SMalik Posted January 12, 2018 Share Posted January 12, 2018 Revised Entry Added: %AppData%\Adobe\Photoshop Elements\*\Editor|*.txt [Adobe Photoshop Elements *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Photoshop Elements Default=False FileKey1=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cache FileKey2=%AppData%\Adobe\Photoshop Elements\*\Editor|*.txt RegKey1=HKCU\Software\Adobe\Photoshop Elements\11.0\common\settings\Elements MRU RegKey2=HKCU\Software\Adobe\Photoshop Elements\11.0\CurrentMediaFilePath RegKey3=HKCU\Software\Adobe\Photoshop Elements\11.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey4=HKCU\Software\Adobe\Photoshop Elements\12.0\common\settings\Elements MRU RegKey5=HKCU\Software\Adobe\Photoshop Elements\12.0\CurrentMediaFilePath RegKey6=HKCU\Software\Adobe\Photoshop Elements\12.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey7=HKCU\Software\Adobe\Photoshop Elements\13.0\common\settings\Elements MRU RegKey8=HKCU\Software\Adobe\Photoshop Elements\13.0\CurrentMediaFilePath RegKey9=HKCU\Software\Adobe\Photoshop Elements\13.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey10=HKCU\Software\Adobe\Photoshop Elements\14.0\common\settings\Elements MRU RegKey11=HKCU\Software\Adobe\Photoshop Elements\14.0\CurrentMediaFilePath RegKey12=HKCU\Software\Adobe\Photoshop Elements\14.0\VisitedDirs|STARTUPIMAGEDIRECTORY RegKey13=HKCU\Software\Adobe\Photoshop Elements\15.0\common\settings\Elements MRU RegKey14=HKCU\Software\Adobe\Photoshop Elements\15.0\CurrentMediaFilePath RegKey15=HKCU\Software\Adobe\Photoshop Elements\15.0\VisitedDirs|STARTUPIMAGEDIRECTORY Link to comment Share on other sites More sharing options...
patrickdrd Posted January 12, 2018 Share Posted January 12, 2018 On 10/1/2018 at 13:22, Andavari said: Unfortunately deleting lang files can break some programs, i.e.; in some they may show a pop-up error dialog about missing files, and some others they won't run at all. It's one of those things that if I'm about to delete a bunch of lang files in a program I ZIP them first, then delete them manually and see what happens. If all goes well I add them into my winapp2.ini file, but I never submit them on here because someone using a non-English lang version of a program may need those lang files. you didn't understand, I'm keeping only English based files (even though it's not my mother language for me either), but I get sick when I get an app (a portable one for example) that is only available in "international" version and I don't have a choice than to install thousands of junk files from languages all over the world, and later, when there's an update and I need to sync that app, I would have to wait for it to sync all these completely useless thousands of files relying in random folders and difficult to find, well, this sucks, obviously.. other than that, I've had only one or two problems with chrome, where there was one or two files that were needed for an extension to run, even though that seemed like language files to me, other than that, no problems.. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted January 12, 2018 Moderators Share Posted January 12, 2018 On 1/11/2018 at 07:26, SMalik said: Does it make sense to remove "Application Cache" directories from this entry? [Chrome Application Cache *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False FileKey1=%AppData%\Brave\*\Application Cache|*.*|REMOVESELF FileKey2=%LocalAppData%\Amigo\User Data\*\Application Cache|*.*|REMOVESELF FileKey3=%LocalAppData%\Chrome Plus\User Data\*\Application Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\Chromium\User Data\*\Application Cache|*.*|REMOVESELF FileKey5=%LocalAppData%\Flock\User Data\*\Application Cache|*.*|REMOVESELF FileKey6=%LocalAppData%\Google\Chrome*\User Data\*\Application Cache|*.*|REMOVESELF FileKey7=%LocalAppData%\Rockmelt\User Data\*\Application Cache|*.*|REMOVESELF FileKey8=%LocalAppData%\SRWare Iron\User Data\*\Application Cache|*.*|REMOVESELF FileKey9=%LocalAppData%\SuperBird\User Data\*\Application Cache|*.*|REMOVESELF FileKey10=%LocalAppData%\Torch\User Data\*\Application Cache|*.*|REMOVESELF FileKey11=%LocalAppData%\Vivaldi\User Data\*\Application Cache|*.*|REMOVESELF With my own personal Chrome/Chrome-based browser cleaners on my system I only use RECURSE with Application Cache folders. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 13, 2018 Author Share Posted January 13, 2018 22 hours ago, JDPower said: That may be true, but my point was you can't easily copy and paste the entries from Git update page. Unless I'm missing something, you copy and paste, then have to delete a load of plus signs, minus signs, removed lines, leading spaces. Then hope you've not accidentally screwed up the entry in the process lol I've completed the basic work for this now actually. It's not ready for public release just yet, but it is functional. Here is an example of the output:NOTE TO READERS: THE BELOW IS NOT AN OFFICIAL CHANGELOG OF ANY SORT AND SHOULD NOT BE INTERPRETED AS ONE. IT IS SIMPLY THE OUTPUT OF A CLASS I AM TESTING THAT WILL EVENTUALLY REPLACE THE BACKBONE OF THE CURRENT SET OF TOOLS SUCH AS WINAPPDEBUG. I have provided it for feedback purposes only Installer * has been modified. [Installer *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect=HKCU\Software\Vivaldi Default=False FileKey1=%LocalAppData%\SuperBird\Application\*\Installer|*.7z FileKey2=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey5=%ProgramFiles%\Google\Chrome\Application\*\Installer|*.7z ---------------------------------------------------------------------------------------------------------------------- Web Data * has been modified. [Web Data *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info. FileKey1=%LocalAppData%\Amigo\User Data\*\*|Web Data FileKey2=%LocalAppData%\Chrome Plus\User Data\*|Web Data FileKey3=%LocalAppData%\Chromium\User Data\*|Web Data FileKey4=%LocalAppData%\Flock\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Rockmelt\User Data\*|Web Data FileKey7=%LocalAppData%\SRWare Iron\User Data\*|Web Data FileKey8=%LocalAppData%\SuperBird\User Data\*|Web Data FileKey9=%LocalAppData%\Torch\User Data\*|Web Data FileKey10=%LocalAppData%\Vivaldi\User Data\*|Web Data ---------------------------------------------------------------------------------------------------------------------- Active@ Disk Image * has been modified. [Active@ Disk Image *] LangSecRef=3024 Detect=HKLM\Software\LSoft Technologies\Active Disk Image Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE FileKey3=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey4=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Images * was removed. [Active@ UNDELETE Images *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved disk images. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Recovered Files * was removed. [Active@ UNDELETE Recovered Files *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all recovered data. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Sessions * was removed. [Active@ UNDELETE Sessions *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved sessions. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE ---------------------------------------------------------------------------------------------------------------------- Adobe Photoshop * has been modified. [Adobe Photoshop *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Photoshop Default=False RegKey1=HKCU\Software\Adobe\Photoshop\5.5\VisitedDirs FileKey1=%AppData%\Adobe\Adobe Photoshop*\Generator\logs|*.* FileKey2=%AppData%\Adobe\Bridge*\Cache\Thumbnails|*.*|RECURSE FileKey3=%AppData%\Adobe\CameraRaw\Cache|*.*|RECURSE FileKey4=%AppData%\Adobe\FileBrowser\PhotoshopCS|*.* FileKey5=%AppData%\Adobe\Photoshop Album\*.*|Logse*.txt FileKey6=%Pictures%|.BridgeSort|RECURSE ---------------------------------------------------------------------------------------------------------------------- Cameyo * has been modified. [Cameyo *] LangSecRef=3021 Detect=HKCU\Software\VOS Default=False RegKey1=HKCU\Software\VOS FileKey1=%AppData%\VOS|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- CCDump * has been modified. [CCDump *] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Default=False Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt ---------------------------------------------------------------------------------------------------------------------- CD/DVD Burn Cache * has been modified. [CD/DVD Burn Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo ---------------------------------------------------------------------------------------------------------------------- DriverPack Solution * has been modified. [DriverPack Solution *] LangSecRef=3024 Detect=HKCU\Software\drpsu Default=False Warning=This will delete your bug report. FileKey1=%AppData%\DRPSu\Logs|*.* FileKey2=%AppData%\DRPSu\snapshots|*.* FileKey3=%AppData%\DRPSu\temp|*.* FileKey4=%Documents%\DRP-Log|*.* FileKey5=%WinDir%\Logs\DRPLog|*.png;*.txt FileKey6=%WinDir%\Logs\SysInfo|*.* ---------------------------------------------------------------------------------------------------------------------- DUC * was removed. [DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%LocalAppData%\Vitalwerks\DUC|DUC.log ---------------------------------------------------------------------------------------------------------------------- ElsterFormular * has been modified. [ElsterFormular *] LangSecRef=3021 DetectFile=%AppData%\elsterformular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log;*.log.* FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zip FileKey4=%CommonAppData%\elsterformular\log|*.log FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey6=%LocalAppData%\elfopatch|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- HyperSnap 7 * has been modified. [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List ---------------------------------------------------------------------------------------------------------------------- Intuit TurboTax * has been modified. [Intuit TurboTax *] LangSecRef=3021 DetectFile=%ProgramFiles%\TurboTax* Default=False FileKey1=%AppData%\Intuit*|*.log|RECURSE FileKey2=%CommonAppData%|*.bc FileKey3=%CommonAppData%\Intuit*|*.log|RECURSE FileKey4=%CommonAppData%\Intuit\Common\Metrix\*\Logs|*.* FileKey5=%CommonAppData%\Intuit\Common\QuickBaseClient\*\Logs|*.* FileKey6=%CommonAppData%\Intuit\Common\Update Service\*\Logs|*.* FileKey7=%CommonAppData%\Intuit\TurboTax\MSI\*\Logs|*.* FileKey8=%CommonProgramFiles%\Intuit\Internet Client|Msdun13.exe FileKey9=%LocalAppData%\VirtualStore\Program Files*\Common Files\Intuit\Internet Client|Msdun13.exe FileKey10=%LocalAppData%\VirtualStore\Program Files*\TurboTax*|*.txt FileKey11=%LocalAppData%\VirtualStore\ProgramData|*.bc FileKey12=%LocalAppData%\VirtualStore\ProgramData\Intuit*|*.log|RECURSE FileKey13=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\Metrix\*\Logs|*.* FileKey14=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\QuickBaseClient\*\Logs|*.* FileKey15=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\Update Service\*\Logs|*.* FileKey16=%LocalAppData%\VirtualStore\ProgramData\Intuit\TurboTax\MSI\*\Logs|*.