CCleaner Community Forums
Winapp2.ini additions
3 hours ago, Winapp2.ini said:
did or does this location exist on any version of Windows 7-10? I don't have it on my Windows10 system either.
I have this on windows 10, AppData\LocalLow\Microsoft\CryptnetUrlCache...
BTW why were all the "*" changed to " *", this is going to cause a headache.
Link to post
38 minutes ago, SMalik said:
As for Ashampoo Burning Studio, if there is a newer version of the program is available for free with support for more drives, who will install or keep the previous free version?
Many do. Especially the year named versions as they're usually giveaway versions, not 'always free' versions (even though they technically are, they're not publicised as such to potential users). And newer is not always better. I used an old version of Burning Studio for years, cos the newer version added a load of bloat and functions I didn't need, was about ten times the size, and made a simple job complicated.
It sometimes seems like there's an OCD file size obsession when it comes to winapp2, even at the cost of functionality.
Link to post
8 hours ago, Winapp2.ini said:
Given that it's related to Windows Installer, should we fold this into the [Windows Installer *] entry?
I agree with you, %SystemDrive%\Config.msi|*.*|REMOVESELF  should be merged into [Windows Installer *].
Link to post
On 11/21/2017 at 23:47, SMalik said:
"HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts" not being wiped. Can someone take a look into this?
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
RegKey2=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
Any fix for this?
Link to post
On 12/13/2017 at 22:27, SMalik said:
Please change the Detect. It shows up on a system that does not have any Adobe CS products.
Remove %LocalAppData%\Adobe\AAMUpdater\*|aamul.log;aamun.log. It is already in [Adobe Updater *] and that's where it should be.
[Adobe CS *]
LangSecRef=3021
Detect=HKCU\Software\Adobe
Default=False
FileKey1=%AppData%\Adobe\CS*ServiceManager\Cache|*.*|RECURSE
FileKey2=%AppData%\Adobe\CS*ServiceManager\Logs|*.*|RECURSE
FileKey3=%AppData%\com.adobe.downloadassistant.AdobeDownloadAssistant|*.log|RECURSE
FileKey4=%Documents%\Adobe\Adobe Media Encoder\6.0.0|*.log
FileKey5=%LocalAppData%\Adobe\AAMUpdater\*|aamul.log;aamun.log
FileKey6=%LocalAppData%\Akamai\Cache|*.*
FileKey7=%LocalAppData%\Akamai\Logs|*.*|RECURSE
I see you have changed the Detect, but forgot to remove FileKey5=%LocalAppData%\Adobe\AAMUpdater\*|aamul.log;aamun.log
Link to post
[TeraCopy *]
LangSecRef=3024
Detect=HKCU\Software\Code Sector\TeraCopy
Default=False
FileKey1=%AppData%\TeraCopy|FileList.dat;Transfer.log
FileKey2=%AppData%\TeraCopy\History|*.*
FileKey3=%LocalAppData%\VirtualStore\Program Files*\TeraCopy|FileList.dat;Transfer.log
FileKey4=%ProgramFiles%\TeraCopy|FileList.dat;Transfer.log
RegKey1=HKCU\Software\Code Sector\TeraCopy|LastTargetFolder
- Added FileKey2
Link to post
Partially for better alphabetization in the CCleaner interface, but also because many entries have been merged together or otherwise heavily modified, and lacking an effective way to communicate these sweeping changes to the end user, changing the name (which will toggle the entry back to disabled) seemed like a good way to indicate that a lot of changes have occurred.
If you're worried about the ccleaner.ini bloat, you can trim it using ccinidebug in the top post. If you're worried about resetting your settings, you can find & replace all the "*" to " *" in ccleaner.ini (this will transition over your old settings to new entries, assuming the name hasn't been otherwise changed other than the added space)
Link to post
14 hours ago, SMalik said:
Some Windows 10 app"s names are changed. Zune Music is "Groove Music" now and Zune Video is "Movies & TV".
Have the paths also changed, or just the app names themselves?
Any fix for this?
Key might be in use, have you tried ending explorer.exe before cleaning?
Link to post
Just the app names.
As for the Cached File Extensions, I have tried that.
Link to post
  • Moderators
There's a [Windows Installer Temps*] entry in there, I didn't find the one in the above quote.
Based upon combining them, here's what I've did on my system. Added Detect1 and Filekey1.
LangSecRef=3025
Detect1=HKCU\Software\Microsoft\Installer
Detect2=HKLM\Software\Microsoft\Windows\CurrentVersion\Installer
Default=False
FileKey1=%SystemDrive%\Config.msi|*.*|REMOVESELF
FileKey2=%WinDir%\Installer\MSI*.tmp-|*.*|REMOVESELF
FileKey3=%WinDir%\Installer|*.tmp|RECURSE
FileKey4=%WinDir%\Installer|SourceHash{*};wix{*}.SchedServiceConfig.rmi
Link to post
2 hours ago, Special said:
And why are we removing it? It's an entry I use to clean out...
