APMichael Posted August 30, 2021 Share Posted August 30, 2021 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f91d4caad1e76d866e5b85a62145785a8decf6c9 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/e7faf3a3cc4cc5245429676b97f64e62b32dd5d0 Link to comment Share on other sites More sharing options...
siliconman01 Posted September 2, 2021 Share Posted September 2, 2021 Modified entry: [jv16 PowerTools *] FileKey3 needs to be removed. Deleting the cache causes jv16 to run Initialization when jv16 is executed. FileKey3=%ProgramFiles%\jv16 PowerTools*\Cache|*.* [jv16 PowerTools *] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools* FileKey1=%ProgramFiles%\jv16 PowerTools*|*.log;*.reg FileKey2=%ProgramFiles%\jv16 PowerTools*\Backups|*.*|RECURSE FileKey3=%ProgramFiles%\jv16 PowerTools*\Debug|*.* FileKey4=%ProgramFiles%\jv16 PowerTools*\Settings|*.log FileKey5=%ProgramFiles%\jv16 PowerTools*\Temp|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted September 3, 2021 Share Posted September 3, 2021 [Beyond Compare *] LangSecRef=3021 Detect=HKCU\Software\Scooter Software\Beyond Compare FileKey1=%AppData%\Scooter Software\Beyond Compare*|*.bak RegKey1=HKCU\Software\Scooter Software\Beyond Compare\Recent This appears with Multi-Edit but does not use %appdata%\.... Is there a modification so it won't show if MEW exists? Detect=HKCU\Software\Multi Edit Software\Multi-Edit\11.0 Link to comment Share on other sites More sharing options...
APMichael Posted September 5, 2021 Share Posted September 5, 2021 On 03/09/2021 at 02:07, CSGalloway said: [Beyond Compare *] ... Detect=HKCU\Software\Scooter Software\Beyond Compare ... This appears with Multi-Edit but does not use %appdata%\.... Is there a modification so it won't show if MEW exists? ... If the entry [Beyond Compare *] appears, then you probably had "Beyond Compare" installed once and it is a leftover after uninstalling. Open "regedit" and delete the "Beyond Compare" key under "HKCU\Software\Scooter Software". Link to comment Share on other sites More sharing options...
CSGalloway Posted September 5, 2021 Share Posted September 5, 2021 5 hours ago, APMichael said: If the entry [Beyond Compare *] appears, then you probably had "Beyond Compare" installed once and it is a leftover after uninstalling. Open "regedit" and delete the "Beyond Compare" key under "HKCU\Software\Scooter Software". As I said Beyond Compare is bundled with Multiedit - but from what I gather - HKCU\Software\Scooter Software\Beyond Compare\Recent never appears.... I have exported the HKCU\Software\Scooter Software\Beyond Compare tree...... in case it may narrow down a mod that would prevent it from showing when I run CCleaner BC.reg.txt Link to comment Share on other sites More sharing options...
APMichael Posted September 6, 2021 Share Posted September 6, 2021 Thanks for the modified entry. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/3edbd77e39bffe1a1891c74ba735639d0c4b5ff3 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f07e11374a8c9347df4034c1ed3b48abc9a2ecce Link to comment Share on other sites More sharing options...
ricktendo64 Posted September 9, 2021 Share Posted September 9, 2021 Here is an old one everybody seems to have missed, Remote Assistance (msra.exe) [Remote Assistance *] LangSecRef=3025 Detect1=HKCU\SOFTWARE\Microsoft\Remote Assistance DetectFile1=%Documents%\Remote Assistance Logs FileKey1=%Documents%\Remote Assistance Logs|*.xml Link to comment Share on other sites More sharing options...
APMichael Posted September 10, 2021 Share Posted September 10, 2021 Thanks for the new entry. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/56993ce27bb8e402b51ce5520acb5763e29bd98ehttps://github.com/MoscaDotTo/Winapp2/commit/3c99227a27ec3674382455729e20ddada9226086https://github.com/MoscaDotTo/Winapp2/commit/f5e55a7b4b51181c12df09b9c2a253f6fb28bb3e Link to comment Share on other sites More sharing options...