* FileKey17=%ProgramFiles%\TurboTax*|*.txt ---------------------------------------------------------------------------------------------------------------------- Macrium Reflect * has been modified. [Macrium Reflect *] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium|*.log|RECURSE FileKey2=%CommonAppData%\Macrium\Reflect|*.html;*.vsslog FileKey3=%CommonAppData%\Macrium\waik|waiklog.txt FileKey4=%SystemDrive%|ref~tmp~.txt;Reflect_Install.log;rescuepe.log ---------------------------------------------------------------------------------------------------------------------- MS Search * has been modified. [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey9=%UserProfile%\Searches|*.search-ms RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery RegKey2=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache ---------------------------------------------------------------------------------------------------------------------- Nitro PDF Reader * has been modified. [Nitro PDF Reader *] LangSecRef=3024 Detect=HKCU\Software\Nitro PDF\Reader Default=False RegKey1=HKCU\Software\Nitro PDF\Reader\1.0\Recent File List RegKey2=HKCU\Software\Nitro PDF\Reader\2.0\Recent File List FileKey1=%AppData%\Nitro|*.log*;*Log.txt*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Notepad++ * has been modified. [Notepad++ *] LangSecRef=3021 Detect=HKLM\Software\Notepad++ Default=False FileKey1=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zip FileKey2=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF FileKey3=%ProgramFiles%\Notepad++\plugins\disabled|*.* ---------------------------------------------------------------------------------------------------------------------- OpenDNS Updater * has been modified. [OpenDNS Updater *] LangSecRef=3021 Detect=HKCU\Software\OpenDNS Updater Default=False Warning=You must exit OpenDNS Updater in the System Tray to clear log files. FileKey1=%AppData%\OpenDNS Updater|*.txt ---------------------------------------------------------------------------------------------------------------------- OpenOffice.org Setup Files * has been modified. [OpenOffice.org Setup Files *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%UserProfile%\Desktop\OpenOffice.org * Installation Files|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Pando * has been modified. [Pando *] Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default=False Warning=Make sure Pando is totally shut down before using this. FileKey1=%LocalAppData%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\Pando\Pando Files\|*pando.prev.log;*pando.log;*pando.sav;*pando.save;*pando.txt ExcludeKey2=PATH|%LocalAppData%\Pando\Pando Files\Cert\|*.* ---------------------------------------------------------------------------------------------------------------------- Photos * has been modified. [Photos *] DetectOS=10.0| Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey10=%LocalAppData%\PackagesMicrosoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ---------------------------------------------------------------------------------------------------------------------- QTTabBar * has been modified. [QTTabBar *] LangSecRef=3024 Detect=HKCU\Software\Quizo\QTTabBar Default=False FileKey1=%AppData%\QTTabBar|*.log RegKey1=HKCU\Software\Quizo\QTTabBar|TabsOnLastClosedWindow RegKey2=HKCU\Software\Quizo\QTTabBar\Cache RegKey3=HKCU\Software\Quizo\QTTabBar\RecentlyClosed ---------------------------------------------------------------------------------------------------------------------- Saved Search Folders * was removed. [Saved Search Folders *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8 or newer FileKey1=%UserProfile%\Searches|*.search-ms ---------------------------------------------------------------------------------------------------------------------- SoftEther VPN * has been modified. [SoftEther VPN *] LangSecRef=3024 Detect=HKCU\Software\SoftEther Project\SoftEther VPN Default=False Warning=Exclude installer.cache if you're using SoftEther VPN Client Web Installer. FileKey1=%ProgramFiles%\SoftEther VPN Client|installer.cache FileKey2=%ProgramFiles%\SoftEther VPN Client\backup.vpn_client.config|*.config FileKey3=%ProgramFiles%\SoftEther VPN Client\client_log|*.* FileKey4=%ProgramFiles%\SoftEther VPN Client\vpn_debug|*.* ---------------------------------------------------------------------------------------------------------------------- TortoiseSVN History * has been modified. [TortoiseSVN History *] LangSecRef=3024 Detect=HKCU\Software\TortoiseSVN Default=False Warning=This will remove your repo paths and last checkout location. RegKey1=HKCU\Software\TortoiseSVN\History ---------------------------------------------------------------------------------------------------------------------- UsbFix * has been modified. [UsbFix *] LangSecRef=3023 Detect=HKCU\Software\UsbFix Default=False FileKey1=%SystemDrive%\UsbFix\Log|*.*|REMOVESELF FileKey2=%SystemDrive%\UsbFix\Quarantine|*.*|REMOVESELF FileKey3=%UserProfile%\Desktop|UsbFix_Report.txt RegKey1=HKCU\Software\UsbFix\LastReport ---------------------------------------------------------------------------------------------------------------------- VSO Media Player 1 * has been modified. [VSO Media Player 1 *] LangSecRef=3023 Detect=HKCU\Software\VSO\VSO Media Player\1 Default=False RegKey1=HKCU\Software\VSO\VSO Media Player\1\RecentlyOpenedFiles FileKey1=%AppData%\VSO\VSO Media Player\1|autoresume.xml FileKey2=%CommonAppData%\VSO|font.cache FileKey3=%CommonAppData%\VSO\VSO Media Player\1\log|*.log;*.crashlist FileKey4=%CommonAppData%\VSO\vsothumbs|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\VSO|font.cache FileKey6=%LocalAppData%\VirtualStore\ProgramData\VSO\VSO Media Player\1\log|*.log;*.crashlist FileKey7=%LocalAppData%\VirtualStore\ProgramData\VSO\vsothumbs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Windows Media Center * has been modified. [Windows Media Center *] LangSecRef=3023 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU FileKey1=%CommonAppData%\Microsoft\eHome\thmb|TVThumb.db FileKey2=%LocalAppData%\Microsoft\Ehome|Image.db;Video.db;musicThumbs.db FileKey3=%LocalAppData%\VirtualStore\ProgramData\Microsoft\eHome\thmb|TVThumb.db ---------------------------------------------------------------------------------------------------------------------- Windows ShellBags * has been modified. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ---------------------------------------------------------------------------------------------------------------------- X-Chat 2 * has been modified. [X-Chat 2 *] LangSecRef=3022 DetectFile=%AppData%\X-Chat 2 Default=False Warning=This removes Chat Scrollback and Logs. FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- No-IP DUC * was added. [No-IP DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%CommonAppData%\Vitalwerks\DUC|*.log FileKey2=%LocalAppData%\Vitalwerks\DUC|*.log ---------------------------------------------------------------------------------------------------------------------- Note: the above output doesn't reflect any particular current set of changes and should not be interpreted as a changelog. It is only an example of the output of the compareTo method for a new class I wrote that will eventually be used replace the backbone of the current set of tools winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted January 13, 2018 Share Posted January 13, 2018 7 minutes ago, Winapp2.ini said: I've completed the basic work for this now actually. It's not ready for public release just yet, but it is functional. Here is an example of the output:NOTE TO READERS: THE BELOW IS NOT AN OFFICIAL CHANGELOG OF ANY SORT AND SHOULD NOT BE INTERPRETED AS ONE. IT IS SIMPLY THE OUTPUT OF A CLASS I AM TESTING THAT WILL EVENTUALLY REPLACE THE BACKBONE OF THE CURRENT SET OF TOOLS SUCH AS WINAPPDEBUG. I have provided it for feedback purposes only Reveal hidden contents Installer * has been modified. [Installer *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect=HKCU\Software\Vivaldi Default=False FileKey1=%LocalAppData%\SuperBird\Application\*\Installer|*.7z FileKey2=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey5=%ProgramFiles%\Google\Chrome\Application\*\Installer|*.7z ---------------------------------------------------------------------------------------------------------------------- Web Data * has been modified. [Web Data *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info. FileKey1=%LocalAppData%\Amigo\User Data\*\*|Web Data FileKey2=%LocalAppData%\Chrome Plus\User Data\*|Web Data FileKey3=%LocalAppData%\Chromium\User Data\*|Web Data FileKey4=%LocalAppData%\Flock\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Rockmelt\User Data\*|Web Data FileKey7=%LocalAppData%\SRWare Iron\User Data\*|Web Data FileKey8=%LocalAppData%\SuperBird\User Data\*|Web Data FileKey9=%LocalAppData%\Torch\User Data\*|Web Data FileKey10=%LocalAppData%\Vivaldi\User Data\*|Web Data ---------------------------------------------------------------------------------------------------------------------- Active@ Disk Image * has been modified. [Active@ Disk Image *] LangSecRef=3024 Detect=HKLM\Software\LSoft Technologies\Active Disk Image Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE FileKey3=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey4=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Images * was removed. [Active@ UNDELETE Images *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved disk images. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Recovered Files * was removed. [Active@ UNDELETE Recovered Files *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all recovered data. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Sessions * was removed. [Active@ UNDELETE Sessions *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved sessions. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE ---------------------------------------------------------------------------------------------------------------------- Adobe Photoshop * has been modified. [Adobe Photoshop *] LangSecRef=3021 Detect=HKCU\Software\Adobe\Photoshop Default=False RegKey1=HKCU\Software\Adobe\Photoshop\5.5\VisitedDirs FileKey1=%AppData%\Adobe\Adobe Photoshop*\Generator\logs|*.* FileKey2=%AppData%\Adobe\Bridge*\Cache\Thumbnails|*.*|RECURSE FileKey3=%AppData%\Adobe\CameraRaw\Cache|*.*|RECURSE FileKey4=%AppData%\Adobe\FileBrowser\PhotoshopCS|*.* FileKey5=%AppData%\Adobe\Photoshop Album\*.*|Logse*.txt FileKey6=%Pictures%|.BridgeSort|RECURSE ---------------------------------------------------------------------------------------------------------------------- Cameyo * has been modified. [Cameyo *] LangSecRef=3021 Detect=HKCU\Software\VOS Default=False RegKey1=HKCU\Software\VOS FileKey1=%AppData%\VOS|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- CCDump * has been modified. [CCDump *] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Default=False Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt ---------------------------------------------------------------------------------------------------------------------- CD/DVD Burn Cache * has been modified. [CD/DVD Burn Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo ---------------------------------------------------------------------------------------------------------------------- DriverPack Solution * has been modified. [DriverPack Solution *] LangSecRef=3024 Detect=HKCU\Software\drpsu Default=False Warning=This will delete your bug report. FileKey1=%AppData%\DRPSu\Logs|*.* FileKey2=%AppData%\DRPSu\snapshots|*.* FileKey3=%AppData%\DRPSu\temp|*.* FileKey4=%Documents%\DRP-Log|*.* FileKey5=%WinDir%\Logs\DRPLog|*.png;*.txt FileKey6=%WinDir%\Logs\SysInfo|*.