Winapp2.ini additions
Winapp2.ini
New entries:
[steam Dumps*]
Section=Games
Detect=HKCU\Software\Valve\Steam
Default=False
FileKey1=%ProgramFiles%\Steam\dumps|*.*
[samsung Magician Backup*]
LangSecRef=3021
Detect=HKLM\Software\Wow6432Node\Samsung Magician
Default=False
FileKey1=%CommonAppData%\Samsung\Backup|*.*
[samsung Magician Logs*]
LangSecRef=3021
Default=False
FileKey1=%ProgramFiles%\Samsung Magician\Logs|*.*
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
On second thought, do this entry for Starcraft 2 Logs instead.
Modified entries:
[starCraft II Logs*]
Section=Games
Detect1=HKCU\Software\Blizzard Entertainment\StarCraft II
Detect2=HKLM\Software\Wow6432Node\Blizzard Entertainment\StarCraft II
Default=False
FileKey1=%Documents%\StarCraft II\EditorLogs|*.*|RECURSE
FileKey2=%Documents%\StarCraft II\GameLogs|*.*|RECURSE
FileKey3=%Documents%\StarCraft II\UserLogs|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\Starcraft II\Logs|*.*
FileKey5=%ProgramFiles%\Starcraft II\Logs|*.*
Added FileKey1, removed entry %SystemDrive%\Starcraft II\Logs|*.* and removed entry %Public%\games\Starcraft II\Logs|*.*
Link to comment
Modifed entry:
[OpenRA Logs*]
Section=Games
DetectFile=%Documents%\OpenRA
Default=False
FileKey1=%Documents%\OpenRA\Logs|*.*
Renamed and removed replays and warning from this entry.
New entry:
[OpenRA Replays]
Section=Games
Warning=This will remove all of your Replays.
Default=False
FileKey1=%Documents%\OpenRA\Replays|*.*|RECURSE
Moved replays to this entry. It's better to keep these in separate entries, in case people want to keep replays, but don't care about the log files.
New entry:
[starCraft II Misc*]
Section=Games
Detect1=HKCU\Software\Blizzard Entertainment\StarCraft II Editor
Default=False
Warning=This will delete all of your image uploads, replays, and screenshots.
FileKey1=%Documents%\StarCraft II\ImageUploads|*.*|RECURSE
FileKey2=%Documents%\StarCraft II\Replays|*.*|RECURSE
FileKey3=%Documents%\StarCraft II\Screenshots|*.*|RECURSE
Link to comment
New entries:
LangSecRef=3021
Default=False
[samsung Magician Logs*] is already in Winapp2.ini as
[Samsung Magician Logs*]
LangSecRef=3021
Detect1=HKLM\Software\Classes\Applications\Samsung Magician.exe
Detect2=HKLM\Software\Samsung Magician
Detect3=HKLM\Software\Wow6432Node\Samsung Magician
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician|*.log;*.txt|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician\Logs|*.*
FileKey3=%ProgramFiles%\Samsung\Samsung Magician|*.log;*.txt|RECURSE
FileKey4=%ProgramFiles%\Samsung\Samsung Magician\Logs|*.*
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
Not my FileKeys. How about this:
Modified entry:
LangSecRef=3021
Detect1=HKLM\Software\Samsung Magician
Detect2=HKLM\Software\Wow6432Node\Samsung Magician
Default=False
FileKey3=%ProgramFiles%\Samsung Magician\Logs|*.*
FileKey4=%ProgramFiles%\Samsung\Samsung Magician|*.log;*.txt|RECURSE
FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Logs|*.*
Added FileKey 3. Removed one the detects as it is not needed.
By the way, @Siliconman01, did you write this entry? I just ask cause I see you have 2 Samsung SSDs and I am not aware of any logs being located outside the log folder (AKA FileKey4).
Link to comment
Modified entry:
LangSecRef=3021
Default=False
Yes, I think I did submit this entry.  I have Samsung 850 Pro SSDs and also Samsung 950 Pro NVMe M.2 SSDs.  I am running Samsung Magician V4.97.
If you are referring to FileKey4, I make it a point not to enter any entries that are not physically visible in my folders when I write up a submission.  So there must have been a .log and .txt file in folder Samsung Magician at the time I wrote up the entry.  How it got there and why, I really cannot attest to.  :blink:
Your modification certainly looks okay to me.