CSGalloway Posted September 12, 2021 Share Posted September 12, 2021 On 05/09/2021 at 13:15, CSGalloway said: As I said Beyond Compare is bundled with Multiedit - but from what I gather - HKCU\Software\Scooter Software\Beyond Compare\Recent never appears.... I have exported the HKCU\Software\Scooter Software\Beyond Compare tree...... in case it may narrow down a mod that would prevent it from showing when I run CCleaner BC.reg.txt 4.44 kB · 2 downloads Is there a way t6o modify this so it doesn't show is MEW exists? Maybe change the Detect ? Detect= HKCU\Software\Scooter Software\Beyond Compare\Recent ??? Link to comment Share on other sites More sharing options...
APMichael Posted September 13, 2021 Share Posted September 13, 2021 19 hours ago, CSGalloway said: Is there a way t6o modify this so it doesn't show is MEW exists? Maybe change the Detect ? ... With the September 6 update, "Detect" was changed to "DetectFile" because you had written that the %AppData% path is not used in the bundled version. On 03/09/2021 at 02:07, CSGalloway said: ... This appears with Multi-Edit but does not use %appdata%\.... ... Link to comment Share on other sites More sharing options...
APMichael Posted September 13, 2021 Share Posted September 13, 2021 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/e8d7719113bcbfe34eeeb6702c1b63b936b721dc Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/51874debc8db888579212735af5bb3483109dfd0 This was my last update of the Winapp2.ini for now. Unfortunately, due to major changes in my job and personal life, I no longer have the time to continue maintaining Winapp2.ini. If all goes well, @Winapp2.ini will probably take over the maintenance again soon. I hope to return to the project at some point. Until then, I wish you all a wonderful and healthy time. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 13, 2021 Moderators Share Posted September 13, 2021 @APMichael I'm sure everyone who uses Winapp2.ini wishes you well, and thank you for all the effort you have put into it. I'm sure we'll see you back even if it is just with an occasional post Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 13, 2021 Author Share Posted September 13, 2021 I'll be here to maintain winapp2.ini Be aware that the winapp2ool code signing certificate has expired and I won't be renewing it until my legal name change is complete, so any updates to winapp2ool in the somewhat immediate future will be unsigned and may possibly be flagged as malware. Rest assured that they are not and that the entire source code is always available to you on the repo :) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted September 13, 2021 Share Posted September 13, 2021 Good luck APMichael on your new venture. Thanks much on all your efforts with WinApp2. Please take care of yourself plus your family and stay safe! Great to see that you, Winapp2.ini, are taking over the development and updates. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted September 14, 2021 Share Posted September 14, 2021 @hazelnut @siliconman01 Thank you very much for your kind words. I try to visit the forum from time to time. All the best to you. Link to comment Share on other sites More sharing options...
ricktendo64 Posted September 14, 2021 Share Posted September 14, 2021 Here is a question can we post updates here in this topic, or do we have to do a pull request on GitHub? Best of luck! Link to comment Share on other sites More sharing options...
