siliconman01 Posted December 8, 2018 Share Posted December 8, 2018 2 hours ago, SMalik said: Revised Entry Changed LangSecRef from 3021 to 3023 [CyberLink Media Cache *] LangSecRef=3023 Detect=HKCU\Software\CyberLink Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache\Data4 RegKey3=HKCU\Software\CyberLink\MediaCache\Thumbnail4 RegKey4=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 Should change the following Cyberlink items to " LangSecRef from 3021 to 3023", eh?? [CyberLink Install Files *] [CyberLink Downloader *] [CyberLink Crash Files *] Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted December 8, 2018 Share Posted December 8, 2018 2 hours ago, SMalik said: ... Changed LangSecRef from 3021 to 3023 [CyberLink Media Cache *] ... 24 minutes ago, siliconman01 said: Should change the following Cyberlink items to " LangSecRef from 3021 to 3023", eh?? [CyberLink Install Files *] [CyberLink Downloader *] [CyberLink Crash Files *] Yes, thanks for the hint. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 8, 2018 Author Share Posted December 8, 2018 A new winapp2ool for your consideration: https://github.com/MoscaDotTo/Winapp2/pull/318/commits/976dd4c0885ba3d47e04330b062956dc2e8f5e75 Most of the changes in this commit are code structure changes, a good chunk of refactoring is present here and the code is much nicer for it. Some more doc strings have been filled out too, though some docstrings may now be out of date due to the changes. Some small user facing changes: Diff now returns to whichever menu called it (Diff or main winapp2ool) instead of just to the main winapp2ool menu Menus are now dynamic! This means not all options will be visible at all times and some options may change depending on your choices. This is mostly where you might download winapp2.ini (enabling the download changes the local file selection option into the download non-ccleaner winapp2.ini option). Hopefully this should reduce menu clutter. I have also considered removing the non-ccleaner winapp2.ini option entirely and instead making it a toggle somewhere that applies universally across the application, since I don't imagine many people wanting to use both files during the same session. Very open to feedback on this front. A very big diff for the code can be found here: https://github.com/MoscaDotTo/Winapp2/pull/318/commits/b6d95d61b7bc15c4089dde196b123ea09c4e2c67 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted December 9, 2018 Share Posted December 9, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/10dcd9e909c93a53e196ab41f8c97028faba034c Winapp2ool.exe:https://github.com/MoscaDotTo/Winapp2/raw/976dd4c0885ba3d47e04330b062956dc2e8f5e75/Tools/beta/winapp2ool.exe Link to comment Share on other sites More sharing options...
SMalik Posted December 9, 2018 Share Posted December 9, 2018 Revised Entry Added: FileKey2 [Direct3D Shader Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\D3DSCache|*.*|RECURSE FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\D3DSCache|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted December 10, 2018 Share Posted December 10, 2018 13 hours ago, SMalik said: Revised Entry Added: FileKey2 [Direct3D Shader Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\D3DSCache|*.*|RECURSE FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\D3DSCache|*.*|RECURSE Nix my post. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 10, 2018 Share Posted December 10, 2018 Revised Entry Added: Detect11 & RegKey67 thru RegKey83 [Ashampoo Burning Studio *] LangSecRef=3021 Detect1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5 Detect2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6 Detect3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7 Detect4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8 Detect5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 12 Detect6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14 Detect7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15 Detect8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16 Detect9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18 Detect10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19 Detect11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20 Detect12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007 Detect13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2009 Detect14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016 Detect15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017 Detect16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018 Default=False FileKey1=%AppData%\Ashampoo|*.log;*.txt;*.xml|RECURSE FileKey2=%LocalAppData%\Ashampoo\BaNT|*.*|RECURSE RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\tempFiles RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\tempFiles RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Backup Project\BackupOptions|CustomLocation RegKey18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey19=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\BrowseImageFile|ImagePath RegKey20=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey21=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey22=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SelectImage|ImagePath RegKey23=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath RegKey24=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey25=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\MoviesPage|Path RegKey26=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey27=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Logs RegKey28=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles RegKey29=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Unknown Project RegKey30=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey31=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey32=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey33=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey34=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Backup Project\BackupOptions|CustomLocation RegKey35=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey36=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\BrowseImageFile|ImagePath RegKey37=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey38=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey39=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SelectImage|ImagePath RegKey40=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\DumpImage|ImagePath RegKey41=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey42=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\MoviesPage|Path RegKey43=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey44=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Logs RegKey45=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\tempFiles RegKey46=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Unknown Project RegKey47=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey48=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey49=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey50=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey51=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Backup Project\BackupOptions|CustomLocation RegKey52=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey53=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\BrowseImageFile|ImagePath RegKey54=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey55=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey56=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SelectImage|ImagePath RegKey57=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\DumpImage|ImagePath RegKey58=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey59=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\MoviesPage|Path RegKey60=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey61=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Logs RegKey62=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\tempFiles RegKey63=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Unknown Project RegKey64=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey65=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey66=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey67=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey68=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Backup Project\BackupOptions|CustomLocation RegKey69=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey70=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\BrowseImageFile|ImagePath RegKey71=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey72=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey73=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SelectImage|ImagePath RegKey74=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\DumpImage|ImagePath RegKey75=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey76=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\MoviesPage|Path RegKey77=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey78=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Logs RegKey79=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\tempFiles RegKey80=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Unknown Project RegKey81=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey82=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey83=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey84=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog RegKey85=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog RegKey86=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage RegKey87=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog RegKey88=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey89=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Backup Project\BackupOptions|CustomLocation RegKey90=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\BrowseImageFile|ImagePath RegKey91=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey92=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey93=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SelectImage|ImagePath RegKey94=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\DumpImage|ImagePath RegKey95=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey96=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Logs RegKey97=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles RegKey98=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Unknown Project RegKey99=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey100=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey101=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey102=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey103=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Backup Project\BackupOptions|CustomLocation RegKey104=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\BrowseImageFile|ImagePath RegKey105=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey106=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey107=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SelectImage|ImagePath RegKey108=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\DumpImage|ImagePath RegKey109=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey110=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Logs RegKey111=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\tempFiles RegKey112=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Unknown Project RegKey113=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey114=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey115=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey116=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey117=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Backup Project\BackupOptions|CustomLocation RegKey118=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\BrowseImageFile|ImagePath RegKey119=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey120=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey121=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SelectImage|ImagePath RegKey122=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\DumpImage|ImagePath RegKey123=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey124=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Logs RegKey125=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\tempFiles RegKey126=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Unknown Project RegKey127=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey128=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey129=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath Link to comment Share on other sites More sharing options...
