Moderators Andavari Posted November 4, 2011 Moderators Share Posted November 4, 2011 I think you forgot to add/modify the entries listed here. I don't know who proposed to update those Freemake cleaners I made but they shouldn't mainly detect the installed location because that can be changed. Much better to detect the registry location. Link to comment Share on other sites More sharing options...
SMalik Posted November 5, 2011 Share Posted November 5, 2011 I don't know who proposed to update those Freemake cleaners I made but they shouldn't mainly detect the installed location because that can be changed. Much better to detect the registry location. I think it is better to have installed location compare to registry location as detect paths. Some times registry data don't get removed after uninstalling a program and not everyone can remove the registry data manually. I have Windows DVD Maker and Windows Media Center features off but the entries were still showing in CCleaner as both the entries had registry detect paths and Windows does not remove the registry entries after turning these features off. I have changed the detect paths and now they are ok. Please look at the post. http://forum.pirifor...ndpost&p=204579 Link to comment Share on other sites More sharing options...
SMalik Posted November 5, 2011 Share Posted November 5, 2011 The entry listed here needs to be corrected. I think you should remove DetectOS=|5.1. Windows 7 32-bit and 64-bit also get these .ini files. The original enrty that Andavari provided was fine. http://forum.pirifor...ndpost&p=203981 [Audio/Video (Stats)*] DetectOS=|5.1 LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini Link to comment Share on other sites More sharing options...
ricktendo64 Posted November 5, 2011 Share Posted November 5, 2011 %USERPROFILE%\AppData\Local is best changed back to %LocalAppData% [TuneUp Utilities 2011/2012 Reg Defrag Cleanup*] LangSecRef=3024 Detect=HKCU\Software\TuneUp\Utilities\10.0 Detect2=HKCU\Software\TuneUp\Utilities\12.0 Default=False FileKey1=%WinDir%\System32\config|SECURITY_tureg_old FileKey2=%WinDir%\System32\config|SOFTWARE_tureg_old FileKey3=%WinDir%\System32\config|SYSTEM_tureg_old FileKey4=%WinDir%\System32\config|DEFAULT_tureg_new.LOG1 FileKey5=%WinDir%\System32\config|DEFAULT_tureg_new.LOG2 FileKey6=%WinDir%\System32\config|SAM_tureg_new.LOG1 FileKey7=%WinDir%\System32\config|SAM_tureg_new.LOG2 FileKey8=%WinDir%\System32\config|SECURITY_tureg_new.LOG1 FileKey9=%WinDir%\System32\config|SECURITY_tureg_new.LOG2 FileKey10=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG1 FileKey11=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG2 FileKey12=%WinDir%\System32\config|SYSTEM_tureg_new.LOG1 FileKey13=%WinDir%\System32\config|SYSTEM_tureg_new.LOG2 FileKey14=%WinDir%\System32\config|DEFAULT_tureg_old FileKey15=%WinDir%\System32\config|SAM_tureg_old FileKey16=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_old FileKey17=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG1 FileKey18=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG2 FileKey19=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_old FileKey20=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG1 FileKey21=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG2 Filekey22=%WinDir%\System32\config|COMPONENTS_tureg_old Filekey23=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG1 Filekey24=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG2 FileKey25=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_old FileKey26=%UserProfile%|NTUSER.DAT_tureg_new.LOG1 FileKey27=%UserProfile%|NTUSER.DAT_tureg_new.LOG2 FileKey28=%UserProfile%|NTUSER.DAT_tureg_old FileKey29=%SystemDrive%\Boot|BCD_tureg_new.LOG1 FileKey30=%SystemDrive%\Boot|BCD_tureg_new.LOG2 FileKey31=%SystemDrive%\Boot|BCD_tureg_old Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 5, 2011 Author Share Posted November 5, 2011 The entry listed here needs to be corrected. I think you should remove DetectOS=|5.1. Windows 7 32-bit and 64-bit also get these .ini files. The original enrty that Andavari provided was fine. http://forum.pirifor...ndpost&p=203981 [Audio/Video (Stats)*] DetectOS=|5.1 LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini the detectos |5.1 makes it only show on Windows XP, where was known to work. Since I couldn't make this file appear on windows 7, I assumed it did not exist there winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 5, 2011 Moderators Share Posted November 5, 2011 I think it is better to have installed location compare to registry location as detect paths. Well it really goes against what you'd even see in the default CCleaner, but to each their own. I realize the "argument" for having it detect the .EXE file installed path as it has some logic, however the problem with that is with custom installations. For instance I absolutely never install any Freemake software into the default location because they have a COM folder which would get shared, and if using all their software (all three programs) it can really get out of wack with version issues when one program is newer than another, I've seen their setups fail multiple times because of it, or installing a new version of one of their programs makes the others unusable, and the only solution is to install each into its own unique folder. