SMalik Posted January 10, 2019 Share Posted January 10, 2019 @APMichael Regarding the [Sharing MFU *] entry, I have checked a few Windows 10 systems and "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SharingMFU" is not present in the registry. Link to comment Share on other sites More sharing options...
SMalik Posted January 10, 2019 Share Posted January 10, 2019 Revised Entry Added: %LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE [Paint 3D *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MSPaint_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.MSPaint_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.MSPaint_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted January 11, 2019 Share Posted January 11, 2019 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/e724fbf81d16463c74dea387fc00fc575bd0e38f Link to comment Share on other sites More sharing options...
SMalik Posted January 12, 2019 Share Posted January 12, 2019 Revised Entry It is safe to delete all files from the Backup folder. These are just cached files. ShareX uses original .json files from "%Documents%\ShareX". Changed DetectFile from "%Documents%\ShareX" to "%ProgramFiles%\ShareX" because ShareX Microsoft Store app also uses "%Documents%\ShareX" location to store files. [ShareX *] LangSecRef=3021 DetectFile=%ProgramFiles%\ShareX Default=False FileKey1=%Documents%\ShareX\Backup|*.*|RECURSE FileKey2=%Documents%\ShareX|History.xml FileKey3=%Documents%\ShareX\Logs|*.*|RECURSE New Entry [ShareX App *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\19568ShareX.ShareX_egrzcvs15399j Default=False FileKey1=%Documents%\ShareX\Backup|*.*|RECURSE FileKey2=%Documents%\ShareX|History.xml FileKey3=%Documents%\ShareX\Logs|*.*|RECURSE FileKey4=%LocalAppData%\Packages\19568ShareX.ShareX_*\AC\INet*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\19568ShareX.ShareX_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\19568ShareX.ShareX_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\19568ShareX.ShareX_*\LocalState\Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\19568ShareX.ShareX_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted January 12, 2019 Share Posted January 12, 2019 Revised entries: I think we can remove DetectOS if we correct the Detect paths. They only exist on the matching Windows versions. [Action Center *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center ... [Security and Maintenance *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Security and Maintenance ... After some tests I am sure that the FileKey "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE" belongs to the entry [Notifications *]. You can test it for yourself: Just safely remove a USB drive. While you can see the notification, a file appears in the folder "ActionCenterCache". The file caches the icon. (In addition, the folder does not exist under Windows 7 and 8. And Microsoft itself calls the notification icon in the lower right corner of Windows 10 the action center icon.) https://support.microsoft.com/en-us/help/4028116/windows-10-find-action-center-in-windows-10 Link to comment Share on other sites More sharing options...
SMalik Posted January 12, 2019 Share Posted January 12, 2019 22 hours ago, APMichael said: Revised entries: I think we can remove DetectOS if we correct the Detect paths. They only exist on the matching Windows versions. [Action Center *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center ... [Security and Maintenance *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Security and Maintenance ... After some tests I am sure that the FileKey "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE" belongs to the entry [Notifications *]. You can test it for yourself: Just safely remove a USB drive. While you can see the notification, a file appears in the folder "ActionCenterCache". The file caches the icon. (In addition, the folder does not exist under Windows 7 and 8. And Microsoft itself calls the notification icon in the lower right corner of Windows 10 the action center icon.) https://support.microsoft.com/en-us/help/4028116/windows-10-find-action-center-in-windows-10 You're right. The [Notifications *] entry has nothing to do with notifications. This entry should be removed completely. I just opened %LocalAppData%\Microsoft\Windows\Notifications\wpnidm, and it has .jpg files that belongs to Microsoft Store apps. Then, I opened wpndatabase.db from %LocalAppData%\Microsoft\Windows\Notifications\wpnidm, and it has information about Microsoft Store apps. I then opened HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm, and it has information about the Microsoft Store apps that are listed in wpndatabase.db Link to comment Share on other sites More sharing options...
