SMalik Posted December 31, 2018 Share Posted December 31, 2018 Revised Entry In version 9, program's name was changed to Camtasia.https://support.techsmith.com/hc/en-us/articles/115006443267-Camtasia-Windows-Version-History Changed the entry name from [Camtasia Studio 9 *] to [Camtasia *] and added support for Camtasia 2018. Changed LangSecRef from 3024 to 3023. [Camtasia *] LangSecRef=3023 Detect=HKCU\Software\TechSmith\Camtasia Studio Default=False FileKey1=%CommonAppData%\TechSmith\Camtasia Studio *\Library *\Temp|*.*|RECURSE FileKey2=%LocalAppData%\TechSmith\Camtasia Studio\*\Trackerbird_Files|tblog.log FileKey3=%LocalAppData%\TechSmith\Logs|*.*|RECURSE FileKey4=%AppData%\TechSmith\CamtasiaStudio\Logs|*.*|RECURSE RegKey1=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Recorder\9.0\General|lstLastSaveDir RegKey2=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Studio\9.0|ExportAsZipMru RegKey3=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Studio\9.0|FileSaveAsMru RegKey4=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Studio\9.0|MRUImportFolder RegKey5=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Studio\9.0|MRUOpenProjectFolder RegKey6=HKCU\Software\TechSmith\Camtasia Studio\9.0\Camtasia Studio\9.0|RecentRecordingsMru RegKey7=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Recorder\18.0\General|lstLastSaveDir RegKey8=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Studio\18.0|ExportAsZipMru RegKey9=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Studio\18.0|FileSaveAsMru RegKey10=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Studio\18.0|MRUImportFolder RegKey11=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Studio\18.0|MRUOpenProjectFolder RegKey12=HKCU\Software\TechSmith\Camtasia Studio\18.0\Camtasia Studio\18.0|RecentRecordingsMru Link to comment Share on other sites More sharing options...
SMalik Posted December 31, 2018 Share Posted December 31, 2018 14 hours ago, APMichael said: Question: Piriform has removed the font cache entry from CCleaner because it could cause a boot problem (if fast startup is enabled). Should we add the FileKeys of this entry to Winapp2.ini? [Font Cache] FileKey1=%WinDir%\System32|FNTCACHE.DAT FileKey2=%LocalAppData%|GDIPFONTCACHEV1.DAT FileKey3=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache*.dat It seems that FileKey1 is causing the problem, so we could remove it: https://forum.piriform.com/topic/52857-version-540/?tab=comments#comment-300971 I have a Windows 10 (1809) 64-bit system. I have fast startup enabled. I always delete FNTCACHE.DAT, never had any issue. I think we should add this in Winapp2.ini Link to comment Share on other sites More sharing options...
siliconman01 Posted December 31, 2018 Share Posted December 31, 2018 17 hours ago, APMichael said: Thank you for your modified entry. Wouldn't it be possible to use "log*.txt"? Or are there any important "log*.txt" files? Yes, it does appear that "log*.txt" would work. The files "NvFBCPlugin|logError.txt, LogNvFBCPlugin.txt, LogPluginError.txt" are the only files that show up in this folder on my systems. However, I do not use a LOT of the capabilities of the Nvidia software because I am not a gamer. So I played it "safe" by cleaning only the files listed. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 31, 2018 Share Posted December 31, 2018 18 hours ago, APMichael said: Question: Piriform has removed the font cache entry from CCleaner because it could cause a boot problem (if fast startup is enabled). Should we add the FileKeys of this entry to Winapp2.ini? [Font Cache] FileKey1=%WinDir%\System32|FNTCACHE.DAT FileKey2=%LocalAppData%|GDIPFONTCACHEV1.DAT FileKey3=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache*.dat It seems that FileKey1 is causing the problem, so we could remove it: https://forum.piriform.com/topic/52857-version-540/?tab=comments#comment-300971 So you are suggesting that the code be....which looks good to me for Winapp2.ini. It does look like there is a "permissions" issue, however, that prevents CCleaner from actually cleaning out these files. [Font Cache *] FileKey2=%LocalAppData%|GDIPFONTCACHEV1.DAT FileKey3=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache*.dat Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 31, 2018 Moderators Share Posted December 31, 2018 Why risk cleaning the Font cache at all? Link to comment Share on other sites More sharing options...
APMichael Posted December 31, 2018 Share Posted December 31, 2018 6 hours ago, siliconman01 said: So you are suggesting that the code be....which looks good to me for Winapp2.ini. It does look like there is a "permissions" issue, however, that prevents CCleaner from actually cleaning out these files. Strange! On my systems CCleaner removes all font cache files without any permission issues. 4 hours ago, Andavari said: Why risk cleaning the Font cache at all? IMHO it is not riskier than cleaning other Windows related caches, as we will never know what Microsoft will change with the next feature update. Like SMalik, I never had any issues after cleaning the font cache. And I don't think anyone knows the correlations why the FileKey1 caused the boot issue on some systems. Link to comment Share on other sites More sharing options...
