Moderators Andavari Posted March 25, 2021 Moderators Share Posted March 25, 2021 New: New because the cleaning entry "[Intel Graphics Command Center *]" does not work since I don't have any folder named "LocalAppData%\Packages\AppUp.IntelGraphicsExperience_*" for it to detect, therefore it never cleans the Intel Graphics Command Center Service Logs which are still generated (if the service is set to automatically run). [Intel GCC SVC Logs *] LangSecRef=3021 Detect=HKLM\Software\Intel\Display FileKey1=%CommonAppData%\Intel\GCC|gcc_svc_log_*.txt -------------------------------- New: [Intel Processor Diagnostic Tool *] LangSecRef=3024 Detect=HKCU\Software\Intel Corporation\Intel Processor Diagnostic Tool 64bit FileKey1=%ProgramFiles%\Intel Corporation\Intel Processor Diagnostic Tool 64bit|*Results.txt;System_Info.txt;TestResults_Full.txt -------------------------------- It would certainly be nice if all the Intel stuff was combined into one unique area instead of using LangSecRef= which has some of it scattered and it's a bit of a pain to find all of it in a quick enough fashion. Something I could do on my end for my system alone but I though sharing the ideal may help others too. I'd prefer it to be in for example: Section=Intel Link to comment Share on other sites More sharing options...
APMichael Posted March 25, 2021 Share Posted March 25, 2021 Thanks for the new entries. 7 hours ago, Andavari said: ... New because the cleaning entry "[Intel Graphics Command Center *]" does not work since I don't have any folder named "LocalAppData%\Packages\AppUp.IntelGraphicsExperience_*" for it to detect, therefore it never cleans the Intel Graphics Command Center Service Logs which are still generated (if the service is set to automatically run). ... Ok, then the graphics driver seems to always install the GCC service, no matter if the "Metro App"-based settings GUI gets installed or not. 7 hours ago, Andavari said: ... It would certainly be nice if all the Intel stuff was combined into one unique area instead of using LangSecRef= which has some of it scattered and it's a bit of a pain to find all of it in a quick enough fashion. Something I could do on my end for my system alone but I though sharing the ideal may help others too. I'd prefer it to be in for example: Section=Intel ... In my humble opinion, we should stick with the LangSecRefs specified by CCleaner for Winapp2.ini. Introducing special sections for different manufacturers (Intel, AMD, Adobe, Cyberlink, ...) would only make the display in CCleaner more confusing. The entries in the Winapp2.ini file are sorted alphabetically, so that you have at least in this all entries of a manufacturer together. Link to comment Share on other sites More sharing options...
APMichael Posted March 29, 2021 Share Posted March 29, 2021 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/7d499d570f1c17a2e43c91190215c047fc729ac1 Link to comment Share on other sites More sharing options...
siliconman01 Posted April 2, 2021 Share Posted April 2, 2021 Does anyone else who runs MS Edge Chromium browser and winapp2.ini in CCleaner see this update error in MS Edge (see pic)? It occurs on all my systems (all use Edge, CCleaner, Winapp2.ini) and each time I check for an Edge update via ABOUT. Please note that Edge's automatic update does not work on any of my systems. I've searched for months to find a fix but have been unsuccessful. My suspicion is that CCleaner is deleting a needed parameter. Once the error occurs, all I do to "fix" it is to run ABOUT again and the update completes. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 3, 2021 Moderators Share Posted April 3, 2021 I don't get that Edge Chromium error as seen in your screenshot and I use the winapp2.ini cleaning entries from here in CCleaner, and also what's included in BleachBit and I'm not getting any corruption. From what I know corruption happens if it's closed improperly by forcing it to close such as via Task Manager, or if a cleaning tool could possibly improperly close it. Link to comment Share on other sites More sharing options...