* ---------------------------------------------------------------------------------------------------------------------- DUC * was removed. [DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%LocalAppData%\Vitalwerks\DUC|DUC.log ---------------------------------------------------------------------------------------------------------------------- ElsterFormular * has been modified. [ElsterFormular *] LangSecRef=3021 DetectFile=%AppData%\elsterformular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log;*.log.* FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zip FileKey4=%CommonAppData%\elsterformular\log|*.log FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey6=%LocalAppData%\elfopatch|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- HyperSnap 7 * has been modified. [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List ---------------------------------------------------------------------------------------------------------------------- Intuit TurboTax * has been modified. [Intuit TurboTax *] LangSecRef=3021 DetectFile=%ProgramFiles%\TurboTax* Default=False FileKey1=%AppData%\Intuit*|*.log|RECURSE FileKey2=%CommonAppData%|*.bc FileKey3=%CommonAppData%\Intuit*|*.log|RECURSE FileKey4=%CommonAppData%\Intuit\Common\Metrix\*\Logs|*.* FileKey5=%CommonAppData%\Intuit\Common\QuickBaseClient\*\Logs|*.* FileKey6=%CommonAppData%\Intuit\Common\Update Service\*\Logs|*.* FileKey7=%CommonAppData%\Intuit\TurboTax\MSI\*\Logs|*.* FileKey8=%CommonProgramFiles%\Intuit\Internet Client|Msdun13.exe FileKey9=%LocalAppData%\VirtualStore\Program Files*\Common Files\Intuit\Internet Client|Msdun13.exe FileKey10=%LocalAppData%\VirtualStore\Program Files*\TurboTax*|*.txt FileKey11=%LocalAppData%\VirtualStore\ProgramData|*.bc FileKey12=%LocalAppData%\VirtualStore\ProgramData\Intuit*|*.log|RECURSE FileKey13=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\Metrix\*\Logs|*.* FileKey14=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\QuickBaseClient\*\Logs|*.* FileKey15=%LocalAppData%\VirtualStore\ProgramData\Intuit\Common\Update Service\*\Logs|*.* FileKey16=%LocalAppData%\VirtualStore\ProgramData\Intuit\TurboTax\MSI\*\Logs|*.* FileKey17=%ProgramFiles%\TurboTax*|*.txt ---------------------------------------------------------------------------------------------------------------------- Macrium Reflect * has been modified. [Macrium Reflect *] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium|*.log|RECURSE FileKey2=%CommonAppData%\Macrium\Reflect|*.html;*.vsslog FileKey3=%CommonAppData%\Macrium\waik|waiklog.txt FileKey4=%SystemDrive%|ref~tmp~.txt;Reflect_Install.log;rescuepe.log ---------------------------------------------------------------------------------------------------------------------- MS Search * has been modified. [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey9=%UserProfile%\Searches|*.search-ms RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery RegKey2=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache ---------------------------------------------------------------------------------------------------------------------- Nitro PDF Reader * has been modified. [Nitro PDF Reader *] LangSecRef=3024 Detect=HKCU\Software\Nitro PDF\Reader Default=False RegKey1=HKCU\Software\Nitro PDF\Reader\1.0\Recent File List RegKey2=HKCU\Software\Nitro PDF\Reader\2.0\Recent File List FileKey1=%AppData%\Nitro|*.log*;*Log.txt*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Notepad++ * has been modified. [Notepad++ *] LangSecRef=3021 Detect=HKLM\Software\Notepad++ Default=False FileKey1=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zip FileKey2=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF FileKey3=%ProgramFiles%\Notepad++\plugins\disabled|*.* ---------------------------------------------------------------------------------------------------------------------- OpenDNS Updater * has been modified. [OpenDNS Updater *] LangSecRef=3021 Detect=HKCU\Software\OpenDNS Updater Default=False Warning=You must exit OpenDNS Updater in the System Tray to clear log files. FileKey1=%AppData%\OpenDNS Updater|*.txt ---------------------------------------------------------------------------------------------------------------------- OpenOffice.org Setup Files * has been modified. [OpenOffice.org Setup Files *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%UserProfile%\Desktop\OpenOffice.org * Installation Files|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Pando * has been modified. [Pando *] Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default=False Warning=Make sure Pando is totally shut down before using this. FileKey1=%LocalAppData%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\Pando\Pando Files\|*pando.prev.log;*pando.log;*pando.sav;*pando.save;*pando.txt ExcludeKey2=PATH|%LocalAppData%\Pando\Pando Files\Cert\|*.* ---------------------------------------------------------------------------------------------------------------------- Photos * has been modified. [Photos *] DetectOS=10.0| Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey10=%LocalAppData%\PackagesMicrosoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ---------------------------------------------------------------------------------------------------------------------- QTTabBar * has been modified. [QTTabBar *] LangSecRef=3024 Detect=HKCU\Software\Quizo\QTTabBar Default=False FileKey1=%AppData%\QTTabBar|*.log RegKey1=HKCU\Software\Quizo\QTTabBar|TabsOnLastClosedWindow RegKey2=HKCU\Software\Quizo\QTTabBar\Cache RegKey3=HKCU\Software\Quizo\QTTabBar\RecentlyClosed ---------------------------------------------------------------------------------------------------------------------- Saved Search Folders * was removed. [Saved Search Folders *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8 or newer FileKey1=%UserProfile%\Searches|*.search-ms ---------------------------------------------------------------------------------------------------------------------- SoftEther VPN * has been modified. [SoftEther VPN *] LangSecRef=3024 Detect=HKCU\Software\SoftEther Project\SoftEther VPN Default=False Warning=Exclude installer.cache if you're using SoftEther VPN Client Web Installer. FileKey1=%ProgramFiles%\SoftEther VPN Client|installer.cache FileKey2=%ProgramFiles%\SoftEther VPN Client\backup.vpn_client.config|*.config FileKey3=%ProgramFiles%\SoftEther VPN Client\client_log|*.* FileKey4=%ProgramFiles%\SoftEther VPN Client\vpn_debug|*.* ---------------------------------------------------------------------------------------------------------------------- TortoiseSVN History * has been modified. [TortoiseSVN History *] LangSecRef=3024 Detect=HKCU\Software\TortoiseSVN Default=False Warning=This will remove your repo paths and last checkout location. RegKey1=HKCU\Software\TortoiseSVN\History ---------------------------------------------------------------------------------------------------------------------- UsbFix * has been modified. [UsbFix *] LangSecRef=3023 Detect=HKCU\Software\UsbFix Default=False FileKey1=%SystemDrive%\UsbFix\Log|*.*|REMOVESELF FileKey2=%SystemDrive%\UsbFix\Quarantine|*.*|REMOVESELF FileKey3=%UserProfile%\Desktop|UsbFix_Report.txt RegKey1=HKCU\Software\UsbFix\LastReport ---------------------------------------------------------------------------------------------------------------------- VSO Media Player 1 * has been modified. [VSO Media Player 1 *] LangSecRef=3023 Detect=HKCU\Software\VSO\VSO Media Player\1 Default=False RegKey1=HKCU\Software\VSO\VSO Media Player\1\RecentlyOpenedFiles FileKey1=%AppData%\VSO\VSO Media Player\1|autoresume.xml FileKey2=%CommonAppData%\VSO|font.cache FileKey3=%CommonAppData%\VSO\VSO Media Player\1\log|*.log;*.crashlist FileKey4=%CommonAppData%\VSO\vsothumbs|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\VSO|font.cache FileKey6=%LocalAppData%\VirtualStore\ProgramData\VSO\VSO Media Player\1\log|*.log;*.crashlist FileKey7=%LocalAppData%\VirtualStore\ProgramData\VSO\vsothumbs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Windows Media Center * has been modified. [Windows Media Center *] LangSecRef=3023 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU FileKey1=%CommonAppData%\Microsoft\eHome\thmb|TVThumb.db FileKey2=%LocalAppData%\Microsoft\Ehome|Image.db;Video.db;musicThumbs.db FileKey3=%LocalAppData%\VirtualStore\ProgramData\Microsoft\eHome\thmb|TVThumb.db ---------------------------------------------------------------------------------------------------------------------- Windows ShellBags * has been modified. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ---------------------------------------------------------------------------------------------------------------------- X-Chat 2 * has been modified. [X-Chat 2 *] LangSecRef=3022 DetectFile=%AppData%\X-Chat 2 Default=False Warning=This removes Chat Scrollback and Logs. FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- No-IP DUC * was added. [No-IP DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%CommonAppData%\Vitalwerks\DUC|*.log FileKey2=%LocalAppData%\Vitalwerks\DUC|*.log ---------------------------------------------------------------------------------------------------------------------- Note: the above output doesn't reflect any particular current set of changes and should not be interpreted as a changelog. It is only an example of the output of the compareTo method for a new class I wrote that will eventually be used replace the backbone of the current set of tools Now we're talking. Thanks for putting the work into that, looking forward to keeping an up to date winapp2.ini again Link to comment Share on other sites More sharing options...
cbaumer0628 Posted January 13, 2018 Share Posted January 13, 2018 On 1/11/2018 at 15:52, ROCKNROLL said: Tons of updates: https://github.com/MoscaDotTo/Winapp2/commit/0b115d3aa2870b22ed2fc58fadef9516d5d3e8cf https://github.com/MoscaDotTo/Winapp2/commit/bd9e60092aa65ff9fac84a0a651c52690cb915c9 Missed one. https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=291884 Link to comment Share on other sites More sharing options...
cbaumer0628 Posted January 13, 2018 Share Posted January 13, 2018 On 1/8/2018 at 06:54, APMichael said: Sorry, but you overlooked it. We can remove the entry [Explorer MRUs *], because it is in winsys.ini already: [Window Size/Location Cache] ... RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams On 1/8/2018 at 10:38, SMalik said: I’m sorry. I think they should move these into the 'Other Explorer MRUs' entry. Like [Windows ShellBags *], [Window Size/Location Cache] may be an entry users may NOT wish to enable. I know this is true for me. So, keeping [Window Size/Location Cache] as a separate entry from [Other Explorer MRUs] entry, as is the case currently in winsys.ini, would be preferable for these users. Link to comment Share on other sites More sharing options...