APMichael Posted December 31, 2018 Share Posted December 31, 2018 Many thanks for all the replies and the revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/ffcdd07e5fcf30b773dd144372ba8b35c0786852 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/3fa0712f357afaba2c1d665fa540255c410f7183 Happy New Year! Link to comment Share on other sites More sharing options...
SMalik Posted January 1, 2019 Share Posted January 1, 2019 New Entry [Game bar *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxGamingOverlay_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxGamingOverlay_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.XboxGamingOverlay_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.XboxGamingOverlay_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.XboxGamingOverlay_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.XboxGamingOverlay_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted January 3, 2019 Share Posted January 3, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/049566c47c4edb16f96ffa6fabdbfa95e3780142https://github.com/MoscaDotTo/Winapp2/commit/a6ada37fc0bd5cbefc0549b7b0d2ecf28c1fdf9bhttps://github.com/MoscaDotTo/Winapp2/commit/15f4c4515b9c97e33cdb128e7a30db904ce6a17a Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/a568a9c69d1283f839beeaf851f00738e3fc2e51 Link to comment Share on other sites More sharing options...
APMichael Posted January 5, 2019 Share Posted January 5, 2019 Question: As far as I know, the servers for the following messengers were shut down some time ago: AOL Instant Messenger Windows Live Messenger Yahoo! Messenger Therefore, the programs are useless without their servers and we could remove the following entries: [AIM *] [Windows Live Messenger *] [Windows Live Messenger Chat History *] [Yahoo Messenger *] [Yahoo Messenger Cache *] Are you okay with that? And do you know any other programs where the servers have been shut down in the meantime and the program became useless? Link to comment Share on other sites More sharing options...
SMalik Posted January 5, 2019 Share Posted January 5, 2019 Revised Entry Removed %LocalLowAppData%\Google\GoogleEarth\unified_cache_leveldb_*|*.*|REMOVESELF It is already in CCleaner's built-in entry. [Google Earth *] LangSecRef=3021 Detect1=HKCU\Software\Google\Google Earth Plus Detect2=HKCU\Software\Google\Google Earth Pro Detect3=HKLM\Software\Google\Google Earth Plus Detect4=HKLM\Software\Google\Google Earth Pro Default=False FileKey1=%ProgramFiles%\Google\GoogleEarth\client|*.log FileKey2=%LocalLowAppData%\Google\GoogleEarth|*.tmp;*.log|RECURSE FileKey3=%LocalLowAppData%\Google\GoogleEarth\Cache|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\Program Files*\Google\GoogleEarth\client|*.log Link to comment Share on other sites More sharing options...
SMalik Posted January 5, 2019 Share Posted January 5, 2019 On 1/3/2019 at 04:42, APMichael said: Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/049566c47c4edb16f96ffa6fabdbfa95e3780142 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/a568a9c69d1283f839beeaf851f00738e3fc2e51 Link to comment Share on other sites More sharing options...
APMichael Posted January 5, 2019 Share Posted January 5, 2019 23 hours ago, SMalik said: Revised Entry Removed %LocalLowAppData%\Google\GoogleEarth\unified_cache_leveldb_*|*.*|REMOVESELF It is already in CCleaner's built-in entry... Thanks! I also found and fixed that yesterday. 23 hours ago, SMalik said: ...image of the "Game bar" icon... Normally we use Proper Case (Title Case) for the names of the entries. IMHO the lower case letter "b" is not so important. Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 Revised Entry Added: %LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE [Xbox Identity Provider *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxIdentityProvider_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*|*.log FileKey4=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\NativeImages\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\UsageLogs|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalCache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 [Xbox Game Overlay *] and [Xbox Identity Provider *] are part of [Xbox *] app. They should be merged with [Xbox *] entry. [Xbox *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxApp_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState|*.log*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\*Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\DiagOutputDir|*.txt FileKey9=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\SmartGlass|*.log FileKey10=%LocalAppData%\Packages\Microsoft.XboxApp_*\TempState|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\INet*|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\Temp|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalCache\Cache|*.*|RECURSE FileKey15=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalState\Cache|*.*|RECURSE FileKey16=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalState\DiagOutputDir|*.txt FileKey17=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\TempState|*.