SMalik Posted December 3, 2018 Share Posted December 3, 2018 2 hours ago, APMichael said: I think SMalik means that he wants to protect the profile folder, because there are other (not profile) folders that could contain usual log files (*.log). My suggestion would be to rename the existing entry to [LevelDB Logs *] and add a new entry [Logs *] with ExcludeKeys for the profile folders: FileKeyX=%LocalAppData%\Google\Chrome*|*.log|RECURSE ExcludeKeyX=PATH|%LocalAppData%\Google\Chrome*\User Data\Default\|*.* ExcludeKeyX=PATH|%LocalAppData%\Google\Chrome*\User Data\*Profile*\|*.* (As far as I know, Google Chrome names the profile folders "Default", "Profile X" or "XYZ Profile".) Google Chrome profile folder names "Default" I meant to remove .log files from "Default" only %LocalAppData%\Google\Chrome\User Data\Default|*.log Link to comment Share on other sites More sharing options...
APMichael Posted December 3, 2018 Share Posted December 3, 2018 1 hour ago, SMalik said: I meant to remove .log files from "Default" only %LocalAppData%\Google\Chrome\User Data\Default|*.log Thanks for your clarification. This 0000X.log file is also a database file. But we could change the FileKeys, as mentioned in my other post: https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=298&tab=comments#comment-301811. This should work, because the other subfolders of "User Data" do not contain LevelDB files yet. Is that ok for you? 1 hour ago, SMalik said: Google Chrome profile folder names "Default" Yes, after the installation the profile folder name is "Default". However, if you add an additional user, the profile folder name for that new user is "Profile 1" (and that also adds a folder named "System Profile"). If you are using the guest mode, the profile folder name is "Guest Profile". Link to comment Share on other sites More sharing options...
SMalik Posted December 3, 2018 Share Posted December 3, 2018 39 minutes ago, APMichael said: Thanks for your clarification. This 0000X.log file is also a database file. But we could change the FileKeys, as mentioned in my other post: https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=298&tab=comments#comment-301811. This should work, because the other subfolders of "User Data" do not contain LevelDB files yet. Is that ok for you? Yes, after the installation the profile folder name is "Default". However, if you add an additional user, the profile folder name for that new user is "Profile 1" (and that also adds a folder named "System Profile"). If you are using the guest mode, the profile folder name is "Guest Profile". Yes, you are correct about the Google Chrome profiles. I have no problem with whatever changes you all make, but I definitely suggest the removing of .ldb files, the ones shown in the screenshots I have posted before. Link to comment Share on other sites More sharing options...
APMichael Posted December 3, 2018 Share Posted December 3, 2018 37 minutes ago, SMalik said: ... I have no problem with whatever changes you all make, but I definitely suggest the removing of .ldb files, ... Thank you for your fast reply. Ok, then I will change the FileKeys of the entry [Internet Cache *] as mentioned. (This will include the .ldb and .log files from "Default".) Link to comment Share on other sites More sharing options...
APMichael Posted December 3, 2018 Share Posted December 3, 2018 7 hours ago, siliconman01 said: I also have never seen any "affect" from RegKeys 1-4. My MS Notepad always stays the same size that I set it for. I suggest we just eliminate these 4 keys and the warning message. 2 hours ago, SMalik said: I think just FileKey5 & FileKey6 paths are enough in this entry without a warning. Thank you very much for your fast replies. Link to comment Share on other sites More sharing options...
APMichael Posted December 4, 2018 Share Posted December 4, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/3e191d5d00c465eae5c8eff2b1898c9cde05377e Link to comment Share on other sites More sharing options...