Link to comment
  • Moderators
Making corrections to [AVG Protection*] since it has FileKey number errors starting after FileKey7.
Corrections:
[AVG Protection*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG\AV
Default=False
FileKey1=%CommonAppData%\Avg\AV\Antispam|*.tmp;*.tmp1;*.tmp2;*.gz
FileKey2=%CommonAppData%\Avg\AV\SetupBackup|*.*|REMOVESELF
FileKey3=%CommonAppData%\Avg\log\AV16|history.xml;*.log;*.log.*;*.log.lock
FileKey4=%CommonAppData%\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey5=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xml
FileKey6=%CommonAppData%\MFAData\logs|*.*
FileKey7=%CommonAppData%\MFAData\pack|*.*
FileKey8=%LocalAppData%\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey9=%LocalAppData%\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey10=%LocalAppData%\AvgSetupLog|*.*|REMOVESELF
FileKey11=%LocalAppData%\MFAData\logs|*.*
FileKey12=%ProgramFiles%\AVG\Av|updatecomps.bak;*.old
FileKey13=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\av16\temp|*.*
FileKey14=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey15=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey16=%WinDir%\System32\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
FileKey17=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\av16\temp|*.*
FileKey18=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey19=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey20=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
Old, with errors (skips from FileKey7 to FileKey9, without any FileKey8):
[AVG Protection*]
LangSecRef=3024
Default=False
FileKey9=%LocalAppData%\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey10=%LocalAppData%\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey11=%LocalAppData%\AvgSetupLog|*.*|REMOVESELF
FileKey12=%LocalAppData%\MFAData\logs|*.*
FileKey13=%ProgramFiles%\AVG\Av|updatecomps.bak;*.old
FileKey14=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\av16\temp|*.*
FileKey15=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey16=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey17=%WinDir%\System32\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
FileKey18=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\av16\temp|*.*
FileKey19=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock
FileKey20=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lock
FileKey21=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
Link to comment
Not my FileKeys
Are you sure that's not a custom location you chose to install to? I have Magician and it's installed to %ProgramFiles%\Samsung\Samsung Magician like the rest of the original entry too
Link to comment
It is the default path for the 64-bit location. If you move it from (x86) to the 64-bit directory for program files, it will, by default, rename it to that instead.
I was referring to the lack of a Samsung folder in your path, perhaps Windows specific path differences (Win7 here).
(although on a side point I wasn't aware there was a specific 64bit version, using 64 bit Windows but Magician installer installs to Program Files (x86) by default here)
Link to comment
new:
[Dreadnought*]
Section=Games
Detect=HKCU\SOFTWARE\Grey Box\Dreadnought
Default=False
FileKey1=%LocalAppData%\DreadGame\Saved\Logs|*.log
Added here: https://github.com/MoscaDotTo/Winapp2/commit/2c68d96d59be9943c17ea9005f56d81f6d51b288
Link to comment
I use CCleaner (the latest version with the latest winapp2.ini) and then another system cleaner.  I'd be interested if someone could look at the files the other utility cleans and come up with entiries to add to Winapp2.ini please.  Anyone willing to help with this endeavor?
Link to comment
P.S.
some are like:
C:\Windows\SoftwareDistribution\Download\
HKCU\Software\Microsoft\Office\11.0\Common\Open Find
C:\Users\Galloway\AppData\Local\Microsoft\Windows\Explorer\*.db
The other thing - be nice if CCleaner could do a BeforeClean= and an AfterClean= and both would run the applications either before or/and after the entry was cleaned.
Link to comment
  • Moderators
Wow, those all (at least two of them) are terrible ideas to clean.
Link to comment
Usually stuff in the Windows\SoftwareDistribution\Download\ directory isn't anything useful in there. I don't know about the other ones you have.
A user suggested on the GitHub page to make another winapp2 with more advanced/aggressive entries, however, I don't know if it will happen
Link to comment
  • Moderators
Removing softwaredistribution can/will break windows update. That's why it has not been re-added to winapp2
Link to comment
  • Moderators
Here is the whole list.....
