SMalik Posted December 28, 2017 Share Posted December 28, 2017 I don't have this, but it is still showing up. It definitely needs a Detect. Revised Entry Added: Detect=HKCU\Software\Local AppWizard-Generated Applications [SetRegistryKey Leftovers *] LangSecRef=3025 Detect=HKCU\Software\Local AppWizard-Generated Applications Default=False RegKey1=HKCU\Software\Local AppWizard-Generated Applications Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2017 Author Share Posted December 29, 2017 Is there no possible way to make this entry non volatile? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
gavsta Posted December 29, 2017 Share Posted December 29, 2017 It's worrying to allow countless modifications via the registry by un-trusted members. Now just after a few posts the bat files, how can i say this....s**t :/ Regardless of not pinpointing said posts, that the admins will allow any member to post such files. It's almost like there is NO level of responsibility. Any member can post whatever code like they are a pro. Come on piriform mods. You should no better, least take a level of professionalism when regarding Registry changes :/ Link to comment Share on other sites More sharing options...
gavsta Posted December 29, 2017 Share Posted December 29, 2017 One of my teachers was a mod from here in the Malware section. That's actually how far back iv watched this forum. 8/9 years ago the malware section was closed here. Bleepingcomputer, geekstogo and so on. Malware & registry changes can only be made by qualified members. :/ Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 Revised Entry Added: %Public%\WinTV\Installation Log|*.*|RECURSE %Public%\WinTV\Logs|*.log;*.txt [Hauppauge WinTV *] LangSecRef=3024 Detect=HKLM\Software\Hauppauge Default=False FileKey1=%SystemDrive%|hcwDriverInstall.txt FileKey2=%Public%\WinTV|Settings-old.xml FileKey3=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb FileKey4=%Public%\WinTV\Installation Log|*.*|RECURSE FileKey5=%Public%\WinTV\Logs\minidump|*.*|RECURSE FileKey6=%Public%\WinTV\Logs|*.log;*.txt Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2017 Author Share Posted December 29, 2017 32 minutes ago, gavsta said: It's worrying to allow countless modifications via the registry by un-trusted members. Now just after a few posts the bat files, how can i say this....s**t :/ Regardless of not pinpointing said posts, that the admins will allow any member to post such files. It's almost like there is NO level of responsibility. Any member can post whatever code like they are a pro. Come on piriform mods. You should no better, least take a level of professionalism when regarding Registry changes :/ 27 minutes ago, gavsta said: One of my teachers was a mod from here in the Malware section. That's actually how far back iv watched this forum. 8/9 years ago the malware section was closed here. Bleepingcomputer, geekstogo and so on. Malware & registry changes can only be made by qualified members. :/ Nothing in this thread is endorsed or supported by Piriform and they claim no liability for any damages resulting from the use of winapp2.ini That being said, all modifications made to the registry through winapp2.ini are exclusively deletions. If you find an entry whose contents damage an application or Windows, you are welcome to point it out. The purpose of this thread and the GitHub review process is to ensure that nothing damaging makes it into the public release. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 2 hours ago, Winapp2.ini said: Is there no possible way to make this entry non volatile? Please ask siliconman01, who provided this entry. I have checked a Windows 7 system and there is no such path there. I have also checked a Windows 10 system and there is no such path there either. Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 Revised Entries Removed: *.pdf extension from the %ProgramFiles%\LSoft Technologies\Active@ KillDisk*| [Active@ KillDisk *] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{0F62EFB8-3C1C-4EE6-B6EF-9593007F9B03}_is1 Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\LSoft Technologies\Active@ KillDisk*|*.log;*.xml FileKey2=%ProgramFiles%\LSoft Technologies\Active@ KillDisk*|*.log;*.xml Removed: %LocalAppData%\VirtualStore\Program Files*\RFA *|*.diz;*.url %ProgramFiles%\RFA *|*.diz;*.url [Registry First Aid *] LangSecRef=3024 Detect1=HKCU\Software\KsL Software\RFA Default=False FileKey1=%UserProfile%|NTUSER.tmp;UsrClass.tmp FileKey2=%LocalAppData%\Microsoft\Windows|NTUSER.tmp;UsrClass.tmp FileKey3=%WinDir%\ServiceProfiles\*Service|*.tmp;*.tmp.LOG1;*.tmp.LOG2 