APMichael Posted January 14, 2018 Share Posted January 14, 2018 12 hours ago, cbaumer0628 said: Missed one.https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=291884 Thank you for checking! I created a pull request on GitHub. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 14, 2018 Author Share Posted January 14, 2018 This one IS a changelog. Changes made between Version: 180107 and Version: 180111 Installer * has been modified. [Installer *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect=HKCU\Software\Vivaldi Default=False FileKey1=%LocalAppData%\SuperBird\Application\*\Installer|*.7z FileKey2=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey5=%ProgramFiles%\Google\Chrome\Application\*\Installer|*.7z ---------------------------------------------------------------------------------------------------------------------- Web Data * has been modified. [Web Data *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info. FileKey1=%LocalAppData%\Amigo\User Data\*\*|Web Data FileKey2=%LocalAppData%\Chrome Plus\User Data\*|Web Data FileKey3=%LocalAppData%\Chromium\User Data\*|Web Data FileKey4=%LocalAppData%\Flock\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Rockmelt\User Data\*|Web Data FileKey7=%LocalAppData%\SRWare Iron\User Data\*|Web Data FileKey8=%LocalAppData%\SuperBird\User Data\*|Web Data FileKey9=%LocalAppData%\Torch\User Data\*|Web Data FileKey10=%LocalAppData%\Vivaldi\User Data\*|Web Data ---------------------------------------------------------------------------------------------------------------------- Active@ Disk Image * has been modified. [Active@ Disk Image *] LangSecRef=3024 Detect=HKLM\Software\LSoft Technologies\Active Disk Image Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE FileKey3=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey4=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Images * was removed. [Active@ UNDELETE Images *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved disk images. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Recovered Files * was removed. [Active@ UNDELETE Recovered Files *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all recovered data. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Sessions * was removed. [Active@ UNDELETE Sessions *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved sessions. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE ---------------------------------------------------------------------------------------------------------------------- Apple MobileSync Backups * has been modified. [Apple MobileSync Backups *] LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc. Default=False FileKey1=%AppData%\Apple Computer\MobileSync\Backup|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- CCDump * has been modified. [CCDump *] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Default=False Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt ---------------------------------------------------------------------------------------------------------------------- CD/DVD Burn Cache * has been modified. [CD/DVD Burn Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo ---------------------------------------------------------------------------------------------------------------------- DriverPack Solution * has been modified. [DriverPack Solution *] LangSecRef=3024 Detect=HKCU\Software\drpsu Default=False Warning=This will delete your bug report. FileKey1=%AppData%\DRPSu\Logs|*.* FileKey2=%AppData%\DRPSu\snapshots|*.* FileKey3=%AppData%\DRPSu\temp|*.* FileKey4=%Documents%\DRP-Log|*.* FileKey5=%WinDir%\Logs\DRPLog|*.png;*.txt FileKey6=%WinDir%\Logs\SysInfo|*.* ---------------------------------------------------------------------------------------------------------------------- DUC * was removed. [DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%LocalAppData%\Vitalwerks\DUC|DUC.log ---------------------------------------------------------------------------------------------------------------------- ElsterFormular * has been modified. [ElsterFormular *] LangSecRef=3021 DetectFile=%AppData%\elsterformular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log;*.log.* FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zip FileKey4=%CommonAppData%\elsterformular\log|*.log FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey6=%LocalAppData%\elfopatch|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Explorer MRUs * has been modified. [Explorer MRUs *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams ---------------------------------------------------------------------------------------------------------------------- Hauppauge WinTV * has been modified. [Hauppauge WinTV *] LangSecRef=3024 Detect=HKLM\Software\Hauppauge Default=False FileKey1=%Public%\WinTV|Settings-old.xml FileKey2=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb FileKey3=%Public%\WinTV\Installation Log|*.*|RECURSE FileKey4=%Public%\WinTV\Logs|*.log;*.txt FileKey5=%Public%\WinTV\Logs\minidump|*.*|RECURSE FileKey6=%SystemDrive%|hcwDriverInstall.txt ---------------------------------------------------------------------------------------------------------------------- HyperSnap 7 * has been modified. [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List ---------------------------------------------------------------------------------------------------------------------- Internet Explorer * has been modified. [Internet Explorer *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\IECompatUaCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\windows_ie_ac_*\AC\INet*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.* FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.* FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE FileKey14=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE FileKey15=%WinDir%\System32\config\Systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage RegKey2=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey3=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage RegKey4=HKCU\Software\Microsoft\Internet Explorer\Main\FeatureControl RegKey5=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats ---------------------------------------------------------------------------------------------------------------------- IObit Advanced SystemCare * has been modified. [IObit Advanced SystemCare *] LangSecRef=3024 DetectFile1=%AppData%\IObit\Advanced SystemCare V* DetectFile2=%CommonAppData%\IObit\Advanced SystemCare V* Default=False FileKey1=%AppData%\IObit\Advanced SystemCare *|*.log FileKey2=%AppData%\IObit\Advanced SystemCare *\Boottime|*.log FileKey3=%AppData%\IObit\Advanced SystemCare *\EmptyFolder|*.*|RECURSE FileKey4=%AppData%\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey5=%CommonAppData%\IObit\Advanced SystemCare *\Log|*.*|REMOVESELF FileKey6=%CommonAppData%\IObit\ASCDownloader|*.log FileKey7=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey8=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey9=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey10=%LocalAppData%\VirtualStore\ProgramData\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey11=%LocalAppData%\VirtualStore\ProgramData\IObit\ASCDownloader|*.log FileKey12=%ProgramFiles%\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey13=%ProgramFiles%\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey14=%ProgramFiles%\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey15=%SystemDrive%\Users\Default\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey16=%WinDir%\System32\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey17=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log ---------------------------------------------------------------------------------------------------------------------- K-Lite Codec Pack * has been modified. [K-Lite Codec Pack *] LangSecRef=3023 Detect=HKLM\Software\KLCodecPack Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\K-Lite*|*.log;*.txt|RECURSE FileKey2=%ProgramFiles%\K-Lite*|*.log;*.txt|RECURSE FileKey3=%SystemDrive%|*klcp_itp_*.tmp;*klcp_iph_*.tmp FileKey4=%UserProfile%\Desktop|klcp_codec_log.txt RegKey1=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path0 RegKey2=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path1 RegKey3=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path2 ---------------------------------------------------------------------------------------------------------------------- Macrium Reflect * has been modified. [Macrium Reflect *] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium|*.log|RECURSE FileKey2=%CommonAppData%\Macrium\Reflect|*.html;*.vsslog FileKey3=%CommonAppData%\Macrium\waik|waiklog.txt FileKey4=%SystemDrive%|ref~tmp~.txt;Reflect_Install.log;rescuepe.log ---------------------------------------------------------------------------------------------------------------------- MS Search * has been modified. [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey5=%UserProfile%\Searches|*.search-ms FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey9=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery RegKey2=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache ---------------------------------------------------------------------------------------------------------------------- Notepad++ * has been modified. [Notepad++ *] LangSecRef=3021 Detect=HKLM\Software\Notepad++ Default=False FileKey1=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zip FileKey2=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF FileKey3=%ProgramFiles%\Notepad++\plugins\disabled|*.* ---------------------------------------------------------------------------------------------------------------------- OpenDNS Updater * has been modified. [OpenDNS Updater *] LangSecRef=3021 Detect=HKCU\Software\OpenDNS Updater Default=False Warning=You must exit OpenDNS Updater in the System Tray to clear log files. FileKey1=%AppData%\OpenDNS Updater|*.txt ---------------------------------------------------------------------------------------------------------------------- OpenOffice.org Setup Files * has been modified. [OpenOffice.org Setup Files *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%UserProfile%\Desktop\OpenOffice.org * Installation Files|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Pando * has been modified. [Pando *] Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default=False Warning=Make sure Pando is totally shut down before using this. FileKey1=%LocalAppData%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\Pando\Pando Files\|*pando.prev.log;*pando.log;*pando.sav;*pando.save;*pando.txt ExcludeKey2=PATH|%LocalAppData%\Pando\Pando Files\Cert\|*.* ---------------------------------------------------------------------------------------------------------------------- Photos * has been modified. [Photos *] DetectOS=10.0| Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey10=%LocalAppData%\PackagesMicrosoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ---------------------------------------------------------------------------------------------------------------------- QTTabBar * has been modified. [QTTabBar *] LangSecRef=3024 Detect=HKCU\Software\Quizo\QTTabBar Default=False FileKey1=%AppData%\QTTabBar|*.log RegKey1=HKCU\Software\Quizo\QTTabBar|TabsOnLastClosedWindow RegKey2=HKCU\Software\Quizo\QTTabBar\Cache RegKey3=HKCU\Software\Quizo\QTTabBar\RecentlyClosed ---------------------------------------------------------------------------------------------------------------------- Saved Search Folders * was removed. [Saved Search Folders *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8 or newer FileKey1=%UserProfile%\Searches|*.search-ms ---------------------------------------------------------------------------------------------------------------------- Snagit * has been modified. [Snagit *] LangSecRef=3021 Detect=HKCU\Software\TechSmith\Snagit Default=False Warning=This will delete the backups of the captures. FileKey1=%CommonAppData%\TechSmith\Uploader|*.log FileKey2=%Documents%|SnagitDebug.log FileKey3=%LocalAppData%\TechSmith\Logs|*.log FileKey4=%LocalAppData%\TechSmith\Snagit|Tray.bin FileKey5=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE FileKey6=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4 FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico FileKey8=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico FileKey9=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE FileKey10=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount RegKey5=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey6=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount RegKey7=HKCU\Software\TechSmith\Snagit\13|CaptureCount RegKey8=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount RegKey9=HKCU\Software\TechSmith\Snagit\13\Recent Captures RegKey10=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List RegKey11=HKCU\Software\TechSmith\Snagit\18|CaptureCount RegKey12=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount RegKey13=HKCU\Software\TechSmith\Snagit\18\Recent Captures RegKey14=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List RegKey15=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder ---------------------------------------------------------------------------------------------------------------------- SoftEther VPN * has been modified. [SoftEther VPN *] LangSecRef=3024 Detect=HKCU\Software\SoftEther Project\SoftEther VPN Default=False Warning=Exclude installer.cache if you're using SoftEther VPN Client Web Installer. FileKey1=%ProgramFiles%\SoftEther VPN Client|installer.cache FileKey2=%ProgramFiles%\SoftEther VPN Client\backup.vpn_client.config|*.config FileKey3=%ProgramFiles%\SoftEther VPN Client\client_log|*.