siliconman01 Posted December 5, 2018 Share Posted December 5, 2018 Modified entry: [Quicken *] Added Detect2 [Quicken *] LangSecRef=3021 Detect1=HKLM\Software\Intuit\Quicken Detect2=HKLM\Software\Quicken Default=False FileKey1=%AppData%\Intuit\Quicken\Log|*.txt;*.log FileKey2=%AppData%\Quicken\Log|*.txt;*.log FileKey3=%CommonAppData%\Intuit\Quicken\Log|*.log FileKey4=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|REMOVESELF FileKey5=%CommonAppData%\Intuit\SendError|*.log FileKey6=%CommonAppData%\Quicken\Log|*.log FileKey7=%CommonAppData%\Quicken\Log\installer|*.*|REMOVESELF FileKey8=%CommonAppData%\Quicken\SendError|*.log FileKey9=%LocalAppData%\Intuit\Common\Authorization\V1\Logs|*.txt FileKey10=%LocalAppData%\Quicken\Common\Authorization\V1\Logs|*.txt FileKey11=%LocalAppData%\VirtualStore\ProgramData\Intuit\Quicken\Log|*.log FileKey12=%LocalAppData%\VirtualStore\ProgramData\Intuit\SendError|*.log FileKey13=%LocalAppData%\VirtualStore\ProgramData\Quicken\Log|*.log FileKey14=%LocalAppData%\VirtualStore\ProgramData\Quicken\SendError|*.log FileKey15=%ProgramFiles%\Quicken\PDFDrv|install.log;InstallPDFConverter.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted December 5, 2018 Share Posted December 5, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/0847286a1fa4285162d033fd2fbd2510edd63544 Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: RegKey1, RegKey2 & RegKey3 [CyberLink AudioDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\AudioDirector4 Detect2=HKCU\Software\CyberLink\AudioDirector5 Detect3=HKCU\Software\CyberLink\AudioDirector6 Detect4=HKCU\Software\CyberLink\AudioDirector7 Detect5=HKCU\Software\CyberLink\AudioDirector8 Detect6=HKCU\Software\CyberLink\AudioDirector9 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%Documents%\Cyberlink\AudioDirector\*\SplitterIndex|*.*|RECURSE FileKey3=%LocalAppData%\Cyberlink\AudioDirector\*|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey3=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\AudioDirector4\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\AudioDirector4\MediaObj\MediaCache5\Thumbnail5 RegKey6=HKCU\Software\CyberLink\AudioDirector5\MediaObj\MediaCache5\Data5 RegKey7=HKCU\Software\CyberLink\AudioDirector5\MediaObj\MediaCache5\Thumbnail5 RegKey8=HKCU\Software\CyberLink\AudioDirector6\MediaObj\MediaCache5\Data5 RegKey9=HKCU\Software\CyberLink\AudioDirector6\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\AudioDirector7\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\AudioDirector7\MediaObj\MediaCache5\Thumbnail5 RegKey12=HKCU\Software\CyberLink\AudioDirector8\MediaObj\MediaCache5\Data5 RegKey13=HKCU\Software\CyberLink\AudioDirector8\MediaObj\MediaCache5\Thumbnail5 RegKey14=HKCU\Software\CyberLink\AudioDirector9\MediaObj\MediaCache5\Data5 RegKey15=HKCU\Software\CyberLink\AudioDirector9\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: RegKey1, RegKey2 & RegKey3 [CyberLink ColorDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\ColorDirector3 Detect2=HKCU\Software\CyberLink\ColorDirector4 Detect3=HKCU\Software\CyberLink\ColorDirector5 Detect4=HKCU\Software\CyberLink\ColorDirector6 Detect5=HKCU\Software\CyberLink\ColorDirector7 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%LocalAppData%\Cyberlink\ColorDirector\*|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey3=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\ColorDirector3\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\ColorDirector3\MediaObj\MediaCache5\Thumbnail5 RegKey6=HKCU\Software\CyberLink\ColorDirector4\MediaObj\MediaCache5\Data5 RegKey7=HKCU\Software\CyberLink\ColorDirector4\MediaObj\MediaCache5\Thumbnail5 RegKey8=HKCU\Software\CyberLink\ColorDirector5\MediaObj\MediaCache5\Data5 RegKey9=HKCU\Software\CyberLink\ColorDirector5\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\ColorDirector6\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\ColorDirector6\MediaObj\MediaCache5\Thumbnail5 RegKey12=HKCU\Software\CyberLink\ColorDirector7\MediaObj\MediaCache5\Data5 RegKey13=HKCU\Software\CyberLink\ColorDirector7\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entriy Added: RegKey1 thru RegKey3 [CyberLink PhotoDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PhotoDirector3 Detect2=HKLM\Software\CyberLink\PhotoDirector4 Detect3=HKLM\Software\CyberLink\PhotoDirector5 Detect4=HKLM\Software\CyberLink\PhotoDirector6 Detect5=HKLM\Software\CyberLink\PhotoDirector7 Detect6=HKLM\Software\CyberLink\PhotoDirector8 Detect7=HKLM\Software\CyberLink\PhotoDirector9 Detect8=HKLM\Software\CyberLink\PhotoDirector10 Default=False FileKey1=%Pictures%\PhotoDirector\*\*|*.