APMichael Posted April 3, 2021 Share Posted April 3, 2021 The entry [Edge Update *] removes cached installation files, however I have never had problems with this on my systems. [Edge Update *] ... FileKey4=%ProgramFiles%\Microsoft\EdgeUpdate\Download|*.*|RECURSE FileKey5=%ProgramFiles%\Microsoft\EdgeUpdate\Install|*.*|RECURSE Is it possible that you are using the Winapp3.ini entry [Edge Installer *]? This is known to cause the problem you describe. [Edge Installer *] ... FileKey2=%ProgramFiles%\Microsoft\Edge*\Application\*\Installer|*.7z Link to comment Share on other sites More sharing options...
siliconman01 Posted April 3, 2021 Share Posted April 3, 2021 52 minutes ago, APMichael said: The entry [Edge Update *] removes cached installation files, however I have never had problems with this on my systems. [Edge Update *] ... FileKey4=%ProgramFiles%\Microsoft\EdgeUpdate\Download|*.*|RECURSE FileKey5=%ProgramFiles%\Microsoft\EdgeUpdate\Install|*.*|RECURSE Is it possible that you are using the Winapp3.ini entry [Edge Installer *]? This is known to cause the problem you describe. [Edge Installer *] ... FileKey2=%ProgramFiles%\Microsoft\Edge*\Application\*\Installer|*.7z Thanks for the feedback. I do not use winapp3.ini. One thing I'm testing now is that I have signed into my MS account via MS Edge. I typically run only with a local account on Windows 10x64 Pro and also Edge. I have to wait for the next Edge update to see if that is/was the problem. Would please post the code for [Edge Installer *] in winapp3,ini. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 3, 2021 Share Posted April 3, 2021 I also only ever use local accounts. This is the complete Winapp3.ini entry: [Edge Installer *] Section=Dangerous Edge Chromium DetectFile=%LocalAppData%\Microsoft\Edge* Warning=This will prevent successful online updates. You will need to download the installer for a reinstallation. FileKey1=%LocalAppData%\Microsoft\Edge*\Application\*\Installer|*.7z FileKey2=%ProgramFiles%\Microsoft\Edge*\Application\*\Installer|*.7z Link to comment Share on other sites More sharing options...
siliconman01 Posted April 5, 2021 Share Posted April 5, 2021 Modified entry: [Casper *] Added Detect3 [Casper *] LangSecRef=3024 Detect1=HKCU\Software\Future Systems Solutions\Casper Detect2=HKCU\Software\Future Systems Solutions\Casper 10 Detect3=HKCU\Software\Future Systems Solutions\Casper 11 FileKey1=%CommonAppData%\Future Systems Solutions\Casper\Minidump|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted April 5, 2021 Share Posted April 5, 2021 Revised Entry Added: UserActivity.json into FileKey9 [Weather *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CLR_v4.0|*.log FileKey4=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\PRICache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Temp|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState|*.tmp;UserActivity.json FileKey10=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\Cache|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\navigationHistory|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingWeather_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe\SearchHistory Link to comment Share on other sites More sharing options...
thoste Posted April 6, 2021 Share Posted April 6, 2021 I am new to Winapp2 and tried to use it for CCLeaner. I downloaded newest winapp2ool.exe from github and put it into CCLeaner installation directory (with winapp2.ini). Then I started winapp2.ini and selected 2.Trim--->1. Run (default) to trim all unfound applications on my system from winapp2.ini file. Afterwards I started CCleaner v5.78 and inspected in Custom Clean--->Applications all remaining entries with stars Surprisingly a lot of them still appears: E.g. for Opera and Brave browser. I never installed them. So why are they NOT trimmed/removed from winapp2.ini (...and CCleaner)? Link to comment Share on other sites More sharing options...
APMichael Posted April 6, 2021 Share Posted April 6, 2021 Thanks for the modified/revised entries. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/e1d8a1adc7ba5d8727a4c3f7378116569c9091b2https://github.com/MoscaDotTo/Winapp2/commit/26cc78022b3c8f2dc81ae1fb73441cd8cdbda299 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/6923d56a2484d251220193548f6e0be56b7a48f1 Link to comment Share on other sites More sharing options...
