CC 3.07 Not cleaning Chrome 12.0.742.91 beta-m
pthubbard
I know this has been posted before but I don't see any recent updates to the issue. Has any work been done towards getting CC to work with Chrome? When I run CC, it doesn't see ANY Chrome files... Period. I'm using the latest version of both softwares with Win7x64.
Link to comment
  • Moderators
Beta software is (nearly) NEVER supported in ccleaner. Too many things change between nightly/weekly builds.
Your two choices here are
1) build a winapp2 entry
or
2) wait until google releases the final version of chrome 12
Link to comment
I figured... and since I'm on the beta channel of Chrome, chances are I'll never get a current version of CC working with it. I'm curious, though. Why does an earlier version of CC work? I'm using 3.03 still which cleans chrome just fine.
Link to comment
Register a new account
Sign in
Important Information
