS + SP # - Speccy version # - If this problem occurs only with Speccy, or if it happens with other programs u use. Also, perhaps you can run Speccy in Debug mode, then post the logs here. * Does Speccy run at all in Safe Mode? Link to post Share on other sites
Moderators Nergal 0 Posted October 21, 2011 Moderators Share Posted October 21, 2011 To run in debug mode type this into your Windows Run Box (Including the quote marks) "C:\program files\speccy\speccy.exe" /debug (replace C:\program files\speccy with the location of your install) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
