six..pack Posted September 27, 2011 Share Posted September 27, 2011 The new versions of CCleaner 3.11 and Defraggler 2.07 are bad coded. Why do both programs start my Floppy-Disk? The name is C-Cleaner, not A-Cleaner. What a crap. You better should test your software before release. Best Regards W. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 27, 2011 Moderators Share Posted September 27, 2011 start your floppy drive? what do you mean? they are (perhaps) detecting your drives as both show lists of drives, but I don't understand how this would possibly cause any concern much less a trolling comment like this. also c doesn't stand for c drive in ccleaner, it (used to) stand for the last word in the "sentence" you made. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 27, 2011 Share Posted September 27, 2011 You still have a floppy drive. Ccleaner initializes all disks, as far as I am aware, this includes externals and floppies. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
eL_PuSHeR Posted September 27, 2011 Share Posted September 27, 2011 It seems this is a new issue for v3.11 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 27, 2011 Moderators Share Posted September 27, 2011 This was also reported in this topic which is actually two bugs. That other topic has more posts in it, etc., and a temporary solution until it's fixed. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 27, 2011 Moderators Share Posted September 27, 2011 This was also reported in this topic which is actually two bugs. That other topic has more posts in it, etc., and a temporary solution until it's fixed. in light of that I'm going to close this topic and expect further posts in the above referenced link. To the original poster, if this is a seperate issue I will reopen this one at your request via private message (please include a link to this topic in the private message) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
