Graphic card temperature (issue?)
riot89
Hi everybody, i've just discovered Speccy and i'm very impressed, i was used to check my pc stats using several programs together but Speccy does the work of them all just fine.
The only problem i have it's that it doesn't detect my gfx temperature.
I have a Nvidia GTX 570, which is recognized by Speccy.
Below there are some screenshots and my .speccy file.
Thanks for anyone willing to help me :)
.speccy
EDIT: my bad, i just realized i posted in the wrong section
Link to comment
  • 5 weeks later...
  • Moderators
hi i'll move this topic to the right board
Link to comment
Register a new account
Sign in
Important Information