* FileKey4=%ProgramFiles%\SoftEther VPN Client\vpn_debug|*.* ---------------------------------------------------------------------------------------------------------------------- TortoiseSVN History * has been modified. [TortoiseSVN History *] LangSecRef=3024 Detect=HKCU\Software\TortoiseSVN Default=False Warning=This will remove your repo paths and last checkout location. RegKey1=HKCU\Software\TortoiseSVN\History ---------------------------------------------------------------------------------------------------------------------- UsbFix * has been modified. [UsbFix *] LangSecRef=3023 Detect=HKCU\Software\UsbFix Default=False FileKey1=%SystemDrive%\UsbFix\Log|*.*|REMOVESELF FileKey2=%SystemDrive%\UsbFix\Quarantine|*.*|REMOVESELF FileKey3=%UserProfile%\Desktop|UsbFix_Report.txt RegKey1=HKCU\Software\UsbFix\LastReport ---------------------------------------------------------------------------------------------------------------------- Windows ShellBags * has been modified. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ---------------------------------------------------------------------------------------------------------------------- X-Chat 2 * has been modified. [X-Chat 2 *] LangSecRef=3022 DetectFile=%AppData%\X-Chat 2 Default=False Warning=This removes Chat Scrollback and Logs. FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- No-IP DUC * was added. [No-IP DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%CommonAppData%\Vitalwerks\DUC|*.log FileKey2=%LocalAppData%\Vitalwerks\DUC|*.log ---------------------------------------------------------------------------------------------------------------------- winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 15, 2018 Author Share Posted January 15, 2018 Here is a demo of the new multitool (winapp2ool): https://github.com/MoscaDotTo/Winapp2/tree/master/Tools/beta Please give it a try, it includes a slightly improved WinappDebug, ccinidebug, a new module called "diff" that compares two winapp2.ini versions and outputs the changes, and a trimming module with an option to both overwrite the existing winapp2.ini file or to output to a new file called winapp2-trimmed.ini Recommended that you run it as an administrator, many of the functions don't work will without elevation. Trim especially, as it can't access certain registry keys without elevation and will as a result, erroneously trim entries from your file. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted January 15, 2018 Share Posted January 15, 2018 9 hours ago, Winapp2.ini said: This one IS a changelog. Hide contents Changes made between Version: 180107 and Version: 180111 Installer * has been modified. [Installer *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect=HKCU\Software\Vivaldi Default=False FileKey1=%LocalAppData%\SuperBird\Application\*\Installer|*.7z FileKey2=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey5=%ProgramFiles%\Google\Chrome\Application\*\Installer|*.7z ---------------------------------------------------------------------------------------------------------------------- Web Data * has been modified. [Web Data *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info. FileKey1=%LocalAppData%\Amigo\User Data\*\*|Web Data FileKey2=%LocalAppData%\Chrome Plus\User Data\*|Web Data FileKey3=%LocalAppData%\Chromium\User Data\*|Web Data FileKey4=%LocalAppData%\Flock\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Rockmelt\User Data\*|Web Data FileKey7=%LocalAppData%\SRWare Iron\User Data\*|Web Data FileKey8=%LocalAppData%\SuperBird\User Data\*|Web Data FileKey9=%LocalAppData%\Torch\User Data\*|Web Data FileKey10=%LocalAppData%\Vivaldi\User Data\*|Web Data ---------------------------------------------------------------------------------------------------------------------- Active@ Disk Image * has been modified. [Active@ Disk Image *] LangSecRef=3024 Detect=HKLM\Software\LSoft Technologies\Active Disk Image Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE FileKey3=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey4=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Images * was removed. [Active@ UNDELETE Images *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved disk images. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Recovered Files * was removed. [Active@ UNDELETE Recovered Files *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all recovered data. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Sessions * was removed. [Active@ UNDELETE Sessions *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved sessions. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE ---------------------------------------------------------------------------------------------------------------------- Apple MobileSync Backups * has been modified. [Apple MobileSync Backups *] LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc. Default=False FileKey1=%AppData%\Apple Computer\MobileSync\Backup|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- CCDump * has been modified. [CCDump *] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Default=False Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt ---------------------------------------------------------------------------------------------------------------------- CD/DVD Burn Cache * has been modified. [CD/DVD Burn Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo ---------------------------------------------------------------------------------------------------------------------- DriverPack Solution * has been modified. [DriverPack Solution *] LangSecRef=3024 Detect=HKCU\Software\drpsu Default=False Warning=This will delete your bug report. FileKey1=%AppData%\DRPSu\Logs|*.* FileKey2=%AppData%\DRPSu\snapshots|*.* FileKey3=%AppData%\DRPSu\temp|*.* FileKey4=%Documents%\DRP-Log|*.* FileKey5=%WinDir%\Logs\DRPLog|*.png;*.txt FileKey6=%WinDir%\Logs\SysInfo|*.* ---------------------------------------------------------------------------------------------------------------------- DUC * was removed. [DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%LocalAppData%\Vitalwerks\DUC|DUC.log ---------------------------------------------------------------------------------------------------------------------- ElsterFormular * has been modified. [ElsterFormular *] LangSecRef=3021 DetectFile=%AppData%\elsterformular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log;*.log.* FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zip FileKey4=%CommonAppData%\elsterformular\log|*.log FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey6=%LocalAppData%\elfopatch|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Explorer MRUs * has been modified. [Explorer MRUs *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams ---------------------------------------------------------------------------------------------------------------------- Hauppauge WinTV * has been modified. [Hauppauge WinTV *] LangSecRef=3024 Detect=HKLM\Software\Hauppauge Default=False FileKey1=%Public%\WinTV|Settings-old.xml FileKey2=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb FileKey3=%Public%\WinTV\Installation Log|*.*|RECURSE FileKey4=%Public%\WinTV\Logs|*.log;*.txt FileKey5=%Public%\WinTV\Logs\minidump|*.*|RECURSE FileKey6=%SystemDrive%|hcwDriverInstall.txt ---------------------------------------------------------------------------------------------------------------------- HyperSnap 7 * has been modified. [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List ---------------------------------------------------------------------------------------------------------------------- Internet Explorer * has been modified. [Internet Explorer *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\IECompatUaCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\windows_ie_ac_*\AC\INet*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.* FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.* FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE FileKey14=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE FileKey15=%WinDir%\System32\config\Systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage RegKey2=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey3=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage RegKey4=HKCU\Software\Microsoft\Internet Explorer\Main\FeatureControl RegKey5=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats ---------------------------------------------------------------------------------------------------------------------- IObit Advanced SystemCare * has been modified. [IObit Advanced SystemCare *] LangSecRef=3024 DetectFile1=%AppData%\IObit\Advanced SystemCare V* DetectFile2=%CommonAppData%\IObit\Advanced SystemCare V* Default=False FileKey1=%AppData%\IObit\Advanced SystemCare *|*.log FileKey2=%AppData%\IObit\Advanced SystemCare *\Boottime|*.log FileKey3=%AppData%\IObit\Advanced SystemCare *\EmptyFolder|*.*|RECURSE FileKey4=%AppData%\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey5=%CommonAppData%\IObit\Advanced SystemCare *\Log|*.