APMichael Posted December 11, 2018 Share Posted December 11, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/53eae0a67dc14d67d47945bf8d82f872a527ef5f Link to comment Share on other sites More sharing options...
SMalik Posted December 12, 2018 Share Posted December 12, 2018 Revised Entry Added: Detect17 & RegKey130 thru RegKey143 [Ashampoo Burning Studio *] LangSecRef=3021 Detect1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5 Detect2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6 Detect3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7 Detect4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8 Detect5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 12 Detect6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14 Detect7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15 Detect8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16 Detect9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18 Detect10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19 Detect11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20 Detect12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007 Detect13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2009 Detect14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016 Detect15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017 Detect16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018 Detect17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019 Default=False FileKey1=%AppData%\Ashampoo|*.log;*.txt;*.xml|RECURSE FileKey2=%LocalAppData%\Ashampoo\BaNT|*.*|RECURSE RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\tempFiles RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\tempFiles RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Backup Project\BackupOptions|CustomLocation RegKey18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey19=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\BrowseImageFile|ImagePath RegKey20=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey21=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey22=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SelectImage|ImagePath RegKey23=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath RegKey24=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey25=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\MoviesPage|Path RegKey26=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey27=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Logs RegKey28=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles RegKey29=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Unknown Project RegKey30=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey31=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey32=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey33=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey34=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Backup Project\BackupOptions|CustomLocation RegKey35=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey36=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\BrowseImageFile|ImagePath RegKey37=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey38=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey39=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SelectImage|ImagePath RegKey40=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\DumpImage|ImagePath RegKey41=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey42=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\MoviesPage|Path RegKey43=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey44=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Logs RegKey45=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\tempFiles RegKey46=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Unknown Project RegKey47=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey48=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey49=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey50=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey51=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Backup Project\BackupOptions|CustomLocation RegKey52=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey53=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\BrowseImageFile|ImagePath RegKey54=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey55=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey56=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SelectImage|ImagePath RegKey57=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\DumpImage|ImagePath RegKey58=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey59=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\MoviesPage|Path RegKey60=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey61=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Logs RegKey62=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\tempFiles RegKey63=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Unknown Project RegKey64=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey65=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey66=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey67=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey68=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Backup Project\BackupOptions|CustomLocation RegKey69=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey70=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\BrowseImageFile|ImagePath RegKey71=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey72=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey73=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SelectImage|ImagePath RegKey74=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\DumpImage|ImagePath RegKey75=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey76=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\MoviesPage|Path RegKey77=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey78=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Logs RegKey79=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\tempFiles RegKey80=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Unknown Project RegKey81=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey82=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey83=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey84=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog RegKey85=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog RegKey86=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage RegKey87=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog RegKey88=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey89=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Backup Project\BackupOptions|CustomLocation RegKey90=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\BrowseImageFile|ImagePath RegKey91=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey92=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey93=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SelectImage|ImagePath RegKey94=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\DumpImage|ImagePath RegKey95=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey96=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Logs RegKey97=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles RegKey98=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Unknown Project RegKey99=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey100=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey101=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey102=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey103=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Backup Project\BackupOptions|CustomLocation RegKey104=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\BrowseImageFile|ImagePath RegKey105=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey106=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey107=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SelectImage|ImagePath RegKey108=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\DumpImage|ImagePath RegKey109=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey110=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Logs RegKey111=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\tempFiles RegKey112=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Unknown Project RegKey113=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey114=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey115=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey116=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey117=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Backup Project\BackupOptions|CustomLocation RegKey118=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\BrowseImageFile|ImagePath RegKey119=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey120=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey121=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SelectImage|ImagePath RegKey122=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\DumpImage|ImagePath RegKey123=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey124=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Logs RegKey125=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\tempFiles RegKey126=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Unknown Project RegKey127=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey128=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey129=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey130=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey131=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Backup Project\BackupOptions|CustomLocation RegKey132=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\BrowseImageFile|ImagePath RegKey133=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey134=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey135=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SelectImage|ImagePath RegKey136=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\DumpImage|ImagePath RegKey137=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey138=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Logs RegKey139=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\tempFiles RegKey140=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Unknown Project RegKey141=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey142=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey143=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath Link to comment Share on other sites More sharing options...