*|RECURSE ExcludeKey1=PATH|%Pictures%\PhotoDirector\*\*\|*.phd RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey3=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: RegKey1, RegKey3, RegKey4 & RegKey21 [CyberLink PowerDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDirector10 Detect2=HKCU\Software\CyberLink\PowerDirector11 Detect3=HKCU\Software\CyberLink\PowerDirector12 Detect4=HKCU\Software\CyberLink\PowerDirector13 Detect5=HKCU\Software\CyberLink\PowerDirector14 Detect6=HKCU\Software\CyberLink\PowerDirector15 Detect7=HKCU\Software\CyberLink\PowerDirector16 Detect8=HKCU\Software\CyberLink\PowerDirector17 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%AppData%\Cyberlink\PowerDirector\*|Recentfiles.ini FileKey3=%AppData%\CyberLink\PowerDirector\*\AutoSave|*.*|RECURSE FileKey4=%AppData%\CyberLink\PowerDirector\*\photoTmp|*.*|RECURSE FileKey5=%AppData%\Cyberlink\PowerDirector\*\WaveForms|*.*|RECURSE FileKey6=%Documents%\CyberLink\PowerDirector\*|Snapshot(*).jpg FileKey7=%Documents%\CyberLink\PowerDirector\*\MyTitles|*.*|RECURSE FileKey8=%Documents%\Cyberlink\PowerDirector\*\PDRMUSIC.TMP|*.*|REMOVESELF FileKey9=%Documents%\Cyberlink\PowerDirector\*\PP.TWOPASS|*.*|REMOVESELF FileKey10=%Documents%\CyberLink\PowerDirector\*\Preview Cache Files|*.* FileKey11=%Documents%\CyberLink\PowerDirector\*\ShadowEditFiles|*.MPG FileKey12=%Documents%\CyberLink\PowerDirector\*\SplitterIndex|*.maidx RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\Hanuman RegKey3=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey4=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 RegKey5=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Data5 RegKey6=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Thumbnail5 RegKey9=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Data5 RegKey10=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Thumbnail5 RegKey11=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Data5 RegKey12=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Thumbnail5 RegKey13=HKCU\Software\CyberLink\PowerDirector14\MediaObj\MediaCache5\Data5 RegKey14=HKCU\Software\CyberLink\PowerDirector14\MediaObj\MediaCache5\Thumbnail5 RegKey15=HKCU\Software\CyberLink\PowerDirector15\MediaObj\MediaCache5\Data5 RegKey16=HKCU\Software\CyberLink\PowerDirector15\MediaObj\MediaCache5\Thumbnail5 RegKey17=HKCU\Software\CyberLink\PowerDirector16\MediaObj\MediaCache5\Data5 RegKey18=HKCU\Software\CyberLink\PowerDirector16\MediaObj\MediaCache5\Thumbnail5 RegKey19=HKCU\Software\CyberLink\PowerDirector17\MediaObj\MediaCache5\Data5 RegKey20=HKCU\Software\CyberLink\PowerDirector17\MediaObj\MediaCache5\Thumbnail5 RegKey21=HKCU\Software\CyberLink\PowerDirector17\OldCacheFolder Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: FileKey7, RegKey6 & RegKey7 [Adobe Elements Organizer *] LangSecRef=3023 Detect=HKCU\Software\Adobe\Elements Organizer Default=False FileKey1=%AppData%\Adobe\amecommand\6.0|Plugin Loading.log FileKey2=%AppData%\Adobe\Elements Organizer\*\Organizer|*.txt;status.dat FileKey3=%AppData%\Adobe\Elements Smart Tag Agent\*\Logs|*.log FileKey4=%AppData%\Adobe\LogTransport2\Logs|*.*|RECURSE FileKey5=%CommonAppData%|StreamingMediaTechnologyLog.txt FileKey6=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|face.thumb.9.cache;thumb.5.cache FileKey7=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog\FaceAnalysis|FaceAnalysis.cache FileKey8=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog\WaldoData|waldo.cache FileKey9=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog\Watch Folder|*.txt;*.xml RegKey1=HKCU\Software\Adobe\Elements Organizer\11.0\CurrentMediaFilePath RegKey2=HKCU\Software\Adobe\Elements Organizer\12.0\CurrentMediaFilePath RegKey3=HKCU\Software\Adobe\Elements Organizer\13.0\CurrentMediaFilePath RegKey4=HKCU\Software\Adobe\Elements Organizer\14.0\CurrentMediaFilePath RegKey5=HKCU\Software\Adobe\Elements Organizer\15.0\CurrentMediaFilePath RegKey6=HKCU\Software\Adobe\Elements Organizer\16.0\CurrentMediaFilePath RegKey7=HKCU\Software\Adobe\Elements Organizer\17.0\CurrentMediaFilePath Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: RegKey19, RegKey20 & RegKey21 [Adobe Photoshop Elements *] LangSecRef=3023 Detect=HKCU\Software\Adobe\Photoshop Elements Default=False FileKey1=%AppData%\Adobe\LogTransport2\Logs|*.