*|REMOVESELF FileKey6=%CommonAppData%\IObit\ASCDownloader|*.log FileKey7=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey8=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey9=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey10=%LocalAppData%\VirtualStore\ProgramData\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey11=%LocalAppData%\VirtualStore\ProgramData\IObit\ASCDownloader|*.log FileKey12=%ProgramFiles%\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey13=%ProgramFiles%\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey14=%ProgramFiles%\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey15=%SystemDrive%\Users\Default\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey16=%WinDir%\System32\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey17=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log ---------------------------------------------------------------------------------------------------------------------- K-Lite Codec Pack * has been modified. [K-Lite Codec Pack *] LangSecRef=3023 Detect=HKLM\Software\KLCodecPack Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\K-Lite*|*.log;*.txt|RECURSE FileKey2=%ProgramFiles%\K-Lite*|*.log;*.txt|RECURSE FileKey3=%SystemDrive%|*klcp_itp_*.tmp;*klcp_iph_*.tmp FileKey4=%UserProfile%\Desktop|klcp_codec_log.txt RegKey1=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path0 RegKey2=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path1 RegKey3=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path2 ---------------------------------------------------------------------------------------------------------------------- Macrium Reflect * has been modified. [Macrium Reflect *] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium|*.log|RECURSE FileKey2=%CommonAppData%\Macrium\Reflect|*.html;*.vsslog FileKey3=%CommonAppData%\Macrium\waik|waiklog.txt FileKey4=%SystemDrive%|ref~tmp~.txt;Reflect_Install.log;rescuepe.log ---------------------------------------------------------------------------------------------------------------------- MS Search * has been modified. [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey5=%UserProfile%\Searches|*.search-ms FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey9=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery RegKey2=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache ---------------------------------------------------------------------------------------------------------------------- Notepad++ * has been modified. [Notepad++ *] LangSecRef=3021 Detect=HKLM\Software\Notepad++ Default=False FileKey1=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zip FileKey2=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF FileKey3=%ProgramFiles%\Notepad++\plugins\disabled|*.* ---------------------------------------------------------------------------------------------------------------------- OpenDNS Updater * has been modified. [OpenDNS Updater *] LangSecRef=3021 Detect=HKCU\Software\OpenDNS Updater Default=False Warning=You must exit OpenDNS Updater in the System Tray to clear log files. FileKey1=%AppData%\OpenDNS Updater|*.txt ---------------------------------------------------------------------------------------------------------------------- OpenOffice.org Setup Files * has been modified. [OpenOffice.org Setup Files *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%UserProfile%\Desktop\OpenOffice.org * Installation Files|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Pando * has been modified. [Pando *] Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default=False Warning=Make sure Pando is totally shut down before using this. FileKey1=%LocalAppData%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\Pando\Pando Files\|*pando.prev.log;*pando.log;*pando.sav;*pando.save;*pando.txt ExcludeKey2=PATH|%LocalAppData%\Pando\Pando Files\Cert\|*.* ---------------------------------------------------------------------------------------------------------------------- Photos * has been modified. [Photos *] DetectOS=10.0| Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey10=%LocalAppData%\PackagesMicrosoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ---------------------------------------------------------------------------------------------------------------------- QTTabBar * has been modified. [QTTabBar *] LangSecRef=3024 Detect=HKCU\Software\Quizo\QTTabBar Default=False FileKey1=%AppData%\QTTabBar|*.log RegKey1=HKCU\Software\Quizo\QTTabBar|TabsOnLastClosedWindow RegKey2=HKCU\Software\Quizo\QTTabBar\Cache RegKey3=HKCU\Software\Quizo\QTTabBar\RecentlyClosed ---------------------------------------------------------------------------------------------------------------------- Saved Search Folders * was removed. [Saved Search Folders *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8 or newer FileKey1=%UserProfile%\Searches|*.search-ms ---------------------------------------------------------------------------------------------------------------------- Snagit * has been modified. [Snagit *] LangSecRef=3021 Detect=HKCU\Software\TechSmith\Snagit Default=False Warning=This will delete the backups of the captures. FileKey1=%CommonAppData%\TechSmith\Uploader|*.log FileKey2=%Documents%|SnagitDebug.log FileKey3=%LocalAppData%\TechSmith\Logs|*.log FileKey4=%LocalAppData%\TechSmith\Snagit|Tray.bin FileKey5=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE FileKey6=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4 FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico FileKey8=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico FileKey9=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE FileKey10=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount RegKey5=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey6=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount RegKey7=HKCU\Software\TechSmith\Snagit\13|CaptureCount RegKey8=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount RegKey9=HKCU\Software\TechSmith\Snagit\13\Recent Captures RegKey10=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List RegKey11=HKCU\Software\TechSmith\Snagit\18|CaptureCount RegKey12=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount RegKey13=HKCU\Software\TechSmith\Snagit\18\Recent Captures RegKey14=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List RegKey15=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder ---------------------------------------------------------------------------------------------------------------------- SoftEther VPN * has been modified. [SoftEther VPN *] LangSecRef=3024 Detect=HKCU\Software\SoftEther Project\SoftEther VPN Default=False Warning=Exclude installer.cache if you're using SoftEther VPN Client Web Installer. FileKey1=%ProgramFiles%\SoftEther VPN Client|installer.cache FileKey2=%ProgramFiles%\SoftEther VPN Client\backup.vpn_client.config|*.config FileKey3=%ProgramFiles%\SoftEther VPN Client\client_log|*.* FileKey4=%ProgramFiles%\SoftEther VPN Client\vpn_debug|*.* ---------------------------------------------------------------------------------------------------------------------- TortoiseSVN History * has been modified. [TortoiseSVN History *] LangSecRef=3024 Detect=HKCU\Software\TortoiseSVN Default=False Warning=This will remove your repo paths and last checkout location. RegKey1=HKCU\Software\TortoiseSVN\History ---------------------------------------------------------------------------------------------------------------------- UsbFix * has been modified. [UsbFix *] LangSecRef=3023 Detect=HKCU\Software\UsbFix Default=False FileKey1=%SystemDrive%\UsbFix\Log|*.*|REMOVESELF FileKey2=%SystemDrive%\UsbFix\Quarantine|*.*|REMOVESELF FileKey3=%UserProfile%\Desktop|UsbFix_Report.txt RegKey1=HKCU\Software\UsbFix\LastReport ---------------------------------------------------------------------------------------------------------------------- Windows ShellBags * has been modified. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ---------------------------------------------------------------------------------------------------------------------- X-Chat 2 * has been modified. [X-Chat 2 *] LangSecRef=3022 DetectFile=%AppData%\X-Chat 2 Default=False Warning=This removes Chat Scrollback and Logs. FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- No-IP DUC * was added. [No-IP DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%CommonAppData%\Vitalwerks\DUC|*.log FileKey2=%LocalAppData%\Vitalwerks\DUC|*.log ---------------------------------------------------------------------------------------------------------------------- Brilliant. Thanks Link to comment Share on other sites More sharing options...
cbaumer0628 Posted January 15, 2018 Share Posted January 15, 2018 9 hours ago, Winapp2.ini said: This one IS a changelog. Reveal hidden contents Changes made between Version: 180107 and Version: 180111 Installer * has been modified. [Installer *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect=HKCU\Software\Vivaldi Default=False FileKey1=%LocalAppData%\SuperBird\Application\*\Installer|*.7z FileKey2=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey5=%ProgramFiles%\Google\Chrome\Application\*\Installer|*.7z ---------------------------------------------------------------------------------------------------------------------- Web Data * has been modified. [Web Data *] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Chromium Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Torch Detect4=HKCU\Software\Vivaldi Default=False Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info. FileKey1=%LocalAppData%\Amigo\User Data\*\*|Web Data FileKey2=%LocalAppData%\Chrome Plus\User Data\*|Web Data FileKey3=%LocalAppData%\Chromium\User Data\*|Web Data FileKey4=%LocalAppData%\Flock\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Rockmelt\User Data\*|Web Data FileKey7=%LocalAppData%\SRWare Iron\User Data\*|Web Data FileKey8=%LocalAppData%\SuperBird\User Data\*|Web Data FileKey9=%LocalAppData%\Torch\User Data\*|Web Data FileKey10=%LocalAppData%\Vivaldi\User Data\*|Web Data ---------------------------------------------------------------------------------------------------------------------- Active@ Disk Image * has been modified. [Active@ Disk Image *] LangSecRef=3024 Detect=HKLM\Software\LSoft Technologies\Active Disk Image Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE FileKey3=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey4=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Images * was removed. [Active@ UNDELETE Images *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved disk images. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Recovered Files * was removed. [Active@ UNDELETE Recovered Files *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all recovered data. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Active@ UNDELETE Sessions * was removed. [Active@ UNDELETE Sessions *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Default=False Warning=This will delete all saved sessions. FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE FileKey2=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE ---------------------------------------------------------------------------------------------------------------------- Apple MobileSync Backups * has been modified. [Apple MobileSync Backups *] LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc. Default=False FileKey1=%AppData%\Apple Computer\MobileSync\Backup|*.*|RECURSE ---------------------------------------------------------------------------------------------------------------------- CCDump * has been modified. [CCDump *] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Default=False Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt ---------------------------------------------------------------------------------------------------------------------- CD/DVD Burn Cache * has been modified. [CD/DVD Burn Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive. FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\StagingInfo ---------------------------------------------------------------------------------------------------------------------- DriverPack Solution * has been modified. [DriverPack Solution *] LangSecRef=3024 Detect=HKCU\Software\drpsu Default=False Warning=This will delete your bug report. FileKey1=%AppData%\DRPSu\Logs|*.* FileKey2=%AppData%\DRPSu\snapshots|*.* FileKey3=%AppData%\DRPSu\temp|*.* FileKey4=%Documents%\DRP-Log|*.* FileKey5=%WinDir%\Logs\DRPLog|*.png;*.txt FileKey6=%WinDir%\Logs\SysInfo|*.