APMichael Posted January 13, 2019 Share Posted January 13, 2019 Thanks for your reply. But I think the entry [Notifications *] is correct after all: I opened the wpndatabase.db you mentioned, scrolled through it and was shocked because I found many snippets of old emails at the end of the file. The wpndatabase.db-wal also contains many snippets of emails. These are traces of email notifications from Outlook. Wow, what a privacy risk! The wpndatabase.db-wal is also updated after new notifications from Outlook: Therefore I think that the entry [Notifications *] should remain and we should add the FileKey "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE". Unfortunately, the wpndatabase.db files are locked by a service and cannot be removed by CCleaner. (I have to remove them manually.) Link to comment Share on other sites More sharing options...
SMalik Posted January 13, 2019 Share Posted January 13, 2019 1 hour ago, APMichael said: Thanks for your reply. But I think the entry [Notifications *] is correct after all: I opened the wpndatabase.db you mentioned, scrolled through it and was shocked because I found many snippets of old emails at the end of the file. The wpndatabase.db-wal also contains many snippets of emails. These are traces of email notifications from Outlook. Wow, what a privacy risk! The wpndatabase.db-wal is also updated after new notifications from Outlook: Therefore I think that the entry [Notifications *] should remain and we should add the FileKey "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE". Unfortunately, the wpndatabase.db files are locked by a service and cannot be removed by CCleaner. (I have to remove them manually.) Then I think we should change its name to Push Notifications. By the way, whenever I delete wpndatabase.db file, LiveTile stop working on Microsoft Store apps, but I think we should add this back in the entry since it holds sensitive stuff. Link to comment Share on other sites More sharing options...
SMalik Posted January 13, 2019 Share Posted January 13, 2019 @APMichael Have you seen my two posts above with images? I want to delete the images. Link to comment Share on other sites More sharing options...
SMalik Posted January 13, 2019 Share Posted January 13, 2019 Revised Entry Changed name from [Notifications *] to [Push Notifications *] Added *.db, *.db-shm and *.db-wal file extensions in FileKey1 [Push Notifications *] DetectOS=10.0| LangSecRef=3025 Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Notifications|*.db; *.db-shm;*.db-wal;*.tmp FileKey2=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey4=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm Link to comment Share on other sites More sharing options...
APMichael Posted January 13, 2019 Share Posted January 13, 2019 1 hour ago, SMalik said: ... By the way, whenever I delete wpndatabase.db file, LiveTile stop working on Microsoft Store apps, but I think we should add this back in the entry since it holds sensitive stuff. Yes, now I remember that you wrote the issue with the LiveTiles a few weeks ago. And yes, adding the .db files back shouldn't be a problem as they can only be deleted in Safe Mode. 1 hour ago, SMalik said: Revised Entry Changed name from [Notifications *] to [Push Notifications *] Added *.db, *.db-shm and *.db-wal file extensions in FileKey1 ... Is it okay with you if I add the FileKey "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE"? I think the FileKey fits much better in this entry than in the entry [Security and Maintenance *]. 1 hour ago, SMalik said: Have you seen my two posts above with images? I want to delete the images. Yes, thanks for the screenshots. You can remove them as you like. Link to comment Share on other sites More sharing options...
SMalik Posted January 13, 2019 Share Posted January 13, 2019 Revised Entries Changed the name from [Sound Recorder *] to [Voice Recorder *] [Voice Recorder *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsSoundRecorder_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\LocalState\Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.WindowsSoundRecorder_*\TempState|*.*|RECURSE Changed FileKey9=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalCache\PlayReady\Cache|*.*|RECURSE with FileKey9=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalCache\PlayReady|*.*|RECURSE [Groove Music *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneMusic_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.ZuneMusic_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\PRICache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Temp|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalCache\PlayReady|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\Database\*|*.log FileKey11=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageCache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageRetrievalFailure|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageStore|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\navigationHistory|*.*|RECURSE FileKey15=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\PlayReady|*.*|RECURSE FileKey16=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneMusic_8wekyb3d8bbwe\SearchHistory Changed FileKey9=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalCache\PlayReady\Cache|*.*|RECURSE with FileKey9=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalCache\PlayReady|*.*|RECURSE [Movies & TV *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneVideo_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe* Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\PRICache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Temp|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalCache\PlayReady|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\Database\anonymous|*.log FileKey11=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageCache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageRetrievalFailure|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageStore|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\navigationHistory|*.*|RECURSE FileKey15=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\PlayReady|*.*|RECURSE FileKey16=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneVideo_8wekyb3d8bbwe\SearchHistory\SearchHistory Link to comment Share on other sites More sharing options...