*|RECURSE FileKey2=%AppData%\Adobe\Photoshop Elements\*\Editor|*.txt FileKey3=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cache RegKey1=HKCU\Software\Adobe\Photoshop Elements\11.0\common\settings\Elements MRU RegKey2=HKCU\Software\Adobe\Photoshop Elements\11.0\CurrentMediaFilePath RegKey3=HKCU\Software\Adobe\Photoshop Elements\11.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey4=HKCU\Software\Adobe\Photoshop Elements\12.0\common\settings\Elements MRU RegKey5=HKCU\Software\Adobe\Photoshop Elements\12.0\CurrentMediaFilePath RegKey6=HKCU\Software\Adobe\Photoshop Elements\12.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey7=HKCU\Software\Adobe\Photoshop Elements\13.0\common\settings\Elements MRU RegKey8=HKCU\Software\Adobe\Photoshop Elements\13.0\CurrentMediaFilePath RegKey9=HKCU\Software\Adobe\Photoshop Elements\13.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey10=HKCU\Software\Adobe\Photoshop Elements\14.0\common\settings\Elements MRU RegKey11=HKCU\Software\Adobe\Photoshop Elements\14.0\CurrentMediaFilePath RegKey12=HKCU\Software\Adobe\Photoshop Elements\14.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey13=HKCU\Software\Adobe\Photoshop Elements\15.0\common\settings\Elements MRU RegKey14=HKCU\Software\Adobe\Photoshop Elements\15.0\CurrentMediaFilePath RegKey15=HKCU\Software\Adobe\Photoshop Elements\15.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey16=HKCU\Software\Adobe\Photoshop Elements\16.0\common\settings\Elements MRU RegKey17=HKCU\Software\Adobe\Photoshop Elements\16.0\CurrentMediaFilePath RegKey18=HKCU\Software\Adobe\Photoshop Elements\16.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey19=HKCU\Software\Adobe\Photoshop Elements\17.0\common\settings\Elements MRU RegKey20=HKCU\Software\Adobe\Photoshop Elements\17.0\CurrentMediaFilePath RegKey21=HKCU\Software\Adobe\Photoshop Elements\17.0\VisitedDirs|STARTUPIMAGEDIRECTORY Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 Revised Entry Added: FileKey1 & RegKey7 [Adobe Premiere Elements *] LangSecRef=3023 Detect=HKCU\Software\Adobe\Premiere Elements Default=False FileKey1=%AppData%\Adobe\Common\Thumbnail Cache|thumbnailDB FileKey2=%AppData%\Adobe\LogTransport2\Logs|*.*|RECURSE FileKey3=%AppData%\Adobe\Premiere Elements\*|Plugin Loading.log FileKey4=%AppData%\Adobe\Premiere Elements\*\logs|*.*|RECURSE FileKey5=%Documents%\Adobe\Premiere Elements\*|*.log FileKey6=%Documents%\NewBlueFX\Logs|*.txt RegKey1=HKCU\Software\Adobe\Premiere Elements\11.0\MRUDocuments RegKey2=HKCU\Software\Adobe\Premiere Elements\12.0\MRUDocuments RegKey3=HKCU\Software\Adobe\Premiere Elements\13.0\MRUDocuments RegKey4=HKCU\Software\Adobe\Premiere Elements\14.0\MRUDocuments RegKey5=HKCU\Software\Adobe\Premiere Elements\15.0\MRUDocuments RegKey6=HKCU\Software\Adobe\Premiere Elements\16.0\MRUDocuments RegKey7=HKCU\Software\Adobe\Premiere Elements\17.0\MRUDocuments Link to comment Share on other sites More sharing options...
APMichael Posted December 6, 2018 Share Posted December 6, 2018 Since we are trying to avoid duplicate Keys, I would suggest that we add a separate entry and remove the Keys from all CyberLink entries: [CyberLink Common Cache *] LangSecRef=3021 Detect=HKCU\Software\CyberLink Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache\Data4 RegKey3=HKCU\Software\CyberLink\MediaCache\Thumbnail4 RegKey4=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2018 Share Posted December 6, 2018 12 minutes ago, APMichael said: Since we are trying to avoid duplicate Keys, I would suggest that we add a separate entry and remove the Keys from all CyberLink entries: [CyberLink Common Cache *] LangSecRef=3021 Detect=HKCU\Software\CyberLink Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache\Data4 RegKey3=HKCU\Software\CyberLink\MediaCache\Thumbnail4 RegKey4=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 That is better. How about CyberLink Media Cache? Link to comment Share on other sites More sharing options...