* ---------------------------------------------------------------------------------------------------------------------- DUC * was removed. [DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%LocalAppData%\Vitalwerks\DUC|DUC.log ---------------------------------------------------------------------------------------------------------------------- ElsterFormular * has been modified. [ElsterFormular *] LangSecRef=3021 DetectFile=%AppData%\elsterformular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log;*.log.* FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zip FileKey4=%CommonAppData%\elsterformular\log|*.log FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey6=%LocalAppData%\elfopatch|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Explorer MRUs * has been modified. [Explorer MRUs *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams ---------------------------------------------------------------------------------------------------------------------- Hauppauge WinTV * has been modified. [Hauppauge WinTV *] LangSecRef=3024 Detect=HKLM\Software\Hauppauge Default=False FileKey1=%Public%\WinTV|Settings-old.xml FileKey2=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb FileKey3=%Public%\WinTV\Installation Log|*.*|RECURSE FileKey4=%Public%\WinTV\Logs|*.log;*.txt FileKey5=%Public%\WinTV\Logs\minidump|*.*|RECURSE FileKey6=%SystemDrive%|hcwDriverInstall.txt ---------------------------------------------------------------------------------------------------------------------- HyperSnap 7 * has been modified. [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List ---------------------------------------------------------------------------------------------------------------------- Internet Explorer * has been modified. [Internet Explorer *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\IECompatUaCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\windows_ie_ac_*\AC\INet*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.* FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.* FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE FileKey14=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE FileKey15=%WinDir%\System32\config\Systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage RegKey2=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey3=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage RegKey4=HKCU\Software\Microsoft\Internet Explorer\Main\FeatureControl RegKey5=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats ---------------------------------------------------------------------------------------------------------------------- IObit Advanced SystemCare * has been modified. [IObit Advanced SystemCare *] LangSecRef=3024 DetectFile1=%AppData%\IObit\Advanced SystemCare V* DetectFile2=%CommonAppData%\IObit\Advanced SystemCare V* Default=False FileKey1=%AppData%\IObit\Advanced SystemCare *|*.log FileKey2=%AppData%\IObit\Advanced SystemCare *\Boottime|*.log FileKey3=%AppData%\IObit\Advanced SystemCare *\EmptyFolder|*.*|RECURSE FileKey4=%AppData%\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey5=%CommonAppData%\IObit\Advanced SystemCare *\Log|*.*|REMOVESELF FileKey6=%CommonAppData%\IObit\ASCDownloader|*.log FileKey7=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey8=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey9=%LocalAppData%\VirtualStore\Program Files*\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey10=%LocalAppData%\VirtualStore\ProgramData\IObit\Advanced SystemCare *\Log|*.*|RECURSE FileKey11=%LocalAppData%\VirtualStore\ProgramData\IObit\ASCDownloader|*.log FileKey12=%ProgramFiles%\IObit\Advanced SystemCare *|*.log;*.txt|RECURSE FileKey13=%ProgramFiles%\IObit\Advanced SystemCare *\*.cab_Temp|*.*|REMOVESELF FileKey14=%ProgramFiles%\IObit\Advanced SystemCare *\ASCServiceLog|*.*|RECURSE FileKey15=%SystemDrive%\Users\Default\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey16=%WinDir%\System32\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log FileKey17=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare *|*.log ---------------------------------------------------------------------------------------------------------------------- K-Lite Codec Pack * has been modified. [K-Lite Codec Pack *] LangSecRef=3023 Detect=HKLM\Software\KLCodecPack Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\K-Lite*|*.log;*.txt|RECURSE FileKey2=%ProgramFiles%\K-Lite*|*.log;*.txt|RECURSE FileKey3=%SystemDrive%|*klcp_itp_*.tmp;*klcp_iph_*.tmp FileKey4=%UserProfile%\Desktop|klcp_codec_log.txt RegKey1=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path0 RegKey2=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path1 RegKey3=HKCU\Software\Gabest\vsfilter\DefTextPathes|Path2 ---------------------------------------------------------------------------------------------------------------------- Macrium Reflect * has been modified. [Macrium Reflect *] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium|*.log|RECURSE FileKey2=%CommonAppData%\Macrium\Reflect|*.html;*.vsslog FileKey3=%CommonAppData%\Macrium\waik|waiklog.txt FileKey4=%SystemDrive%|ref~tmp~.txt;Reflect_Install.log;rescuepe.log ---------------------------------------------------------------------------------------------------------------------- MS Search * has been modified. [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey5=%UserProfile%\Searches|*.search-ms FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey9=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery RegKey2=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache ---------------------------------------------------------------------------------------------------------------------- Notepad++ * has been modified. [Notepad++ *] LangSecRef=3021 Detect=HKLM\Software\Notepad++ Default=False FileKey1=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zip FileKey2=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF FileKey3=%ProgramFiles%\Notepad++\plugins\disabled|*.* ---------------------------------------------------------------------------------------------------------------------- OpenDNS Updater * has been modified. [OpenDNS Updater *] LangSecRef=3021 Detect=HKCU\Software\OpenDNS Updater Default=False Warning=You must exit OpenDNS Updater in the System Tray to clear log files. FileKey1=%AppData%\OpenDNS Updater|*.txt ---------------------------------------------------------------------------------------------------------------------- OpenOffice.org Setup Files * has been modified. [OpenOffice.org Setup Files *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%UserProfile%\Desktop\OpenOffice.org * Installation Files|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- Pando * has been modified. [Pando *] Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default=False Warning=Make sure Pando is totally shut down before using this. FileKey1=%LocalAppData%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\Pando\Pando Files\|*pando.prev.log;*pando.log;*pando.sav;*pando.save;*pando.txt ExcludeKey2=PATH|%LocalAppData%\Pando\Pando Files\Cert\|*.* ---------------------------------------------------------------------------------------------------------------------- Photos * has been modified. [Photos *] DetectOS=10.0| Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey10=%LocalAppData%\PackagesMicrosoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ---------------------------------------------------------------------------------------------------------------------- QTTabBar * has been modified. [QTTabBar *] LangSecRef=3024 Detect=HKCU\Software\Quizo\QTTabBar Default=False FileKey1=%AppData%\QTTabBar|*.log RegKey1=HKCU\Software\Quizo\QTTabBar|TabsOnLastClosedWindow RegKey2=HKCU\Software\Quizo\QTTabBar\Cache RegKey3=HKCU\Software\Quizo\QTTabBar\RecentlyClosed ---------------------------------------------------------------------------------------------------------------------- Saved Search Folders * was removed. [Saved Search Folders *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8 or newer FileKey1=%UserProfile%\Searches|*.search-ms ---------------------------------------------------------------------------------------------------------------------- Snagit * has been modified. [Snagit *] LangSecRef=3021 Detect=HKCU\Software\TechSmith\Snagit Default=False Warning=This will delete the backups of the captures. FileKey1=%CommonAppData%\TechSmith\Uploader|*.log FileKey2=%Documents%|SnagitDebug.log FileKey3=%LocalAppData%\TechSmith\Logs|*.log FileKey4=%LocalAppData%\TechSmith\Snagit|Tray.bin FileKey5=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE FileKey6=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4 FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico FileKey8=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico FileKey9=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE FileKey10=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount RegKey5=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey6=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount RegKey7=HKCU\Software\TechSmith\Snagit\13|CaptureCount RegKey8=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount RegKey9=HKCU\Software\TechSmith\Snagit\13\Recent Captures RegKey10=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List RegKey11=HKCU\Software\TechSmith\Snagit\18|CaptureCount RegKey12=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount RegKey13=HKCU\Software\TechSmith\Snagit\18\Recent Captures RegKey14=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List RegKey15=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder ---------------------------------------------------------------------------------------------------------------------- SoftEther VPN * has been modified. [SoftEther VPN *] LangSecRef=3024 Detect=HKCU\Software\SoftEther Project\SoftEther VPN Default=False Warning=Exclude installer.cache if you're using SoftEther VPN Client Web Installer. FileKey1=%ProgramFiles%\SoftEther VPN Client|installer.cache FileKey2=%ProgramFiles%\SoftEther VPN Client\backup.vpn_client.config|*.config FileKey3=%ProgramFiles%\SoftEther VPN Client\client_log|*.* FileKey4=%ProgramFiles%\SoftEther VPN Client\vpn_debug|*.* ---------------------------------------------------------------------------------------------------------------------- TortoiseSVN History * has been modified. [TortoiseSVN History *] LangSecRef=3024 Detect=HKCU\Software\TortoiseSVN Default=False Warning=This will remove your repo paths and last checkout location. RegKey1=HKCU\Software\TortoiseSVN\History ---------------------------------------------------------------------------------------------------------------------- UsbFix * has been modified. [UsbFix *] LangSecRef=3023 Detect=HKCU\Software\UsbFix Default=False FileKey1=%SystemDrive%\UsbFix\Log|*.*|REMOVESELF FileKey2=%SystemDrive%\UsbFix\Quarantine|*.*|REMOVESELF FileKey3=%UserProfile%\Desktop|UsbFix_Report.txt RegKey1=HKCU\Software\UsbFix\LastReport ---------------------------------------------------------------------------------------------------------------------- Windows ShellBags * has been modified. