Winapp2.ini additions
Winapp2.ini
  • 2 weeks later...
  • 2 weeks later...
Revised Entry
Added:
DetectFile3
%SystemDrive%\system.sav|*.*|REMOVESELF
[HP Installation Files *]
LangSecRef=3024
DetectFile1=%SystemDrive%\HP Universal Print Driver
DetectFile2=%SystemDrive%\swsetup
DetectFile3=%SystemDrive%\system.sav
FileKey1=%SystemDrive%\HP Universal Print Driver|*.*|REMOVESELF
FileKey2=%SystemDrive%\swsetup|*.*|REMOVESELF
FileKey3=%SystemDrive%\system.sav|*.*|REMOVESELF
Link to comment
On 25/06/2021 at 17:04, SMalik said:
Revised Entry
Added:
DetectFile3
LangSecRef=3024
Please do no change this entry. system.sav is part of HP Support Assistant program and it keeps logs there.
Link to comment
  • 2 weeks later...
- The lines in Winapp2.ini for "Microsoft Teams" (see below) need to be improved/updated. The line "DetectFile= .......... " targets the wrong file/folder and then there won't be a box called "Microsoft Teams" in CC.
- When I look at the lines below then I am confused. The line "DetectFile= .......... " and "Filekey" #12 through 18 point to subfolders under "%localappdata%" . But filekeys #1 through 11 point to %appdata%. My personal opinion is that filekey #1 through 11 should point to "%loacalappdata%. But I don't use "Teams" and can't check the lines below.
[Microsoft Teams *]
LangSecRef=3021
DetectFile=%LocalAppData%\Microsoft\Teams
FileKey1=%AppData%\Microsoft Teams\Logs|*.*
FileKey2=%AppData%\Microsoft\Teams|*.log;logs.txt;old_logs_*.txt;watchdog.txt
FileKey3=%AppData%\Microsoft\Teams\*Cache|*.*|RECURSE
FileKey4=%AppData%\Microsoft\Teams\blob_storage|*.*|RECURSE
FileKey5=%AppData%\Microsoft\Teams\databases|*.*|RECURSE
FileKey6=%AppData%\Microsoft\Teams\IndexedDB|*.*|RECURSE
FileKey7=%AppData%\Microsoft\Teams\Local Storage|*.*|RECURSE
FileKey8=%AppData%\Microsoft\Teams\media-stack|*.bak;*.blog;*.etl
FileKey9=%AppData%\Microsoft\Teams\Service Worker\CacheStorage|*.*|REMOVESELF
FileKey10=%AppData%\Microsoft\Teams\skylib|*.blog;*.data-shm;*.data-wal
FileKey11=%AppData%\Microsoft\Teams\tmp|*.*|RECURSE
FileKey12=%LocalAppData%\Microsoft\Teams|*.log
FileKey13=%LocalAppData%\Microsoft\Teams*Addin|*-logs.txt
FileKey14=%LocalAppData%\Microsoft\Teams\current|*.log
FileKey15=%LocalAppData%\Microsoft\Teams\current\resources\tmp|*.*|REMOVESELF
FileKey16=%LocalAppData%\Microsoft\Teams\packaqes\squirreltemp|*.*
FileKey17=%LocalAppData%\Microsoft\Teams\previous|*.*|REMOVESELF
FileKey18=%LocalAppData%\SquirrelTemp|*.log
See also the discussion in this thread:
System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc
A discussion always stimulates the braincells !!!
Link to comment
6 hours ago, Willy2 said:
- The lines in Winapp2.ini for "Microsoft Teams" (see below) need to be improved/updated. The line "DetectFile= .......... " targets the wrong file/folder and then there won't be a box called "Microsoft Teams" in CC. ...
Thanks for the info. But the entry [Microsoft Teams *] is correct and works as it should. I have just tested it again. "Microsoft Teams" still stores its program files under %LocalAppData% and the user data under %AppData%.
See also the discussion in this thread: ...
The mentioned thread has nothing to do with Winapp2.ini, because the thread starter nowhere mentions that he uses Winapp2.ini. The fact that no "Microsoft Teams" box appears is simply because CCleaner has not yet built in its own cleaning rule for "Microsoft Teams".