APMichael Posted September 15, 2021 Share Posted September 15, 2021 Thanks! I think that @Winapp2.ini will also continue that you can still post new and updated entries here. Very large changes as a pull request on GitHub are certainly a reduction in workload. However, the file is approaching the 1 MB limit, then one would have to use the desktop software for a pull request, which would certainly complicate things for some. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 15, 2021 Author Share Posted September 15, 2021 Posting here is fine, pull requests are better! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted September 16, 2021 Share Posted September 16, 2021 Modified entry: [DVDFab *] Added FileKey3: FileKey3=%AppData%\LiveUpdate|*.log [DVDFab *] LangSecRef=3023 Detect1=HKCU\Software\DVDFab Detect2=HKCU\Software\DVDFab Passkey Detect3=HKCU\Software\FabPlayer FileKey1=%AppData%\DVDFab Player*\Advertis*|*.*|RECURSE FileKey2=%AppData%\DVDFab\DVDFab*\SceneData|*.*|RECURSE FileKey3=%AppData%\LiveUpdate|*.log FileKey4=%Documents%\DVDFab*|*.log FileKey5=%Documents%\DVDFab*\Log|*.*|RECURSE FileKey6=%Documents%\DVDFab*\SceneData|*.*|RECURSE FileKey7=%Documents%\DVDFab*\Temp|*.*|RECURSE FileKey8=%Documents%\DVDFab\DVDFab*\Log|*.*|RECURSE FileKey9=%Documents%\DVDFab\DVDFab*\Temp|*.*|RECURSE FileKey10=%Documents%\PcSetup|*.*|RECURSE RegKey1=HKCU\Software\FabPlayer|DefaultDir RegKey2=HKCU\Software\FabPlayer|DefaultFile Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 22, 2021 Author Share Posted September 22, 2021 A new winapp2.ini version is available: 210920 that includes the updated DVDFab * entry. You can get it from github or via winapp2ool! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 22, 2021 Author Share Posted September 22, 2021 I noticed some things: RegEditX entry seems to contain RegKeys for RCrawler [RegEditX *] LangSecRef=3024 Detect=HKLM\Software\DCSoft\RegEditX RegKey1=HKLM\Software\4Developers\RCrawler\History RegKey2=HKLM\Software\4Developers\RCrawler\Settings|LastSearch Is there any reason we shouldn't merge the two Acrobat Distiller entries into one? [Adobe Acrobat Distiller DC *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Acrobat Distiller\DC FileKey1=%LocalAppData%\Adobe\Acrobat\Distiller DC|*.log FileKey2=%LocalAppData%\Adobe\Acrobat\Distiller DC\Cache|*.* RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl [Adobe Acrobat Distiller XI *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Acrobat Distiller\11.0 FileKey1=%AppData%\Adobe\Acrobat\Distiller 11|*.log FileKey2=%AppData%\Adobe\Acrobat\Distiller 11\Cache|*.* RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted September 23, 2021 Share Posted September 23, 2021 15 hours ago, Winapp2.ini said: ... RegEditX entry seems to contain RegKeys for RCrawler ... This entry can actually be removed, since it is already covered by the [Registry Crawler *] entry. The reason for the entry was probably the following at the time: "RegEditX now includes Registry Crawler (from 4Developers) and works seemlessly with Vista and Windows 7 UAC...". 14 hours ago, Winapp2.ini said: ... Is there any reason we shouldn't merge the two Acrobat Distiller entries into one? ... I think the entries are welcome to be merged. [Adobe Acrobat Distiller *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Acrobat Distiller FileKey1=%AppData%\Adobe\Acrobat\Distiller*|*.log FileKey2=%AppData%\Adobe\Acrobat\Distiller*\Cache|*.* FileKey3=%LocalAppData%\Adobe\Acrobat\Distiller*|*.log FileKey4=%LocalAppData%\Adobe\Acrobat\Distiller*\Cache|*.* RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl Link to comment Share on other sites More sharing options...
SMalik Posted October 4, 2021 Share Posted October 4, 2021 New Entry [Stored Notification Settings *] LangSecRef=3025 Detect=HKCU\SOFTWARE\Microsoft\Windows RegKey1=HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Notifications\Settings Link to comment Share on other sites More sharing options...
siliconman01 Posted October 6, 2021 Share Posted October 6, 2021 New entry: [Windows Client WebExperience *] This is part of Windows 11. [Windows Client WebExperience *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\MicrosoftWindows.Client.WebExperience_cw5n1h2txyewy FileKey1=%LocalAppData%\Packages\MicrosoftWindows.Client.WebExperience_*\LocalState\EBWebView\Default|*.Old FileKey2=%LocalAppData%\Packages\MicrosoftWindows.Client.WebExperience_*\LocalState\EBWebView\Default\*|*.Old FileKey3=%LocalAppData%\Packages\MicrosoftWindows.Client.WebExperience_*\LocalState\EBWebView\Default\*\*|*.Old Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted October 7, 2021 Share Posted October 7, 2021 BTW is there a DetectOS=11 for Windows 11? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