APMichael Posted December 12, 2018 Share Posted December 12, 2018 I think we can remove the following Chrome entries, because CCleaner cleans the folders by now: [Extensions State *] [GPU Cache *] [Session Storage *] If you find more "duplicate" entries, please report them. Thanks! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 12, 2018 Moderators Share Posted December 12, 2018 2 minutes ago, APMichael said: I think we can remove the following Chrome entries, because CCleaner cleans the folders by now: I agree ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 12, 2018 Author Share Posted December 12, 2018 Off to the removed entries.ini with them! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 12, 2018 Author Share Posted December 12, 2018 I've made available a draft of a readme for winapp2ool.exe that should apply to the upcoming 1.0 release. It is not entirely accurate for 0.85 which is the current master version on the GitHub https://github.com/MoscaDotTo/Winapp2/blob/73f02f7009a1f2123194d080bed34eb4b7617cdd/winapp2ool/Readme.md winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted December 14, 2018 Share Posted December 14, 2018 Thanks for all the replies. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/bd91aff7a2103ca015c4be5637bcbeee57cedffehttps://github.com/MoscaDotTo/Winapp2/commit/abd3f9b74290796d1b117a1d3e8afb540920503b Link to comment Share on other sites More sharing options...
SMalik Posted December 14, 2018 Share Posted December 14, 2018 Revised entry Added Detect1=HKCU\Software\Microsoft\Office\11.0 Removed "\Common" from the end of the Detects Changed the order of the Filekey's Removed %LocalAppData%\Microsoft Help|*.* Removed %CommonAppData%\Microsoft\ClickToRun\ProductReleases|*.*|RECURSE I ran CCleaner and all update files were removed even before the updates were applied. This should not be in Winapp2.ini or there should be a separate entry for this with a warning. [MS Office *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\11.0 Detect2=HKCU\Software\Microsoft\Office\12.0 Detect3=HKCU\Software\Microsoft\Office\14.0 Detect4=HKCU\Software\Microsoft\Office\15.0 Detect5=HKCU\Software\Microsoft\Office\16.0 Default=False FileKey1=%SystemDrive%|propfix.log FileKey2=%LocalAppData%\Microsoft\Office\*|OneNoteOfflineCache.onecache FileKey3=%LocalAppData%\Microsoft\Office\*\OfficeFileCache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Office\OTele|*.*|RECURSE FileKey5=%LocalAppData%\Microsoft\OneNote\*|OneNoteOfflineCache.onecache FileKey6=%LocalAppData%\Microsoft\OneNote\*\cache|*.*|RECURSE FileKey7=%LocalAppData%\Microsoft\OneNote\*\OneNoteOfflineCache_Files|*.*|RECURSE FileKey8=%AppData%\Microsoft\Document Building Blocks|*.*|RECURSE FileKey9=%AppData%\Microsoft\Office|*.tmp|RECURSE FileKey10=%AppData%\Microsoft\OIS|Toolbars.dat FileKey11=%AppData%\Microsoft\UProof|*.bin;*.XML FileKey12=%Documents%|~*.ppt;~*.pptx;~*.doc;~*.docx|RECURSE RegKey1=HKCU\Software\Microsoft\Office\11.0\MSE|LastLoadedSolution RegKey2=HKCU\Software\Microsoft\Office\11.0\MSE\FileMRUList RegKey3=HKCU\Software\Microsoft\Office\11.0\MSE\ProjectMRUList RegKey4=HKCU\Software\Microsoft\Office\11.0\MSE\SolutionMRUList RegKey5=HKCU\Software\Microsoft\Office\12.0\Common\Internet|UseRWHlinkNavigation RegKey6=HKCU\Software\Microsoft\Office\12.0\Word\Reading Locations RegKey7=HKCU\Software\Microsoft\Office\14.0\Common\Internet|UseRWHlinkNavigation RegKey8=HKCU\Software\Microsoft\Office\14.0\Word\Reading Locations RegKey9=HKCU\Software\Microsoft\Office\15.0\Common\Internet|UseRWHlinkNavigation RegKey10=HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations RegKey11=HKCU\Software\Microsoft\Office\16.0\Common\Internet|UseRWHlinkNavigation RegKey12=HKCU\Software\Microsoft\Office\16.0\Word\Reading Locations RegKey13=HKCU\Software\Microsoft\Office\Common|FontBmpCache RegKey14=HKCU\Software\Microsoft\OfficeCustomizeWizard\12.0\RecentFileList RegKey15=HKCU\Software\Microsoft\OfficeCustomizeWizard\14.0\RecentFileList RegKey16=HKCU\Software\Microsoft\OfficeCustomizeWizard\15.0\RecentFileList RegKey17=HKCU\Software\Microsoft\OfficeCustomizeWizard\16.0\RecentFileList Link to comment Share on other sites More sharing options...