Link to comment
Modified Entry:  [Dell Logs *]
Added FileKey12 & FileKey23
Modified: FileKey6 & FileKey13 to include *.log
[Dell Logs *]
LangSecRef=3024
Detect1=HKLM\Software\Dell\MUP
Detect2=HKLM\Software\Dell\UpdateService
Detect3=HKLM\Software\PC-Doctor
DetectFile1=%AppData%\Creative\DELL Webcam Center
DetectFile2=%CommonAppData%\Dell
DetectFile3=%LocalAppData%\Dell
DetectFile4=%LocalAppData%\SupportSoft\DellSupportCenter
DetectFile5=%ProgramFiles%\Dell*
FileKey1=%AppData%\Creative\DELL Webcam Center|MO_Log.txt
FileKey2=%AppData%\PCDr\*\Logs|*.*
FileKey3=%CommonAppData%\Dell\*\Log|*.*|RECURSE
FileKey4=%CommonAppData%\Dell\*\Logs|*.*
FileKey5=%CommonAppData%\Dell\BiosVerification|*.log
FileKey6=%CommonAppData%\Dell\D3\pla\*\*|*.txt;*log|REMOVESELF
FileKey7=%CommonAppData%\Dell\D3\Resources\Logs\serilog|*.*
FileKey8=%CommonAppData%\Dell\Drivers\*|*.log;*.tmp|RECURSE
FileKey9=%CommonAppData%\Dell\TrustedDevice|*.log
FileKey10=%CommonAppData%\Dell\Update|*.txt
FileKey11=%CommonAppData%\Dell\UpdateService\Clients\Update|*.log
FileKey12=%CommonAppData%\Dell\UpdateService\DataStore\*\*|*.log
FileKey13=%CommonAppData%\Dell\UpdateService\UpdatePackage\Log|*.txt;*.log
FileKey14=%CommonAppData%\PCDr\*\Cache|*.xml
FileKey15=%CommonAppData%\PCDr\*\Cache\archives|*.*|RECURSE
FileKey16=%CommonAppData%\PCDr\*\Cache\BUMA|*.*
FileKey17=%CommonAppData%\PCDr\*\Cache\DriverScan|*.*
FileKey18=%CommonAppData%\PCDr\*\Logs|*.*
FileKey19=%LocalAppData%\Dell\*\Log|*.*
FileKey20=%LocalAppData%\Dell\DellMobileConnect|*.log
FileKey21=%LocalAppData%\SupportSoft\DellSupportCenter\*\state\logs|*.*
FileKey22=%ProgramFiles%\Dell*|*.log|RECURSE
FileKey23=%ProgramFiles%\Dell\SupportAssistAgent|*.log
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
14 hours ago, siliconman01 said:
... Modified: FileKey6 & FileKey13 to include *.log
[Dell Logs *]
Thanks for the modified entry.
Just to be sure: should it be "*log" or "*.log"?
Link to comment
OOPS!.  It should be *.log.
Sorry
Link to comment
Modified entry:  [Snagit *]
Added FileKey11
[Snagit *]
LangSecRef=3021
Detect=HKCU\Software\TechSmith\Snagit
FileKey1=%CommonAppData%\TechSmith\Uploader|*.log
FileKey2=%Documents%|SnagitDebug.log
FileKey3=%LocalAppData%\TechSmith\Logs|*.log
FileKey4=%LocalAppData%\TechSmith\Snagit|Tray.bin
FileKey5=%LocalAppData%\TechSmith\Snagit\*\NativeCrashReporting\Reports|*.dmp|RECURSE
FileKey6=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE
FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico
FileKey8=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico
FileKey9=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE
FileKey10=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log;*.logtmp
FileKey11=%Public%\TechSmith\Snagit\License|*.log
RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder
RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder
RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount
RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount
RegKey5=HKCU\Software\TechSmith\Snagit\11|OutputDirLastUsed
RegKey6=HKCU\Software\TechSmith\Snagit\11|VidOutputDirLastUsed
RegKey7=HKCU\Software\TechSmith\Snagit\11\SnagItEditor\Tray|Thumbnailsize
RegKey8=HKCU\Software\TechSmith\Snagit\12|CaptureCount
RegKey9=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount
RegKey10=HKCU\Software\TechSmith\Snagit\12|OutputDirLastUsed
RegKey11=HKCU\Software\TechSmith\Snagit\12|VidOutputDirLastUsed
RegKey12=HKCU\Software\TechSmith\Snagit\12\SnagItEditor\Tray|Thumbnailsize
RegKey13=HKCU\Software\TechSmith\Snagit\13|CaptureCount
RegKey14=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount
RegKey15=HKCU\Software\TechSmith\Snagit\13|OutputDirLastUsed
RegKey16=HKCU\Software\TechSmith\Snagit\13|VidOutputDirLastUsed
RegKey17=HKCU\Software\TechSmith\Snagit\13\Recent Captures