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 5, 2011 Author Share Posted November 5, 2011 It seems DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini is created not by checking file properties, but by opening an avi in Windows Media Player, which is why I was unable to created it (i do not use win media player) I will remove the DetectOS in the next iteration winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted November 6, 2011 Share Posted November 6, 2011 New Entry [ManyCam*] LangSecRef=3024 DetectFile=%LocalAppData%\ManyCam\ Default=False FileKey1=%LocalAppData%\ManyCam|error.log FileKey2=%LocalAppData%\ManyCam|instdrv.log FileKey3=%LocalAppData%\ManyCam|VideoSrc.log All of those are recreated when manycam is opened. I left out "install.log" it's useful for troubleshooting an uninstall but it would be FileKey4=%LocalAppData%\ManyCam|install.log Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 7, 2011 Moderators Share Posted November 7, 2011 It seems DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini is created not by checking file properties, but by opening an avi in Windows Media Player, which is why I was unable to created it (i do not use win media player) I will remove the DetectOS in the next iteration In XP all you have to do is single click an .AVI without even opening it and it will be created! Link to comment Share on other sites More sharing options...
Anissa Posted November 7, 2011 Share Posted November 7, 2011 New Entry [GARMIN MapSource*] LangSecRef=3021 detect=HKCU\Software\Garmin\MapSource Default=False FileKey1=%AppData%\GARMIN\MapSource\TileCache|*.*|REMOVESELF Folder TileCache and temporary files are recreated when MapSource is opened. Link to comment Share on other sites More sharing options...
nodles Posted November 7, 2011 Share Posted November 7, 2011 (edited) I think you should add/modify Jagex Cache entry (bolded): DetectFile2 should be added because folder .jagex_cache_32 is not always created. I also tried using wildcards (e.g. DetectFile2=%UserProfile%\jagexcache*) to detect folders jagexcache, jagexcache1 etc. but it didn't work. [Jagex Cache*] LangSecRef=3023 DetectFile=%WinDir%\.jagex_cache_32 DetectFile2=%UserProfile%\jagexcache Default=False FileKey1=%WinDir%\.jagex_cache_32|*.*|REMOVESELF FileKey2=%UserProfile%\jagexcache|*.*|REMOVESELF FileKey3=%UserProfile%\jagexcache1|*.*|REMOVESELF FileKey4=%UserProfile%|jagex__preferences3.dat FileKey5=%UserProfile%|jagex_cl_runescape_LIVE.dat FileKey6=%UserProfile%|jagex_cl_runescape_LIVE1.dat FileKey7=%UserProfile%|jagex_runescape_preferences.dat FileKey8=%UserProfile%|jagex_runescape_preferences2.dat Also, you've used wildcards to detect my Star Wars The Force Unleashed 2 Crash Logs -entry. I tried it, but it didn't work (doesn't appear to CCleaner so it's not detecting the path). [star Wars The Force Unleashed Crash Logs*] LangSecRef=3023 DetectFile=%LocalAppData%\LucasArts\Star Wars The Force Unleashed * Default=False FileKey1=%LocalAppData%\LucasArts\Star Wars The Force Unleashed *|*.* NEW ENTRIES One of my entries wasn't added to the current winapp2.ini: [Windows Log*]. I changed the name because the logs come from Asus' software. [Asus Logs*] LangSecRef=3024 DetectFile1=%WinDir%\log Default=False FileKey1=%WinDir%\log|*.log|*.txt [Revenge of The Titans Logs*] LangSecRef=3023 DetectFile=%UserProfile%\.revenge_of_the_titans_1.80 Default=False FileKey1=%UserProfile%\.revenge_of_the_titans_1.80|*.log [HUAWEI 3G Mobile Connect Logs*] LangSecRef=3024 DetectFile=%WinDir%\ModemLogs Default=False FileKey1=%WinDir%\ModemLogs|*.txt [Mumble Console Log*] LangSecRef=3025 DetectFile=%AppData%\Mumble Default=False FileKey1=%AppData%\Mumble|console.txt [Age of Conan Logs & Temps*] LangSecRef=3023 DetectFile=%ProgramFiles%\Funcom\Age of Conan Default=False FileKey1=%ProgramFiles%\Funcom\Age of Conan|patcher.log|ConanPatcher.exe.0.tmp|CrashLog.txt|AgeOfConan.log|MiniDump.dmp FileKey2=%ProgramFiles%\Funcom\Age of Conan\OldLogs|*.* [CyberLink Logs*] LangSecRef=3024 DetectFile=%CommonAppData% Default=False FileKey1=%CommonAppData%|*.log Edit. A few corrections. Edited November 9, 2011 by nodles Link to comment Share on other sites More sharing options...