FileKey4=%WinDir%\System32\config|*.tmp;*.tmp.LOG1;*.tmp.LOG2 FileKey5=%WinDir%\System32\config\systemprofile|*.tmp;*.tmp.LOG1;*.tmp.LOG2 FileKey6=%WinDir%\SysWOW64\config\systemprofile|*.tmp;*.tmp.LOG1;*.tmp.LOG2 Removed: *.diz;*.htm;*.GID;*.url extensions from the %ProgramFiles%\RegVac Registry Cleaner|*.xml [RegVac Registry Cleaner *] LangSecRef=3024 DetectFile=%ProgramFiles%\RegVac Registry Cleaner Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\RegVac Registry Cleaner|*.xml FileKey2=%ProgramFiles%\RegVac Registry Cleaner|*.xml Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 Please remove the entry it deletes program related url's only [Privacy Eraser *] LangSecRef=3024 Detect=HKCU\Software\PrivacyEraser Computing, Inc. Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\PrivacyEraser Computing\Privacy Eraser*|*.url FileKey2=%ProgramFiles%\PrivacyEraser Computing\Privacy Eraser*|*.url Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 Please remove "More" from the end of the entries listed below. [Aimersoft Video Converter Ultimate More *] [AOL More *] [Opera More *] [StarCraft II More *] [SUPERAntiSpyware More *] [Twitter Metro More *] [UltraEdit More *] [UltraISO More *] [uTorrent More *] [Vuze More *] [Winamp More *] Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2017 Author Share Posted December 29, 2017 Based on your most recent removals, I assume some changes may need to be made to these entries? [USB Safely Remove *] LangSecRef=3024 Detect=HKCU\Software\SafelyRemove Default=False FileKey1=%AppData%\USBSafelyRemove|*.txt FileKey2=%AppData%\USBSRService|*.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\USB Safely Remove|*.DIZ;*.rtf;*.url FileKey4=%ProgramFiles%\USB Safely Remove|*.DIZ;*.rtf;*.url [Santa's Rampage *] Section=Games DetectFile=%ProgramFiles%\*Santa* Rampage Default=False FileKey1=%ProgramFiles%\*Santa* Rampage|*.diz;*.nfo;*.txt;*.url;dotNetFx40_Full_setup.exe|RECURSE FileKey2=%ProgramFiles%\*Santa* Rampage\Redist|*.*|REMOVESELF FileKey3=%ProgramFiles%\*Santa* Rampage\UDKGame\Logs|*.*|REMOVESELF ExcludeKey1=FILE|%ProgramFiles%\*Santa* Rampage\UDKGame\CookedPC\|Manifest.txt ExcludeKey2=PATH|%ProgramFiles%\*Santa* Rampage\Binaries\Win32\|*.* ExcludeKey3=PATH|%ProgramFiles%\*Santa* Rampage\Binaries\Win64\|*.* ExcludeKey4=PATH|%ProgramFiles%\*Santa* Rampage\UDKGame\Script\|*.* [Christmas Adventure - Candy Storm *] Section=Games Detect1=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Adventure - Candy Storm1.1 Detect2=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Adventure - Candy Stormv1.3 DetectFile=%ProgramFiles%\Christmas Adventure - Candy Storm Default=False FileKey1=%AppData%\Argali|*.log|RECURSE FileKey2=%LocalAppData%\VirtualStore\Program Files*\Christmas Adventure - Candy Storm|*.nfo;*.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\Foxy Games\Christmas Adventure - Candy Storm|*.html;*.msi;*.nfo;*.txt;*.url FileKey4=%ProgramFiles%\Christmas Adventure - Candy Storm|*.nfo;*.txt FileKey5=%ProgramFiles%\Foxy Games\Christmas Adventure - Candy Storm|*.html;*.msi;*.nfo;*.txt;*.url [Christmas Griddlers 2014 *] Section=Games Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Griddlers 20141.1 Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\*\Christmas Griddlers*|*.ico;*.html;*msi;*.nfo;*.txt;*.url|RECURSE FileKey2=%LocalAppData%\VirtualStore\Program Files*\Christmas Griddlers*|*.ico;*.html;*msi;*.nfo;*.txt;*.url|RECURSE FileKey3=%ProgramFiles%\*\Christmas Griddlers*|*.ico;*.html;*msi;*.nfo;*.txt;*.url|RECURSE FileKey4=%ProgramFiles%\Christmas Griddlers*|*.ico;*.html;*msi;*.nfo;*.txt;*.url|RECURSE [Christmas Wonderland *] Section=Games Detect1=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 2 Detect2=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 3 1.0 Detect3=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 4 1.0.4 Detect4=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 21.0 Detect5=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 31.0 Detect6=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Christmas Wonderland 41.1 Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\Christmas Wonderland 3|*.nfo;*.url|RECURSE FileKey2=%LocalAppData%\VirtualStore\Program Files*\Christmas Wonderland 4|*.nfo;*.txt;*.url|RECURSE FileKey3=%LocalAppData%\VirtualStore\Program Files*\Foxy Games\Christmas Wonderland 2|*.url FileKey4=%LocalAppData%\VirtualStore\Program Files*\Foxy Games\Christmas Wonderland 3|*html FileKey5=%LocalAppData%\VirtualStore\Program Files*\Foxy Games\Christmas Wonderland 4|*html;*.nfo;*.txt;*.url|RECURSE FileKey6=%ProgramFiles%\Christmas