JamesJ Posted September 23, 2011 Share Posted September 23, 2011 I have a 64 bit computer with Windows Home Premium. Might seem like a dumb question but should I be using the 32 or 64 bit version of CCleaner? James Link to comment Share on other sites More sharing options...
Guest TexShane Posted September 23, 2011 Share Posted September 23, 2011 "quoted off the ccleaner download page" Runs on Microsoft Windows 7, Vista, XP and 2000. Including both 32-bit and 64-bit versions. "of the operating system, ccleaner has no different download for 32 or 64 bit". Last I heard also, I thought piriform dropped 2000 support, but it's still listed on the page, because some old versions work with 2000. Link to comment Share on other sites More sharing options...
Alan_B Posted September 24, 2011 Share Posted September 24, 2011 The portable ZIP will give you both CCleaner.exe and CCleaner64.exe With both on a flash drive it makes no difference which you launch - the correct one for the system will operate. If you delete the correct one the other will run but may miss some of the things that would otherwise get zapped. I guess if you install the installer will make the correct decision on which flavour to install. Link to comment Share on other sites More sharing options...
JamesJ Posted September 24, 2011 Author Share Posted September 24, 2011 Got it. Thanks, James Link to comment Share on other sites More sharing options...