APMichael Posted April 6, 2021 Share Posted April 6, 2021 4 hours ago, thoste said: ... E.g. for Opera and Brave browser. I never installed them. So why are they NOT trimmed/removed from winapp2.ini (...and CCleaner)? Do you have a browser-independent download manager installed? These sometimes make entries in the registry, even though the corresponding browsers have not been installed. These unwanted registry entries must then be removed manually.Brave: HKEY_CURRENT_USER\Software\BraveSoftwareOpera: HKEY_CURRENT_USER\Software\Opera Software Link to comment Share on other sites More sharing options...
siliconman01 Posted April 15, 2021 Share Posted April 15, 2021 Modified Entry: [CyberLink PowerDVD *] Added Detect8, RegKey21 thru RegKey25 [CyberLink PowerDVD *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDVD14 Detect2=HKCU\Software\CyberLink\PowerDVD15 Detect3=HKCU\Software\CyberLink\PowerDVD16 Detect4=HKCU\Software\CyberLink\PowerDVD17 Detect5=HKCU\Software\CyberLink\PowerDVD18 Detect6=HKCU\Software\CyberLink\PowerDVD19 Detect7=HKCU\Software\CyberLink\PowerDVD20 Detect8=HKCU\Software\CyberLink\PowerDVD21 FileKey1=%CommonAppData%\Cyberlink\Evoparser|*.xml FileKey2=%CommonAppData%\SUPPORTDIR\*|*.log FileKey3=%LocalAppData%\Cyberlink\DigitalHome|*.log|RECURSE FileKey4=%LocalAppData%\Cyberlink\PowerDVD*|*.log|RECURSE FileKey5=%LocalAppData%\Cyberlink\PowerDVD*\*\PowerDVDMainAP|*.*|RECURSE FileKey6=%LocalAppData%\Cyberlink\PowerDVD*\cache*|*.*|RECURSE FileKey7=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser|*.*|RECURSE FileKey8=%LocalAppData%\Cyberlink\PowerDVD*\DB*\computer|*.db|RECURSE FileKey9=%LocalAppData%\Cyberlink\PowerDVD*\DefaultMember|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey3=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey6=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey9=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey12=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey13=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey14=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey15=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey16=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey17=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey18=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey19=HKCU\Software\CyberLink\PowerDVD20\CoarseSnapshot\MediaObj\MediaCache5\Data5 RegKey20=HKCU\Software\CyberLink\PowerDVD20\CoarseSnapshot\MediaObj\MediaCache5\ProgramInfo RegKey21=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey22=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey23=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey24=HKCU\Software\CyberLink\PowerDVD21\CoarseSnapshot\MediaObj\MediaCache5\Data5 RegKey25=HKCU\Software\CyberLink\PowerDVD21\CoarseSnapshot\MediaObj\MediaCache5\ProgramInfo Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 19, 2021 Share Posted April 19, 2021 Thanks for the modified entry. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/54a860636666e799772ff6d29eba44911694fe35 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 19, 2021 Moderators Share Posted April 19, 2021 On 02/04/2021 at 08:04, siliconman01 said: Does anyone else who runs MS Edge Chromium browser and winapp2.ini in CCleaner see this update error in MS Edge (see pic)? It occurs on all my systems (all use Edge, CCleaner, Winapp2.ini) and each time I check for an Edge update via ABOUT. Please note that Edge's automatic update does not work on any of my systems. I've searched for months to find a fix but have been unsuccessful. My suspicion is that CCleaner is deleting a needed parameter. Once the error occurs, all I do to "fix" it is to run ABOUT again and the update completes. I got same error last week when I was still on Win10 Home v1909, it wouldn't update at all due to corruption but I didn't bother because I soon upgraded to Win10 Home v20H2. I also got a similar error in Win10 Home v20H2 when Edge Chromium had an update, but on that occasion it had some text stating to try again in a few hours or something along those lines. I simply rebooted, tried again, and it installed without any issue. Note that I use that Edge Update cleaner, however I don't know if it's causing the issue or not. Perhaps it needs to be investigated and tested. Link to comment Share on other sites More sharing options...