Wonderland 3|*.nfo;*.url|RECURSE FileKey7=%ProgramFiles%\Christmas Wonderland 4|*.nfo;*.txt;*.url|RECURSE FileKey8=%ProgramFiles%\Foxy Games\Christmas Wonderland 2|*.url FileKey9=%ProgramFiles%\Foxy Games\Christmas Wonderland 3|*html FileKey10=%ProgramFiles%\Foxy Games\Christmas Wonderland 4|*html;*.nfo;*.txt;*.url|RECURSE FileKey11=%SystemDrive%\Games\Christmas Wonderland 3|*.nfo;*.url|RECURSE FileKey12=%SystemDrive%\Games\Christmas Wonderland 4|*.nfo;*.txt;*.url|RECURSE [Gardens Inc. 2 - The Road to Fame *] Section=Games Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{BBB8E5A9-EE43-491D-9A2D-84172C3C9384}_is1 Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\*\Gardens Inc. 2*|*.html;*.nfo;*.txt|RECURSE FileKey2=%ProgramFiles%\*\Gardens Inc. 2*|*.ico;*.html;*msi;*.nfo;*.txt;*.url|RECURSE [HyperSnap 7 *] LangSecRef=3021 Detect=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List| [Microsoft Flight Simulator X *] Section=Games Detect=HKLM\Software\Microsoft\Microsoft Games\Flight Simulator\10.0 Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\Microsoft Games\Microsoft Flight Simulator X|*.log;*.rtf;*.html;*.URL FileKey2=%LocalAppData%\VirtualStore\Program Files*\Microsoft Games\Microsoft Flight Simulator X\Modules|*.log FileKey3=%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X|*.log;*.rtf;*.html;*.URL FileKey4=%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X\Modules|*.log ExcludeKey1=PATH|%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X\|*kiosk.rtf;*readme.rtf;*Readme.htm [My Riding Stables *] Section=Games Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\MyRidingStables Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\My Riding Stables*|*.txt;*.url FileKey2=%ProgramFiles%\My Riding Stables*|*.txt;*.url [Radialix 2 *] LangSecRef=3021 Detect=HKCU\Software\Radialix Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\Radialix 2|*diz;*.txt;*.url FileKey2=%ProgramFiles%\Radialix 2|*diz;*.txt;*.url FileKey3=%ProgramFiles%\Radialix 2\Tools\UPX|COPYING;LICENSE [TVersity *] LangSecRef=3023 Detect=HKLM\Software\TVersity\Media Server Default=False FileKey1=%LocalAppData%\VirtualStore\Program Files*\TVersity Codec Pack|*.exe;*.url FileKey2=%LocalAppData%\VirtualStore\Program Files*\TVersity\Media Server\logs|*.log;*.txt;*.xml;*.zip|RECURSE FileKey3=%ProgramFiles%\TVersity Codec Pack|*.exe;*.url FileKey4=%ProgramFiles%\TVersity\Media Server|*.rtf;*.url;*TVersityCodecPackSetup* FileKey5=%ProgramFiles%\TVersity\Media Server\logs|*.log;*.txt;*.xml;*.zip|RECURSE FileKey6=%WinDir%\System32|tversity.cookies;TVersityMediaServer.log;*.1;*.2;*.3 FileKey7=%WinDir%\System32\config\systemprofile\AppData\Local\Temp\TVersity Media Server|*.*|REMOVESELF FileKey8=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Temp\TVersity Media Server|*.*|REMOVESELF ExcludeKey1=FILE|%ProgramFiles%\TVersity Codec Pack\|uninst.exe ExcludeKey2=PATH|%ProgramFiles%\TVersity\Media Server\|*version.txt;*HOWTO Share Media.txt winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 I can confirm that *.diz, *.GID, *.htm, *.pdf, *.url extensions that I suggested to be removed from [Active@ KillDisk *], [Registry First Aid *] and [RegVac Registry Cleaner *] are part of these programs. Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 We should find a way to eliminate "More" in the [Internet Explorer More *] entry. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2017 Author Share Posted December 29, 2017 37 minutes ago, SMalik said: We should find a way to eliminate "More" in the [Internet Explorer More *] entry. Would a trailing space suffice? Eg [Internet Explorer * ] winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 52 minutes ago, Winapp2.ini said: Would a trailing space suffice? Eg [Internet Explorer * ] This is a very good idea. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 29, 2017 Share Posted December 29, 2017 On 12/27/2017 at 18:23, SMalik said: Revised Entry Added: HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders\Shell This change needs to be reversed. It causes the desktop icons to relocate to their default positions on system reboot. This is highly undesirable if the system user has intentionally relocated icons on the desktop. For example, I have my Recycle Bin located on the lower center of my primary monitor. The new entries in Shellbags causes it to be relocated to the top left corner of the monitor on system reboot. Modified entry: [Windows Shellbags *] [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders\Shell Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 11 hours ago, siliconman01 said: This change needs to be reversed. It causes the desktop icons to relocate to their default positions on system reboot. This is highly undesirable if the system user has intentionally relocated icons on the desktop. For example, I have my Recycle Bin located on the lower center of my primary monitor. The new entries in Shellbags causes it to be relocated to the top left corner of the monitor on system reboot. Modified entry: [Windows Shellbags *] [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders\Shell This is a default behavior. This entry was already there. I just made it compatible with Windows 7 and later. All known privacy cleaner programs remove all of these paths. People who have issues with this entry can use the custom entry listed below or we can just adopt this one. [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey3=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Desktop ExcludeKey4=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders\Shell Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 13 hours ago, Winapp2.ini said: Would a trailing space suffice? Eg [Internet Explorer * ] This is not working. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2017 Author Share Posted December 29, 2017 6 hours ago, SMalik said: This is not working. Inserting a second space before the * seems to work [Internet Explorer *] vs [Internet Explorer *] winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2017 Share Posted December 29, 2017 44 minutes ago, Winapp2.ini said: Inserting a second space before the * seems to work [Internet Explorer *] vs [Internet Explorer *] This is working. Please take a look at the [Windows ShellBags *] entry and see if you need to modify it. I have posted a modified entry above. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 30, 2017 Share Posted December 30, 2017 (edited) 8 hours ago, SMalik said: This is working. Please take a look at the [Windows ShellBags *] entry and see if you need to modify it. I have posted a modified entry above. Your revised Shellbags entry does work fine on my systems. It is much more desirable than setting the desktop icons back to default locations just for the sake of cleaning out a few registry keys. I recommend that the modified version be used as the standard in Winapp2.ini Edited December 30, 2017 by siliconman01 added recommendation Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 30, 2017 Share Posted December 30, 2017 Revised Entry Added: %CommonAppData%\Microsoft\Windows\WER\Temp|*.*|RECURSE [Windows Error Reporting *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\Windows Error Reporting Default=False FileKey1=%CommonAppData%\Microsoft\Windows\WER\Temp|*.*|RECURSE FileKey2=%LocalAppData%\PCHealth\ErrorRep\QSignoff|*.* FileKey3=%WinDir%\pchealth\ERRORREP|*.*|RECURSE FileKey4=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp FileKey5=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp FileKey6=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\CrashDumps|*.dmp FileKey7=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp RegKey1=HKCU\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey2=HKLM\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey3=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports|LastFullLiveReport RegKey4=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports\win32k.sys RegKey5=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LiveKernelReports\win32k.sys RegKey6=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LocalDumps RegKey7=HKU\.DEFAULT\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation Link to comment Share on other sites More sharing options...
siliconman01 Posted December 30, 2017 Share Posted December 30, 2017 Modified entry: [Browser Exit Codes *] Made the detect non-volatile because these registry keys appear to show up randomly and may not be present during a user TRIM. [Browser Exit Codes *] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False RegKey1=HKCU\Software\Chromium\BrowserExitCodes RegKey2=HKCU\Software\Google\Chrome\BrowserExitCodes Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 30, 2017 Author Share Posted December 30, 2017 https://github.com/MoscaDotTo/Winapp2/pull/138/commits/afefce9a07e667447ff6f9364654c84326b09aae winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted December 30, 2017 Share Posted December 30, 2017 2 hours ago, Winapp2.ini said: https://github.com/MoscaDotTo/Winapp2/pull/138/commits/afefce9a07e667447ff6f9364654c84326b09aae This update looks doggone good to me. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
