wiedii Posted July 30, 2011 Share Posted July 30, 2011 Hello The program still does not clean up the database ACDSee Pro 3(4) and Adobe Bridge (cs3, cs4, cs5) Link to comment Share on other sites More sharing options...
redhawk Posted July 30, 2011 Share Posted July 30, 2011 Should it?? Richard S. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 30, 2011 Share Posted July 30, 2011 I don't think CCleaner officially supports those cleaning sets, but I may be wrong. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
wiedii Posted July 30, 2011 Author Share Posted July 30, 2011 Should it?? Richard S. почему бы и нет Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 30, 2011 Moderators Share Posted July 30, 2011 почему бы и нет Why not This is an english speaking forum please use translation before posting Это форум английски говоря, пожалуйста, используйте перевода, прежде чем отправлять Please see the link http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-add-your-own-program-for-ccleaner-to-clean on how to make personal additions to ccleaner. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
wiedii Posted July 31, 2011 Author Share Posted July 31, 2011 This is an english speaking forum please use translation before posting Это форум английски говоря, пожалуйста, используйте перевода, прежде чем отправлять Please see the link http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-add-your-own-program-for-ccleaner-to-clean on how to make personal additions to ccleaner. this forum for suggestions or not? Why do I need to make "personal additions" if I already know where and what files should be removed. I simply propose to add this feature in future versions of CCleaner Link to comment Share on other sites More sharing options...
Alan_B Posted July 31, 2011 Share Posted July 31, 2011 this forum for suggestions or not? Why do I need to make "personal additions" if I already know where and what files should be removed. I simply propose to add this feature in future versions of CCleaner You did not make a suggestion. It was framed as a complaint/criticism hence the initial response. N.B. Your knowledge would enable you to make "personal additions" if it is important to you. Should you wish to share your knowledge it might help others. There are many "odd-ball" things that may not be worth adding to WinApp2.ini, and some of the more desirable things progress from WinApp2.ini to the default CCleaner.exe Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 1, 2011 Moderators Share Posted August 1, 2011 think of winapp2 as a testing/proving ground. The piriform developers have 0 way to get a copy of every program in existence, don't forget this is freeware after all. Basically if you want entries added, you need to provide information on the program(s) A detectable item, such as a location of the executable, or a top level registry entry. All registry items and/or file locations you want removed The best way to get these entries to be tested on more operating systems than you own, it is best to add these entry to the public sourced winapp2.ini Basically your response to me was uncalled for because I was attempting to aid you in your suggestion; so that, in the end, the programs are added to the default program & thus your suggestion was a sucess. As @Alan_B stated most things that are added to the program first go through winapp2. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
wiedii Posted August 7, 2011 Author Share Posted August 7, 2011 you can still clean the cache of Adobe CameraRaw c:\Users\%USERPROFILE%\AppData\Local\Adobe\CameraRaw\Cache\ Link to comment Share on other sites More sharing options...
wiedii Posted August 7, 2011 Author Share Posted August 7, 2011 think of winapp2 as a testing/proving ground. The piriform developers have 0 way to get a copy of every program in existence, don't forget this is freeware after all. Basically if you want entries added, you need to provide information on the program(s) A detectable item, such as a location of the executable, or a top level registry entry. All registry items and/or file locations you want removed The best way to get these entries to be tested on more operating systems than you own, it is best to add these entry to the public sourced winapp2.ini Basically your response to me was uncalled for because I was attempting to aid you in your suggestion; so that, in the end, the programs are added to the default program & thus your suggestion was a sucess. As @Alan_B stated most things that are added to the program first go through winapp2. win 7 ACDSee pro 3 HKEY_CURRENT_USER\Software\ACD Systems\ACDSee Pro\30 C:\Users\%USERPROFILE%\AppData\Local\ACD Systems\Catalogs\30Pro\Default\Thumb1.fpt , Thumb2.fpt..... ACDSee pro 4 HKEY_CURRENT_USER\Software\ACD Systems\ACDSee Pro\40 C:\Users\%USERPROFILE%\AppData\Local\ACD Systems\Catalogs\40Pro\Default\Thumb1.fpt , Thumb2.fpt..... Adobe Bridge CS4 HKEY_CURRENT_USER\Software\Adobe\Bridge CS4 c:\Users\%USERPROFILE%\AppData\Roaming\Adobe\Bridge CS4\Cache\ Adobe Bridge CS5 HKEY_CURRENT_USER\Software\Adobe\Bridge CS5 c:\Users\%USERPROFILE%\AppData\Roaming\Adobe\Bridge CS5\Cache\ Adobe CameraRaw HKEY_CURRENT_USER\Software\Adobe\Camera Raw\5.0 HKEY_CURRENT_USER\Software\Adobe\Camera Raw\6.0 c:\Users\%USERPROFILE%\AppData\Local\Adobe\CameraRaw\Cache\ Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 9, 2011 Moderators Share Posted August 9, 2011 Which of the above post is for detect amd which is for clean ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 9, 2011 Share Posted August 9, 2011 It looks like the registry is for detect and the paths are for cleaning winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