SMalik Posted January 13, 2019 Share Posted January 13, 2019 New Entries [3DViewer *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Microsoft3DViewer_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\LocalState\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Microsoft3DViewer_*\TempState|*.*|RECURSE [Alarms *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsAlarms_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalState\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\TempState|*.*|RECURSE [Calculator *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsCalculator_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\LocalState\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsCalculator_*\TempState|*.*|RECURSE [Get Help *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.GetHelp_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.GetHelp_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.GetHelp_*\LocalState\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.GetHelp_*\TempState|*.*|RECURSE [Mixed Reality Portal *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MixedReality.Portal_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\LocalState\Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.MixedReality.Portal_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted January 14, 2019 Share Posted January 14, 2019 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/305e8499386c1bc865c30ce2127ba9f53ff16217 Link to comment Share on other sites More sharing options...
SMalik Posted January 14, 2019 Share Posted January 14, 2019 2 hours ago, APMichael said: Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/305e8499386c1bc865c30ce2127ba9f53ff16217 Push Notifications belong to Microsoft Store apps. Action Center Notifications are different. We should have this "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE" in [Action Center *] and [Security and Maintenance *] entries. It should not be in the [Push Notifications *] entry. Link to comment Share on other sites More sharing options...
APMichael Posted January 14, 2019 Share Posted January 14, 2019 4 hours ago, SMalik said: Push Notifications belong to Microsoft Store apps. Action Center Notifications are different. We should have this "%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE" in [Action Center *] and [Security and Maintenance *] entries. It should not be in the [Push Notifications *] entry. As I wrote in one of my last posts the folder is only for the new Windows 10 action center (= notifications and quick actions). The folder does not exist under Windows 7/8 and Security and Maintenance is also just the old Windows 7/8 action center. Therefore, the folder cannot belong to the entries [Action Center *] or [Security and Maintenance *]. BTW in my wpndatabase.db are also traces of common programs (e.g. system image program), so it is not limited to Microsoft Store apps. And missed (push) notifications are stored in the new Windows 10 action center, so notifications and the new Windows 10 action center go together. I don't think a separate Windows 10 action center entry is really necessary. Edit: I found the registry key for the new Windows 10 action center: "HKLM\Software\Microsoft\Windows\CurrentVersion\ActionCenter". With this key we could make a separate entry. A suggestion for the name of the entry: [Notifications and Action Center *], because that's what Microsoft calls it in the Group Policy Editor. (And "Action Center" is blocked by the old entry for Windows 7/8.) Link to comment Share on other sites More sharing options...
SMalik Posted January 14, 2019 Share Posted January 14, 2019 5 hours ago, APMichael said: As I wrote in one of my last posts the folder is only for the new Windows 10 action center (= notifications and quick actions). The folder does not exist under Windows 7/8 and Security and Maintenance is also just the old Windows 7/8 action center. Therefore, the folder cannot belong to the entries [Action Center *] or [Security and Maintenance *]. BTW in my wpndatabase.db are also traces of common programs (e.g. system image program), so it is not limited to Microsoft Store apps. And missed (push) notifications are stored in the new Windows 10 action center, so notifications and the new Windows 10 action center go together. I don't think a separate Windows 10 action center entry is really necessary. Edit: I found the registry key for the new Windows 10 action center: "HKLM\Software\Microsoft\Windows\CurrentVersion\ActionCenter". With this key we could make a separate entry. A suggestion for the name of the entry: [Notifications and Action Center *], because that's what Microsoft calls it in the Group Policy Editor. (And "Action Center" is blocked by the old entry for Windows 7/8.) You're wrong on this one. "%LocalAppData%\Microsoft\Windows\ActionCenterCache" has nothing to do with Push Notifications. This should go with [Action Center *] and [Security and Maintenance *] entries. Open Event Viewer Go to Applications and Services Logs> Microsoft> Windows> PushNotifications-Platform> Operational, and check the logs. Link to comment Share on other sites More sharing options...