APMichael Posted December 6, 2018 Share Posted December 6, 2018 2 minutes ago, SMalik said: That is better. How about CyberLink Media Cache? Thank you for your quick reply. Sure, we can name the entry [CyberLink Media Cache *]. And many thanks for your revised entries. Link to comment Share on other sites More sharing options...
SMalik Posted December 7, 2018 Share Posted December 7, 2018 7 hours ago, APMichael said: Thank you for your quick reply. Sure, we can name the entry [CyberLink Media Cache *]. And many thanks for your revised entries. You're very welcome. Thanks for your efforts as well. I think we should bring the Adobe Media Cache entry back into Winapp2.ini from Winapp3.ini. I was initially against it, but we can use it wisely. I have always been using this. https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=293507 [Adobe Media Cache *] LangSecRef=3023 DetectFile=%AppData%\Adobe\Common\Media Cache Default=False FileKey1=%AppData%\Adobe\Common\Media Cache|*.*|RECURSE FileKey2=%AppData%\Adobe\Common\Media Cache Files|*.*|RECURSE FileKey3=%AppData%\Adobe\Common\Peak Files|*.*|RECURSE FileKey4=%AppData%\Adobe\Common\Team Projects Cache|*.*|RECURSE FileKey5=%AppData%\Adobe\Common\Thumbnail Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted December 7, 2018 Share Posted December 7, 2018 (edited) Here are some custom entries. Use them on your own risk. [Background Activity Moderator*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKLM\SYSTEM\CurrentControlSet\Services\bam\State\UserSettings [Mounted Volumes *]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseRegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 [Other Apps *]DetectOS=10.0LangSecRef=3031Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppDataDefault=FalseFileKey1=%LocalAppData%\Packages\*\AC\AppCache|*.*|RECURSEFileKey2=%LocalAppData%\Packages\*\AC\INet*|*.*|RECURSEFileKey3=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSEFileKey4=%LocalAppData%\Packages\*\AC\PRICache|*.*|RECURSEFileKey5=%LocalAppData%\Packages\*\AC\Temp|*.*|RECURSEFileKey6=%LocalAppData%\Packages\*\AC\TokenBroker\Cache|*.*|RECURSEFileKey7=%LocalAppData%\Packages\*\LocalCache\Cache|*.*|RECURSEFileKey8=%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSEFileKey9=%LocalAppData%\Packages\*\LocalState\DiagOutputDir|*.txtFileKey10=%LocalAppData%\Packages\*\TempState|*.*|RECURSE [Registry Virtualization *]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseRegKey1=HKCU\Software\Classes\VirtualStore Edited December 7, 2018 by Nergal Link to comment Share on other sites More sharing options...
SMalik Posted December 7, 2018 Share Posted December 7, 2018 I just posted some custom entries above and it is removing Background Activity Moderator name from the first entry. I edited that post a few times, same issue. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 7, 2018 Moderators Share Posted December 7, 2018 18 minutes ago, SMalik said: I just posted some custom entries above and it is removing Background Activity Moderator name from the first entry. I edited that post a few times, same issue. I tried twice too I think the php reads "moderator" with ] as a command. I put it in code tags but it looks kinda ugly ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
APMichael Posted December 7, 2018 Share Posted December 7, 2018 14 hours ago, SMalik said: Here are some custom entries. Use them on your own risk. ... I have compared your custom entries with the Winapp3.ini and have revised or added the entries. Link to comment Share on other sites More sharing options...
APMichael Posted December 7, 2018 Share Posted December 7, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/662b2951e644649b9be3b6d5ce8beb747794ca61Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f13dd8fff2289c27001138c1f9f53978d6f78214 Link to comment Share on other sites More sharing options...
SMalik Posted December 8, 2018 Share Posted December 8, 2018 Revised Entry Changed LangSecRef from 3021 to 3023 [CyberLink Media Cache *] LangSecRef=3023 Detect=HKCU\Software\CyberLink Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\DSSharedMediaInfo\SharedInfoCache RegKey2=HKCU\Software\CyberLink\MediaCache\Data4 RegKey3=HKCU\Software\CyberLink\MediaCache\Thumbnail4 RegKey4=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