*|RECURSE FileKey18=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INet*|*.*|RECURSE FileKey19=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey20=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*|*.log FileKey21=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\NativeImages\Temp|*.*|RECURSE FileKey22=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\UsageLogs|*.*|RECURSE FileKey23=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Temp|*.*|RECURSE FileKey24=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey25=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalCache|*.*|RECURSE FileKey26=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalState\Cache|*.*|RECURSE FileKey27=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 These packages are part of Xbox app. Microsoft.Xbox.TCUI_8wekyb3d8bbwe Microsoft.XboxApp_8wekyb3d8bbwe Microsoft.XboxGameCallableUI_cw5n1h2txyewy Microsoft.XboxGameOverlay_8wekyb3d8bbwe Microsoft.XboxIdentityProvider_8wekyb3d8bbwe Microsoft.XboxSpeechToTextOverlay_8wekyb3d8bbwe Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 New Entry [Microsoft Solitaire Collection *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftSolitaireCollection_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MicrosoftSolitaireCollection_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MicrosoftSolitaireCollection_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MicrosoftSolitaireCollection_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.MicrosoftSolitaireCollection_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MicrosoftSolitaireCollection_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted January 6, 2019 Share Posted January 6, 2019 1 hour ago, SMalik said: These packages are part of Xbox app. Microsoft.Xbox.TCUI_8wekyb3d8bbwe Microsoft.XboxApp_8wekyb3d8bbwe Microsoft.XboxGameCallableUI_cw5n1h2txyewy Microsoft.XboxGameOverlay_8wekyb3d8bbwe Microsoft.XboxIdentityProvider_8wekyb3d8bbwe Microsoft.XboxSpeechToTextOverlay_8wekyb3d8bbwe I think you mean that we should merge all the individual entries into one [Xbox *] entry, right? Do you think we can use the following FileKey for this? Otherwise the entry will be very large. FileKeyX =%LocalAppData%\Packages\Microsoft.Xbox*_*\ Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 6, 2019 Author Share Posted January 6, 2019 25 minutes ago, APMichael said: I think you mean that we should merge all the individual entries into one [Xbox *] entry, right? Do you think we can use the following FileKey for this? Otherwise the entry will be very large. FileKeyX =%LocalAppData%\Packages\Microsoft.Xbox*_*\ This would affect the "Microsoft.XboxOneSmartGlass_8wekyb3d8bbwe" package, is it part of the Xbox app too? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 31 minutes ago, APMichael said: I think you mean that we should merge all the individual entries into one [Xbox *] entry, right? Do you think we can use the following FileKey for this? Otherwise the entry will be very large. FileKeyX =%LocalAppData%\Packages\Microsoft.Xbox*_*\ Yes, we should have only one entry for Xbox. I think the following FileKey is fine. FileKeyX =%LocalAppData%\Packages\Microsoft.Xbox*_*\ Link to comment Share on other sites More sharing options...
APMichael Posted January 6, 2019 Share Posted January 6, 2019 2 hours ago, Winapp2.ini said: This would affect the "Microsoft.XboxOneSmartGlass_8wekyb3d8bbwe" package, is it part of the Xbox app too? Unfortunately, I do not know it, because I have never used Xbox apps before. Maybe SMalik can tell us? (And/or we could use an ExcludeKey for this package.) Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 7 minutes ago, Winapp2.ini said: This would affect the "Microsoft.XboxOneSmartGlass_8wekyb3d8bbwe" package, is it part of the Xbox app too? Xbox One Smart Glass is a separate app. Link to comment Share on other sites More sharing options...
APMichael Posted January 6, 2019 Share Posted January 6, 2019 9 minutes ago, SMalik said: Xbox One Smart Glass is a separate app. Okay, thanks for your reply. Then we should make a big entry, because the app "Game bar" would be affected as well. \Microsoft.Xbox*_*\ \Microsoft.XboxGamingOverlay_*\ \Microsoft.XboxOneSmartGlass_*\ Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 32 minutes ago, APMichael said: Okay, thanks for your reply. Then we should make a big entry, because the app "Game bar" would be affected as well. \Microsoft.Xbox*_*\ \Microsoft.XboxGamingOverlay_*\ \Microsoft.XboxOneSmartGlass_*\ I think you misunderstood. Xbox One Smart Glass is a separate app. Also, Game bar is a separate app. Microsoft.XboxGamingOverlay_8wekyb3d8bbwe Link to comment Share on other sites More sharing options...
SMalik Posted January 6, 2019 Share Posted January 6, 2019 Revised Entry Removed: DetectOS=6.2| Changed: LangSecRef from 3031 to 3022 [Internet Explorer Vault *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False Warning=This will clear the saved passwords in the Windows Mail App FileKey1=%LocalAppData%\Microsoft\Vault\*|*.vcrd Link to comment Share on other sites More sharing options...