JDPower Posted November 7, 2011 Share Posted November 7, 2011 I think you should add/modify Jagex Cache entry (bolded): DetectFile2 should be added because folder .jagex_cache_32 is not always created. It doesn't matter whether it's not always created. If it's not there it won't be cleaned, if it is it will, doesn't mean you need a detect file for it. At the risk of repeating myself, the detect file is solely to tell CCleaner the program is installed - if it's installed CCleaner will clean everything in the entry, you don't need a detect file for every part of the entry. Link to comment Share on other sites More sharing options...
nodles Posted November 7, 2011 Share Posted November 7, 2011 It doesn't matter whether it's not always created. If it's not there it won't be cleaned, if it is it will, doesn't mean you need a detect file for it. At the risk of repeating myself, the detect file is solely to tell CCleaner the program is installed - if it's installed CCleaner will clean everything in the entry, you don't need a detect file for every part of the entry. But it's not a program, comes with browser (like Firefox) if you play Jagex games (Java-based). I tested it and it doesn't find or clean the files/folders in %UserProfile% if the DetectFile=%WinDir%\.jagex_cache_32 is not detected. So it needs something, like DetectFile2=%UserProfile%\jagexcache, or the entry doesn't work/clean completely. Link to comment Share on other sites More sharing options...
nodles Posted November 7, 2011 Share Posted November 7, 2011 (edited) NEW ENTRIES [Comodo Installer Temps*] LangSecRef=3025 DetectFile1=%CommonAppData%\Comodo\Installer Default=False FileKey1=%CommonAppData%\Comodo\Installer|*.tmp [Windows Local AppData .tmp*] LangSecRef=3025 DetectFile1=%LocalAppData%\Temp Default=False FileKey1=%LocalAppData%\Temp|*.tmp [Windows Installer Temps*] LangSecRef=3025 DetectFile1=%WinDir%\Installer Default=False FileKey1=%WinDir%\Installer|.tmp MODIFIED ENTRY [Crayon Physics Deluxe Temps & Cache*] LangSecRef=3023 DetectFile1=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe Default=False FileKey1=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe\data\recordings\temp|*.tmp FileKey2=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe\cache|*.* FileKey3=%AppData%\Crayon Physics Deluxe|log.txt Edited November 9, 2011 by nodles Link to comment Share on other sites More sharing options...
Alan_B Posted November 7, 2011 Share Posted November 7, 2011 I also tried using wildcards (e.g. DetectFile2=%UserProfile%\jagexcache*) to detect folders jagexcache, jagexcache1 etc. but it didn't work. [Jagex Cache*] LangSecRef=3023 DetectFile=%WinDir%\.jagex_cache_32 DetectFile2=%UserProfile%\jagexcache Default=False FileKey1=%WinDir%\.jagex_cache_32|*.*|REMOVESELF FileKey2=%UserProfile%\jagexcache|*.*|REMOVESELF FileKey3=%UserProfile%\jagexcache1|*.*|REMOVESELF FileKey4=%UserProfile%|jagex__preferences3.dat FileKey5=%UserProfile%|jagex_cl_runescape_LIVE.dat FileKey6=%UserProfile%|jagex_cl_runescape_LIVE1.dat FileKey7=%UserProfile%|jagex_runescape_preferences.dat FileKey8=%UserProfile%|jagex_runescape_preferences2.dat I am not sure , but when you clean FileKey2=%UserProfile%\jagexcache|*.*|REMOVESELF Does not this remove the folder %UserProfile%\jagexcache and after that CCleaner will fail to detect DetectFile2=%UserProfile%\jagexcache and after that CCleaner will fail to detect with the result that the following junk would no longer get removed FileKey3=%UserProfile%\jagexcache1|*.*|REMOVESELF FileKey4=%UserProfile%|jagex__preferences3.dat FileKey5=%UserProfile%|jagex_cl_runescape_LIVE.dat FileKey6=%UserProfile%|jagex_cl_runescape_LIVE1.dat FileKey7=%UserProfile%|jagex_runescape_preferences.dat FileKey8=%UserProfile%|jagex_runescape_preferences2.dat Would it not be better to remove the contents but refrain from REMOVESELF on any folder that is used any DetectFile Link to comment Share on other sites More sharing options...