APMichael Posted April 26, 2021 Share Posted April 26, 2021 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/411229e7d16233ff7ed3762eb24b593a2870c2ac Link to comment Share on other sites More sharing options...
siliconman01 Posted April 27, 2021 Share Posted April 27, 2021 New entry: [Folder Size Log *] [Folder Size Log *] LangSecRef=3024 DetectFile=%ProgramFiles%\Folder Size\FolderSize.exe FileKey1=%CommonAppData%\MindGems\FolderSize|FolderSizeLog.txt Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted May 3, 2021 Share Posted May 3, 2021 Thanks for the new entry. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/8b236de65739a5ddf7b52151b5710547de8ce449 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 5, 2021 Moderators Share Posted May 5, 2021 Added: FileKey5 Added because of a Windows Defender bug, in accordance to this topic:https://community.ccleaner.com/topic/60418-windows-defender-bug-may-fill-your-hard-drive-with-thousands-of-files/ [Windows Defender *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows Defender FileKey1=%CommonAppData%\Microsoft\Windows Defender\Network Inspection System\Support|*.txt;NisLog.txt.bak FileKey2=%CommonAppData%\Microsoft\Windows Defender\Scans\BackupStore|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Windows Defender\Scans\History\CacheManager|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Windows Defender\Scans\History\Service|*.logFileKey5=%CommonAppData%\Microsoft\Windows Defender\Scans\History\Store|*.* FileKey6=%CommonAppData%\Microsoft\Windows Defender\Scans\MetaStore|*.*|RECURSE FileKey7=%CommonAppData%\Microsoft\Windows Defender\Scans\RtSigs\Data|*.*|RECURSE FileKey8=%CommonAppData%\Microsoft\Windows Defender\Support|*.*|RECURSE Link to comment Share on other sites More sharing options...
wiggletiggle475 Posted May 7, 2021 Share Posted May 7, 2021 On 01/09/2014 at 05:57, back_track said: but ther are never come into the normal winapp2.ini I collect so entries from this forum threat^^ and collect a bad list...... https://www.dropbox.com/s/tu0yc4dt10hy6ds/Winsys2.ini?dl=0 I was sad to come back and see this deleted after so long, so here's a copy I've had backed up for a while now in case anyone is looking for this in the future: Winsys2.ini Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 7, 2021 Author Share Posted May 7, 2021 1 hour ago, wiggletiggle475 said: I was sad to come back and see this deleted after so long, so here's a copy I've had backed up for a while now in case anyone is looking for this in the future: Winsys2.ini 133.27 kB · 1 download At a glance, I think much of what this file includes is in winapp3.ini now winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted May 10, 2021 Share Posted May 10, 2021 Thanks for the revised entry. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/8933000e1442fdbd6c131ff88bbf728e5450abb2 Link to comment Share on other sites More sharing options...
SMalik Posted May 17, 2021 Share Posted May 17, 2021 Revised Entry Subscriptions Activity History Added: RegKey1 [Content Delivery Manager *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy FileKey1=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\Favicons|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\MobilityExperience\ImageCache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\OneSettingsResponseCache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\TargetedContentCache|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\TempState|*.*|RECURSE RegKey1=HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\ContentDeliveryManager\Subscriptions Link to comment Share on other sites More sharing options...
SMalik Posted May 17, 2021 Share Posted May 17, 2021 New Entry [Edge Website Redirecting Statistics *] LangSecRef=3006 DetectFile=%LocalAppData%\Microsoft\Edge* FileKey1=%LocalAppData%\Microsoft\Edge*\User Data\*|load_statistics.db;load_statistics.db-shm;load_statistics.db-wal Link to comment Share on other sites More sharing options...