SMalik Posted January 14, 2019 Share Posted January 14, 2019 Here are my suggestions. [Notifications *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Providers\EventLog RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Security and Maintenance\Providers\EventLog [Push Notifications *] DetectOS=10.0| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Notifications|*.db;*.db-shm;*.db-wal;*.tmp FileKey2=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey4=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 15, 2019 Moderators Share Posted January 15, 2019 2 hours ago, SMalik said: Here are my suggestions. [Notifications *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Providers\EventLog RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Security and Maintenance\Providers\EventLog [Push Notifications *] DetectOS=10.0| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Notifications|*.db;*.db-shm;*.db-wal;*.tmp FileKey2=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey4=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm Both of those would show no matter what os is used, is that on purpose? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2019 Share Posted January 15, 2019 3 hours ago, Nergal said: Both of those would show no matter what os is used, is that on purpose? [Notifications *] entry works on all OS. [Push Notifications *] is for Windows 10 only, other OS don’t need it. Link to comment Share on other sites More sharing options...
APMichael Posted January 15, 2019 Share Posted January 15, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/aa5bf4a072e39e005fbaa7b1a47a0e517931c6ebhttps://github.com/MoscaDotTo/Winapp2/commit/c0d8e26518ef6b17db297b249971a7ee3d38b223 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 15, 2019 Moderators Share Posted January 15, 2019 13 hours ago, SMalik said: [Notifications *] entry works on all OS. [Push Notifications *] is for Windows 10 only, other OS don’t need it. Oh guess I missed the detect os on the entry, sorry for misreading ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2019 Share Posted January 15, 2019 New Entry [Delivery Optimization Service *] DetectOS=10.0| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\DeliveryOptimization\Cache|*.*|RECURSE FileKey2=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\DeliveryOptimization\Logs|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2019 Share Posted January 15, 2019 Revised Entry Added: RegKey1 & RegKey2 [Snip & Sketch *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.ScreenSketch_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\LocalCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\LocalState\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe\PersistedPickerData\Microsoft.ScreenSketch_8wekyb3d8bbwe!App\AppSnipAndSketchFileSaveSettings|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe\PersistedPickerData\Microsoft.ScreenSketch_8wekyb3d8bbwe!App\DefaultOpenFileSingle|LastLocation Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2019 Share Posted January 15, 2019 Revised Entry Added: %AppData%\Foxit Software\Foxit PhantomPDF\StartPage\*\Start\en-US|index.html [Foxit PhantomPDF *] LangSecRef=3021 Detect1=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0 Detect2=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0 Detect3=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0 Detect4=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0 Default=False FileKey1=%AppData%\Foxit Software\Foxit PDF Creator\Creator-Log|*.*|RECURSE FileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.ds FileKey3=%AppData%\Foxit Software\Foxit PhantomPDF\StartPage\*\Start\en-US|index.html FileKey4=%AppData%\Foxit Software\RMS|FXRMS_Log.txt FileKey5=%LocalAppData%\Foxit PhantomPDF\msilog|*.log FileKey6=%WinDir%\System32\config\systemprofile\AppData\Roaming\Foxit Software\Foxit PDF Creator|*__foxittemp.xml|RECURSE RegKey1=HKCU\Software\Foxit Software Company\Foxit PDF Editor|Recent File List RegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Preferences\History RegKey3=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\RecentFiles RegKey4=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\File MRU RegKey5=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\Place MRU RegKey6=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\plugins\JSPlugins RegKey7=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Preferences\History RegKey8=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Recent File List RegKey9=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\CommentPanel\Filter RegKey10=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Foxit PhantomPDF Advanced Editor\Recent File List RegKey11=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\MRU\File MRU RegKey12=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\MRU\Place MRU RegKey13=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\plugins\JSPlugins RegKey14=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Preferences\History RegKey15=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Recent File List RegKey16=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\CommentPanel\Filter RegKey17=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\Foxit PhantomPDF Advanced Editor\Recent File List RegKey18=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\MRU\File MRU RegKey19=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\MRU\Place MRU RegKey20=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\plugins\JSPlugins RegKey21=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\Preferences\History RegKey22=HKCU\Software\Foxit Software\Foxit PhantomPDF 9.0\Recent File List Link to comment Share on other sites More sharing options...