%AppData%\Microsoft\CryptnetUrlCache  =  C:\Users\{username}\AppData\Roaming\Microsoft\CryptnetUrlCache
not C:\Users\{username}\AppData\LocalLow\Microsoft\CryptnetUrlCache
i hope you can confirm whether you have that folder in Roaming directory, not LocalLow
Link to post
Modified entry:  [Cyberlink Install Files *]
Removed DetectFile1 and DetectFile2
Added  Detect=HKCU\Software\CyberLink
Reason:  If the user trims Winapp2.ini and the users installed Cyberlink program has not been upgraded/updated, [CyberLink Install Files *] was getting trimmed out.  So when a Cyberlink upgrade occurs, the install files would not be cleaned until the user updates Winapp2.ini again and the trim would then leave [CyberLink Install Files *] in.
LangSecRef=3023
Default=False
FileKey1=%CommonAppData%\install_backup|*.*|REMOVESELF
FileKey2=%CommonAppData%\install_clap|*.*|REMOVESELF
FileKey3=%LocalAppData%\VirtualStore\ProgramData\install_backup|*.*|REMOVESELF
FileKey4=%LocalAppData%\VirtualStore\ProgramData\install_clap|*.*|REMOVESELF
Link to post
Revised Entry
Added: %CommonAppData%\Microsoft\Windows Security Health\Logs|*.*|RECURSE
[Windows Logs *]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
Default=False
FileKey1=%CommonAppData%\Microsoft\Network\Downloader|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\Windows Security Health\Logs|*.*|RECURSE
FileKey3=%CommonAppData%\USOShared\Logs|*.*|RECURSE
FileKey4=%LocalAppData%\ConnectedDevicesPlatform|*.log
FileKey5=%LocalAppData%\Diagnostics|*.*|RECURSE
FileKey6=%ProgramFiles%\UNP\Logs|*.*
FileKey7=%SystemDrive%\PerfLogs\System\Diagnostics|*.*|RECURSE
FileKey8=%SystemDrive%\PerfLogs\System\Performance|*.*|RECURSE
FileKey9=%WinDir%\debug\WIA|*.log
FileKey10=%WinDir%\inf|*.log*
FileKey11=%WinDir%\Logs\CBS|*.cab
FileKey12=%WinDir%\Logs\dosvc|*.*|RECURSE
FileKey13=%WinDir%\Logs\NetSetup|*.*|RECURSE
FileKey14=%WinDir%\Logs\SIH|*.*|RECURSE
FileKey15=%WinDir%\Logs\WindowsBackup|*.etl
FileKey16=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log
FileKey17=%WinDir%\Panther\FastCleanup|*.log
FileKey18=%WinDir%\Panther\Rollback|*.txt
FileKey19=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
FileKey20=%WinDir%\repair|setup.log
FileKey21=%WinDir%\System32\catroot2|*.chk;*.log;*.jrs;*.txt
FileKey22=%WinDir%\System32\LogFiles\HTTPERR|*.log
FileKey23=%WinDir%\System32\LogFiles\Scm|*.*|RECURSE
FileKey24=%WinDir%\System32\LogFiles\Srt|*.*|RECURSE
FileKey25=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml;*.log
FileKey26=%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF
FileKey27=%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE
RegKey1=HKLM\Software\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey2=HKLM\Software\Microsoft\Tracing
RegKey3=HKLM\Software\Wow6432Node\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey4=HKLM\Software\Wow6432Node\Microsoft\Tracing
RegKey5=HKLM\SYSTEM\CurrentControlSet\Services\bam\UserSettings
Link to post
1 hour ago, Tr3bg0D said:
How often is the Master file updated?
There is no regular update schedule. The commits I have been linking refer to a branch (Moscadotto-patch-1) that will eventually be merged with the master (and updating the main file with the aggregate of all 25+ commits in the branch), but has not yet been.
https://github.com/MoscaDotTo/Winapp2/pull/138/commits/0ad7e965172522011d7cbf3389d494d6808fc7f2
Link to post
You forgot to change [Internet Explorer More *] to [Internet Explorer *]
I am going to work on this entry because I see some of the stuff is being removed by CCleaner's built-in entry for Internet Explorer. Also, some of the paths/locations in this entry belong to very old versions of Internet Explorer. Should I remove those paths/locations?
Whoever added FileKey6=%LocalAppData%\Microsoft\Windows\*Cache*|*.*|RECURSE in this entry is wrong. First of all it does not belong to Internet Explorer, It is for Window 8/10 Start Menu entries. Removing all files from here can break Start Menu of Windows 8/10.
Link to post
Register a new account
Sign in