SMalik Posted December 14, 2018 Share Posted December 14, 2018 Revied Entry Changed the entry name from [OneDrive *] to match CCleaner's built-in entry [MS OneDrive *] LangSecRef=3021 Detect=HKCU\Software\Microsoft\OneDrive Default=False FileKey1=%LocalAppData%\Microsoft\OneDrive\logs|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\OneDrive\setup\logs|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\OneDrive\logs|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted December 14, 2018 Share Posted December 14, 2018 New Entry Please add a warning. [MS Office Click-to-Run Updates *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\15.0 Detect2=HKCU\Software\Microsoft\Office\16.0 Default=False FileKey1=%CommonAppData%\Microsoft\ClickToRun\ProductReleases|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 14, 2018 Moderators Share Posted December 14, 2018 16 minutes ago, SMalik said: New Entry Please add a warning. [MS Office Click-to-Run Updates *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\15.0 Detect2=HKCU\Software\Microsoft\Office\16.0 Default=False FileKey1=%CommonAppData%\Microsoft\ClickToRun\ProductReleases|*.*|RECURSE Suggestions on said warning's words? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted December 14, 2018 Share Posted December 14, 2018 This should be removed. [MSConfig *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Shared Tools\MSConfig Default=False RegKey1=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandFrom RegKey2=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandTo RegKey3=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|MSConfig Link to comment Share on other sites More sharing options...
SMalik Posted December 14, 2018 Share Posted December 14, 2018 18 minutes ago, Nergal said: Suggestions on said warning's words? This can remove downloaded update files even before they are applied. Link to comment Share on other sites More sharing options...
SMalik Posted December 15, 2018 Share Posted December 15, 2018 I think [CD/DVD Burn Cache *] entry name should be changed to [CD Burning *] [CD Burning *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo Link to comment Share on other sites More sharing options...
SMalik Posted December 15, 2018 Share Posted December 15, 2018 DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini file belongs to Windows Media Player 9. I think this should be added into a new Windows Media Player entry and [Audio/Video Stats *] entry should be removed. http://www.dslreports.com/forum/r9745519-What-is-this-ini-file-on-WINXP [Windows Media Player *] LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer Default=False FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini Link to comment Share on other sites More sharing options...
siliconman01 Posted December 15, 2018 Share Posted December 15, 2018 7 hours ago, SMalik said: This should be removed. [MSConfig *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Shared Tools\MSConfig Default=False RegKey1=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandFrom RegKey2=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandTo RegKey3=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|MSConfig Why should it be removed? The MSConfig folder quite often gets left hanging empty when adding/removing programs. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 15, 2018 Share Posted December 15, 2018 52 minutes ago, siliconman01 said: Why should it be removed? The MSConfig folder quite often gets left hanging empty when adding/removing programs. It is System Configuration utility. There is no MSConfig folder. I think you are mixing it up with %SystemDrive%\Config.msi, which is totally different. This entry removes custom settings of MSConfig. https://www.computerhope.com/jargon/m/msconfig.htm Link to comment Share on other sites More sharing options...
siliconman01 Posted December 15, 2018 Share Posted December 15, 2018 17 minutes ago, SMalik said: It is System Configuration utility. There is no MSConfig folder. I think you are mixing it up with %SystemDrive%\Config.msi, which is totally different. This entry removes custom settings of MSConfig. https://www.computerhope.com/jargon/m/msconfig.htm Ooops, I stand corrected. Thanks a lot for straightening me out. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