RegKey18=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List
RegKey19=HKCU\Software\TechSmith\Snagit\13\SnagItEditor\Tray|Thumbnailsize
RegKey20=HKCU\Software\TechSmith\Snagit\18|CaptureCount
RegKey21=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount
RegKey22=HKCU\Software\TechSmith\Snagit\18|OutputDirLastUsed
RegKey23=HKCU\Software\TechSmith\Snagit\18|VidOutputDirLastUsed
RegKey24=HKCU\Software\TechSmith\Snagit\18\Recent Captures
RegKey25=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List
RegKey26=HKCU\Software\TechSmith\Snagit\18\SnagItEditor\Tray|Thumbnailsize
RegKey27=HKCU\Software\TechSmith\Snagit\19|CaptureCount
RegKey28=HKCU\Software\TechSmith\Snagit\19|CaptureOpenCount
RegKey29=HKCU\Software\TechSmith\Snagit\19|OutputDirLastUsed
RegKey30=HKCU\Software\TechSmith\Snagit\19|VidOutputDirLastUsed
RegKey31=HKCU\Software\TechSmith\Snagit\19\Recent Captures
RegKey32=HKCU\Software\TechSmith\Snagit\19\SnagitEditor\Recent File List
RegKey33=HKCU\Software\TechSmith\Snagit\19\SnagItEditor\Tray|Thumbnailsize
RegKey34=HKCU\Software\TechSmith\Snagit\20|CaptureCount
RegKey35=HKCU\Software\TechSmith\Snagit\20|CaptureOpenCount
RegKey36=HKCU\Software\TechSmith\Snagit\20|OutputDirLastUsed
RegKey37=HKCU\Software\TechSmith\Snagit\20|VidOutputDirLastUsed
RegKey38=HKCU\Software\TechSmith\Snagit\20\Recent Captures
RegKey39=HKCU\Software\TechSmith\Snagit\20\SnagitEditor\Recent File List
RegKey40=HKCU\Software\TechSmith\Snagit\20\SnagItEditor\Tray|Thumbnailsize
RegKey41=HKCU\Software\TechSmith\Snagit\21|CaptureCount
RegKey42=HKCU\Software\TechSmith\Snagit\21|CaptureOpenCount
RegKey43=HKCU\Software\TechSmith\Snagit\21|OutputDirLastUsed
RegKey44=HKCU\Software\TechSmith\Snagit\21|VidOutputDirLastUsed
RegKey45=HKCU\Software\TechSmith\Snagit\21\Recent Captures
RegKey46=HKCU\Software\TechSmith\Snagit\21\SnagitEditor\Recent File List
RegKey47=HKCU\Software\TechSmith\Snagit\21\SnagItEditor\Tray|Thumbnailsize
RegKey48=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder
Link to comment
Windows ShellBags 1 *]
Section=Charles
Detect=HKCU\Software\Microsoft\Windows
Warning=This will reset folders and desktops size, view, icon or position settings to default and remove traces of the folders that do not exist anymore.
RegKey1=HKCU\Software\Microsoft\Windows\Shell\BagMRU
RegKey2=HKCU\Software\Microsoft\Windows\Shell\Bags
RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU
RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags
ExcludeKey1=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop
ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders
ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop
ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders
[Windows ShellBags 2 *]
DetectOS=6.0|
Section=Charles
Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore.
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU
RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags
ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders
Do the RegKeyN's occur in every Windows version? Do I need a DetectOS here?
Link to comment
I suggest that the above Shellbag entries be placed in Winapp3.ini because all the resets will not be acceptable to many CCleaner users IMO.
Link to comment
14 hours ago, CSGalloway said:
[Windows ShellBags 1 *] ...
[Windows ShellBags 2 *] ...
You had already asked this on GitHub: https://github.com/MoscaDotTo/Winapp2/issues/289#issuecomment-402304112. The answers should still be valid today. If you always use both entries either way, you can also just use the entry [Folders View Settings *] present in Winapp2.ini and remove those two.
The merged entry has existed in Winapp2.ini for a very long time. However, it is now named [Folders View Settings *].
Link to comment
Register a new account
Sign in
Important Information