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ---------------------------------------------------------------------------------------------------------------------- X-Chat 2 * has been modified. [X-Chat 2 *] LangSecRef=3022 DetectFile=%AppData%\X-Chat 2 Default=False Warning=This removes Chat Scrollback and Logs. FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF ---------------------------------------------------------------------------------------------------------------------- No-IP DUC * was added. [No-IP DUC *] LangSecRef=3022 Detect=HKCU\Software\Vitalwerks\DUC Default=False FileKey1=%CommonAppData%\Vitalwerks\DUC|*.log FileKey2=%LocalAppData%\Vitalwerks\DUC|*.log ---------------------------------------------------------------------------------------------------------------------- Great job on the changelog. Thanks! One correction though: "Explorer MRUs * has been modified." should be changed to "Explorer MRUs * was removed." See APMichael's pull request, https://github.com/MoscaDotTo/Winapp2/pull/166 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 15, 2018 Author Share Posted January 15, 2018 Just now, cbaumer0628 said: Great job on the changelog. Thanks! One correction though: "Explorer MRUs * has been modified." should be changed to "Explorer MRUs * was removed." See APMichael's pull request, https://github.com/MoscaDotTo/Winapp2/pull/166 The output is generated based on the file contents, so I must have used a version from before that PR was merged to produce it, or else it's absence in the later file would have triggered the "was removed" line. The next time I post a change log, this change will most likely make itself apparent. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted January 15, 2018 Share Posted January 15, 2018 4 hours ago, Winapp2.ini said: Here is a demo of the new multitool (winapp2ool): https://github.com/MoscaDotTo/Winapp2/tree/master/Tools/beta Please give it a try, it includes a slightly improved WinappDebug, ccinidebug, a new module called "diff" that compares two winapp2.ini versions and outputs the changes, and a trimming module with an option to both overwrite the existing winapp2.ini file or to output to a new file called winapp2-trimmed.ini Recommended that you run it as an administrator, many of the functions don't work will without elevation. Trim especially, as it can't access certain registry keys without elevation and will as a result, erroneously trim entries from your file. My system is Windows 10x64 Professional Build 16299.192 V1709. I am running Winapp2ool.exe as "Run as Administrator" ISSUE 1: When I run the DIFF tool, it crashes after I have entered the 2 names of the Winapp2.ini files I want to compare. Below are the two errors via the Event Viewer Quote Application: winapp2ool.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.ArgumentOutOfRangeException at System.ThrowHelper.ThrowArgumentOutOfRangeException(System.ExceptionArgument, System.ExceptionResource) at System.Collections.Generic.List`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].get_Item(Int32) at winapp2ool.diff.main() at winapp2ool.Module1.Main() System - Provider [ Name] .NET Runtime - EventID 1026 [ Qualifiers] 0 Level 2 Task 0 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2018-01-15T06:35:15.961132000Z EventRecordID 61619 Channel Application Computer ASUSHomeBuilt Security - EventData Application: winapp2ool.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.ArgumentOutOfRangeException at System.ThrowHelper.ThrowArgumentOutOfRangeException(System.ExceptionArgument, System.ExceptionResource) at System.Collections.Generic.List`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].get_Item(Int32) at winapp2ool.diff.main() at winapp2ool.Module1.Main() Quote Faulting application name: winapp2ool.exe, version: 1.0.0.0, time stamp: 0x5a5c06fd Faulting module name: KERNELBASE.dll, version: 10.0.16299.15, time stamp: 0x4736733c Exception code: 0xe0434352 Fault offset: 0x0000000000013fb8 Faulting process id: 0xe1c Faulting application start time: 0x01d38dca44861e56 Faulting application path: C:\Program Files\CCleaner\winapp2ool.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: e5237595-e02c-4acb-9d7f-fde2ec73574f Faulting package full name: Faulting package-relative application ID: - System - Provider [ Name] Application Error - EventID 1000 [ Qualifiers] 0 Level 2 Task 100 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2018-01-15T06:30:50.868131000Z EventRecordID 61613 Channel Application Computer ASUSHomeBuilt Security - EventData winapp2ool.exe 1.0.0.0 5a5c06fd KERNELBASE.dll 10.0.16299.15 4736733c e0434352 0000000000013fb8 e1c 01d38dca44861e56 C:\Program Files\CCleaner\winapp2ool.exe C:\WINDOWS\System32\KERNELBASE.dll e5237595-e02c-4acb-9d7f-fde2ec73574f ISSUE 2: Even though I run the tool as "Run as Administrator", it trims 5 more items than the original Trim.bat tool. I can't tell which ones are being trimmed because the DIFF tool is crashing. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 15, 2018 Author Share Posted January 15, 2018 8 minutes ago, siliconman01 said: My system is Windows 10x64 Professional Build 16299.192 V1709. I am running Winapp2ool.exe as "Run as Administrator" ISSUE 1: When I run the DIFF tool, it crashes after I have entered the 2 names of the Winapp2.ini files I want to compare. Below are the two errors via the Event Viewer ISSUE 2: Even though I run the tool as "Run as Administrator", it trims 5 more items than the original Trim.bat tool. I can't tell which ones are being trimmed because the DIFF tool is crashing. You may want to try running the .NET Repair Tool are you including the .ini extension when entering the file name? (you should be!) ' Have you tried running just the trim module? It doesn't call any code from diff so it should not trigger a crash in that module as far as I'm aware. Does the error still occur if you move to tool to a less privileged folder?(ie. downloads) Thanks for trying it out! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted January 15, 2018 Share Posted January 15, 2018 ISSUE 3: Winappdebug failed to detect the missing backslash in the following ExcludeKey ExcludeKey1=FILE|%SystemDrive%\TomsCommonData\Rainmeter\Skins\Gadgets\@Resources\Language|Weather_EN-US.inc Quote You may want to try running the .NET Repair Tool I ran this tool and it did not resolve the crash issue. Quote are you including the .ini extension when entering the file name? (you should be!) ' Yes, I am including the .ini extension Quote Have you tried running just the trim module? It doesn't call any code from diff so it should not trigger a crash in that module as far as I'm aware. Yes, I have run the TRIM module. It is trimming 5 more cleaning items than the original TRIM.BAT. That is why I am wanting to get the DIFF module working. Quote Does the error still occur if you move to tool to a less privileged folder?(ie. downloads) Yes, it still crashes...with and without "Run as Administrator" Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 15, 2018 Author Share Posted January 15, 2018 2 minutes ago, siliconman01 said: ISSUE 3: Winappdebug failed to detect the missing backslash in the following ExcludeKey ExcludeKey1=FILE|%SystemDrive%\TomsCommonData\Rainmeter\Skins\Gadgets\@Resources\Language|Weather_EN-US.inc I ran this tool and it did not resolve the crash issue. Yes, I am including the .ini extension Yes, I have run the TRIM module. It is trimming 5 more cleaning items than the original TRIM.BAT. That is why I am wanting to get the DIFF module working. Yes, it still crashes...with and without "Run as Administrator" I've just uploaded a new version of winapp2ool, give it a try. The trim module has been tweaked a bit to prevent it from outputting a bad ini file. FWIW I think there may be some bug in trim.bat because it also generated more entries for me, but some of them should not have been detected as being on my system. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted January 15, 2018 Share Posted January 15, 2018 (edited) The new winapp2ool.exe no longer crashes when using DIFF. Quote FWIW I think there may be some bug in trim.bat because it also generated more entries for me, but some of them should not have been detected as being on my system. Yes, it does appear to be improperly trimming. In addition it does not alphabetize its final selection. The new version of Trim is still showing 5 less than the original TRIM.BAT. However, the DIFF run shows a lot of adds and removes that do not look correct. TRIM does not seem to like it if the cleaning module has no DETECT or DETECTFILE in the code. It removes these modules Edited January 15, 2018 by siliconman01 Added DETECT/DETECTFILE comment Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2018 Share Posted January 15, 2018 I have fixed this entry https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=292008 "%AppData%\Adobe\LogTransport2\Logs|*.*|RECURSE" belongs to Adobe Elements Organizer. Initially I added this into Adobe Premiere Elements. Link to comment Share on other sites More sharing options...
ROCKNROLL Posted January 15, 2018 Share Posted January 15, 2018 Updates: https://github.com/MoscaDotTo/Winapp2/commit/144435b5cd1d48203f3b641c25ce93664c86f653 https://github.com/MoscaDotTo/Winapp2/commit/b40541bf22928a04062e7b8e87cf459629154271 I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 15, 2018 Author Share Posted January 15, 2018 13 hours ago, siliconman01 said: The new winapp2ool.exe no longer crashes when using DIFF. Yes, it does appear to be improperly trimming. In addition it does not alphabetize its final selection. The new version of Trim is still showing 5 less than the original TRIM.BAT. However, the DIFF run shows a lot of adds and removes that do not look correct. TRIM does not seem to like it if the cleaning module has no DETECT or DETECTFILE in the code. It removes these modules I've uploaded a new version of winapp2ool that should address both the ExcludeKey error checking in WinappDebug and the detectless entries being ignored in the trim module. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 15, 2018 Share Posted January 15, 2018 2 hours ago, ROCKNROLL said: Updates: https://github.com/MoscaDotTo/Winapp2/commit/144435b5cd1d48203f3b641c25ce93664c86f653 https://github.com/MoscaDotTo/Winapp2/commit/b40541bf22928a04062e7b8e87cf459629154271 Any plans to fix entries with unneeded REMOVESELFs? https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=291977 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 16, 2018 Author Share Posted January 16, 2018 I have updated winapp2ool considerably and made available the source code. https://github.com/MoscaDotTo/Winapp2/commit/b69b08c54e70929c2ca8c33ec0a5fdec5f11b8cb Notably, I made a fix to trim such that it will actually respect the hive provided by Detect= entries, it previously ignored any markers such as HKCU, HKLM.. etc and checked all hives simultaneously, which can (strangely enough!) lead to "false" positives (eg. a key exists in HKLM but not HKCU, while the detect is for HKCU. Thus trim would count is as valid but CCleaner would never present this entry, presumably.) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted January 16, 2018 Share Posted January 16, 2018 I installed the new winapp2ool.exe and performed a TRIM. The new TRIM removed 7 cleaning modules that should not have been removed. In examining the ones falsely trimmed (see attached file), the "Detect" checks are all located in the HKLM\Software\WOW6432Node hive area of the registry. So it looks like the new TRIM is not testing this area or is testing it incorrectly. TrimmedIncorrectly.txt Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted January 16, 2018 Share Posted January 16, 2018 ISSUE 1 with ccinidebug: In running the new ccinidebug, it falsely displays that every entry in the ccleaner.ini is a stale entry and will be pruned. If I continue to the second step to let it prune and organize ccleaner.ini, it does not actually prune these entries. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