nodles Posted November 7, 2011 Share Posted November 7, 2011 (edited) True, might work better that way. MODIFIED ENTRY [uTorrent More*] LangSecRef=3022 DetectFile=%ProgramFiles%\uTorrent\uTorrent.exe Default=False FileKey1=%AppData%\utorrent|*.log FileKey2=%ProgramFiles%\uTorrent|*.tmp FileKey3=%AppData%\uTorrent\ie|*.tmp Btw. (why) there's two "same" DetectFile paths: %HomeDrive% = C:\ %SystemDrive% =C:\ Edited November 7, 2011 by nodles Link to comment Share on other sites More sharing options...
nodles Posted November 8, 2011 Share Posted November 8, 2011 (edited) Hmm, this entry doesn't find anything even I have .log files in %AppData%\mIRC\Logs. Also I'd add warning-message for this entry because the logs contains mIRC chat history & mIRC must be closed before cleaning. [mIRC Logs*] LangSecRef=3022 Detect=HKCU\Software\mIRC Default=False FileKey1=%ProgramFiles%\mIRC\logs|*.* FileKey2=%AppData%\mIRC\Logs|*.* Edit. Nevermind, mIRC had to be closed to clean/detect those files. But still I suggest adding that warning there. Edited November 9, 2011 by nodles Link to comment Share on other sites More sharing options...
SMalik Posted November 8, 2011 Share Posted November 8, 2011 New Entry: CA Internet Security Suite [CA Security Center (logs)*] LangSecRef=3021 DetectFile=%ProgramFiles%\CA\CA Internet Security Suite\casc.exe Default=False FileKey1=%CommonAppData%\CA|*.log|RECURSE FileKey2=%CommonAppData%\CA|*.txt|RECURSE FileKey3=%LocalLowAppData%\CA\Consumer\APH|*.log Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 8, 2011 Author Share Posted November 8, 2011 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Miroku4444 Posted November 9, 2011 Share Posted November 9, 2011 I realize the "argument" for having it detect the .EXE file installed path as it has some logic, however the problem with that is with custom installations. For instance I absolutely never install any Freemake software into the default location because they have a COM folder which would get shared, and if using all their software (all three programs) it can really get out of wack with version issues when one program is newer than another, I've seen their setups fail multiple times because of it, or installing a new version of one of their programs makes the others unusable, and the only solution is to install each into its own unique folder. I install(&re-install) freemake video converter, and freemake audio converter in the default locations, and never had any issues. Though, i do a clean un-install of both programs when i install new version. [Freemake Audio Converter (Logs)*]LangSecRef=3023 DetectFile=C:\Program Files\Freemake\Freemake Audio Converter\FreemakeAudioConverter.exe Default=False FileKey1=%CommonAppData%\Freemake\FreemakeAudioConverter|*.txt [Freemake Video Converter (Logs)*] LangSecRef=3023 DetectFile=%ProgramFiles%\Freemake\Freemake Video Converter\FreemakeVideoConverter.exe Default=False FileKey1=%CommonAppData%\Freemake\FreemakeVideoConverter|*.txt Shouldn't Freemake Audio Converter have the % in the DetectFile line like Freemake Video Converter does? Shouldn't it be DetectFile=%ProgramFiles%, not DetectFile=C:\Program Files? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 9, 2011 Moderators Share Posted November 9, 2011 I'd say use systemdrive as homedrive might be different especially for domain users Drive letter on the local computer that is connected to the user's home directory. The drive letter to use is defined in the user's account properties within the domain. This variable is based on the value of the home directory. If the home directory is UNC, this variable will be populated with the drive letter that should be mapped to the UNC. If the home directory is a local path, this variable wil lbe populated with the drive letter of the local path. http://environmentva...title=HomeDrive ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 9, 2011 Author Share Posted November 9, 2011 Sounds about right, Nergal. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted November 9, 2011 Share Posted November 9, 2011 (edited) I'd say use systemdrive as homedrive might be different especially for domain users http://environmentva...title=HomeDrive Thanks.NEW ENTRIES [Apple Installation Temps*] LangSecRef=3023 DetectFile=%CommonAppData%\Apple Computer Default=False FileKey1=%AppData%\Apple Computer\Logs|*.* FileKey2=%CommonAppData%\Apple Computer\Installer Cache|*.*|RECURSE FileKey3=%CommonAppData%\Apple\Installer Cache|*.*|RECURSE [MS IE6 Installation Temps*] LangSecRef=3025 DetectFile=%SystemDrive% Default=False FileKey1=%SystemDrive%|msdownld.tmp [C:\ Logs*] LangSecRef=3024 DetectFile1=%SystemDrive% Default=False FileKey1=%SystemDrive%|*.log|*.txt [Adobe Acrobat 9.0 Updater Logs*] LangSecRef=3021 DetectFile1=%LocalAppData%\Adobe\Acrobat\9.0\Updater Default=False FileKey1=%LocalAppData%\Adobe\Acrobat\9.0\Updater|updater.log [skype MSI Temp*] LangSecRef=3023 DetectFile1=%CommonAppData%\Skype Default=False FileKey1=%CommonAppData%\Skype|Skype.msi|RECURSE [Avira AntiVir Logs*] LangSecRef=3024 DetectFile1=%CommonAppData%\Avira Default=False FileKey1=%CommonAppData%\Avira\AntiVir Desktop\LOGFILES|*.* [Windows ServiceProfiles\NetworkService Temps*] LangSecRef=3025 DetectFile1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp Default=False FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.txt [Windows WinSAT Logs*] LangSecRef=3025 DetectFile1=%WinDir%\Performance\WinSAT Default=False FileKey1=%WinDir%\Performance\WinSAT|winsat.log [Windows Panther Logs*] LangSecRef=3025 DetectFile1=%WinDir%\Panther Default=False FileKey1=%WinDir%\Panther|*.log [ATI Technologies Log*] LangSecRef=3024 DetectFile1=%ProgramFiles%\ATI Technologies Default=False FileKey1=%ProgramFiles%\ATI Technologies|cccutil64.txt [ATI Installation Logs*] LangSecRef=3024 DetectFile1=%SystemDrive%\ATI Default=False FileKey1=%SystemDrive%\ATI|*.*|REMOVESELF [intel Installation Logs*] LangSecRef=3024 DetectFile1=%SystemDrive%\Intel Default=False FileKey1=%SystemDrive%\Intel|*.*|REMOVESELF [Apple Installation Temps*] LangSecRef=3023 DetectFile=%CommonAppData%\Apple Computer Default=False FileKey1=%AppData%\Apple Computer\Logs|*.* FileKey2=%CommonAppData%\Apple Computer\Installer Cache|*.*|RECURSE FileKey3=%CommonAppData%\Apple\Installer Cache|*.*|RECURSE [MS IE6 Installation Temps*] LangSecRef=3025 DetectFile=%SystemDrive% Default=False FileKey1=%SystemDrive%|msdownld.tmp I could explain [C:\ Logs*] entry a bit more. I found some .log & .txt files on my Asus laptop, which indicated mainly to Asus' software logs, Adobe Reader log & MBAM error-log. Edit: Hmm somehow that entry doesn't work in winapp2.ini, but if I add it in CCleaner's include-list it works? NEW ENTRY [Windows Local AppData Temps*] LangSecRef=3025 DetectFile1=%LocalAppData%\Temp Default=False FileKey1=%LocalAppData%\Temp|*.*|RECURSE Warning=Removes everything in Temp-folder You could use this to clean entire content on the Temp-folder, not just .tmp-files like in entry [Windows Local AppData .tmp*]. Edit: Just noticed that CCleaner itself cleans whole Temp-folder already. Edited November 18, 2011 by nodles Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 9, 2011 Author Share Posted November 9, 2011 I think deleting the Apple Installer cache makes iTunes and the like very angry. At least, that's how it used to be. Can anyone confirm? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted November 9, 2011 Share Posted November 9, 2011 I think deleting the Apple Installer cache makes iTunes and the like very angry. At least, that's how it used to be. Can anyone confirm? What's the symptoms there? Though you could add warning-message to that entry. On this PC I have just Quicktime installed. But it's good if you can test and report posted entries, if I've/someone else have missed something. Link to comment Share on other sites More sharing options...