Why give us a list. You've been here long enough, create entries let them be judged by the thread on their agressive/gentleness
Link to comment
Does it still break WU if you
         net stop wuauserv
before cleaning the folder then
        net start wuauserv
after....
Link to comment
  • Moderators
Does it still break WU if you          net stop wuauservbefore cleaning the folder then         net start wuauserv after....
I have no idea, but it's a moot point when discussing the community template because 99.9(repeating)8 percent of users will not be doing that every (or any) clean. If you want an entry to clean it, in your own ccleaner, feel free, but this is a file that, though they shouldn't, gets used in whole by a lot of people who don't know better.
Link to comment
Updated. New additions over the past 10 days were added here: https://github.com/MoscaDotTo/Winapp2/commit/ce8dc52f37c14d9a0a406b253c103072babd1011
Please let me know if I missed anything or made a mistake somewhere.
Link to comment
Modified Entry
Added for newer version of office and updated Detect to only show when Outlook is install as not all office installs contain Outlook. Updated to actually remove keys as there was typo in previous version
[Outlook Appointment Location MRU*]
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\Office\9.0\Outlook
Detect2=HKCU\Software\Microsoft\Office\11.0\Outlook
Detect3=HKCU\Software\Microsoft\Office\12.0\Outlook
Detect4=HKCU\Software\Microsoft\Office\14.0\Outlook
Detect5=HKCU\Software\Microsoft\Office\15.0\Outlook
Detect6=HKCU\Software\Microsoft\Office\16.0\Outlook
Warning=This Will Remove the Most Frequent Appointment Locations from all Outlook Versions.
Default=False
RegKey1=HKCU\Software\Microsoft\Office\9.0\Outlook\Preferences|LocationMRU
RegKey2=HKCU\Software\Microsoft\Office\11.0\Outlook\Preferences|LocationMRU
RegKey3=HKCU\Software\Microsoft\Office\12.0\Outlook\Preferences|LocationMRU
RegKey4=HKCU\Software\Microsoft\Office\14.0\Outlook\Preferences|LocationMRU
RegKey5=HKCU\Software\Microsoft\Office\15.0\Outlook\Preferences|LocationMRU
RegKey6=HKCU\Software\Microsoft\Office\16.0\Outlook\Preferences|LocationMRU
Updated Entry to add new cleanup lines that were used by older versions
[Auslogics Registry Cleaner 4*]
LangSecRef=3024
Detect1=HKLM\Software\Auslogics\Registry Cleaner\4.x
Detect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x
Default=False
Warning=This will remove your scan results, reports and Registry Change Backups
FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\4.x|*.htm;*.html;*.log|RECURSE
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\4.x|*.htm;*.html;*.log|RECURSE
FileKey3=%ProgramData%\Auslogics\Registry Cleaner\4.x\Rescue\Auslogics Registry Cleaner|*.rsc|RECURSE
FileKey4=%ProgramData%\Auslogics\Registry Cleaner\4.x\Reports|*.*|RECURSE
RegKey1=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey5=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScan
RegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScan
[Auslogics Registry Cleaner 5*]
LangSecRef=3024
Detect1=HKLM\Software\Auslogics\Registry Cleaner\5.X
Detect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X
Default=False
FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.htm;*.html;*.log|RECURSE
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.htm;*.html;*.log|RECURSE
FileKey3=%ProgramData%\Auslogics\Registry Cleaner\5.x\Rescue\Auslogics Registry Cleaner|*.rsc|RECURSE
FileKey4=%ProgramData%\Auslogics\Registry Cleaner\5.x\Reports|*.*|RECURSE
RegKey1=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey5=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScan
RegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScan
New Entry
[Auslogics Registry Cleaner 6*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\6.x
Default=False
FileKey1=%ProgramData%\Auslogics\Registry Cleaner\6.x\Rescue\Auslogics Registry Cleaner|*.rsc|RECURSE
FileKey2=%ProgramData%\Auslogics\Registry Cleaner\6.x\Reports|*.*|RECURSE
RegKey1=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\6.X\Settings|RegistryCleaner.AppLogic.ErrorsFailed
RegKey2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\6.X\Settings|RegistryCleaner.AppLogic.ErrorsFound
RegKey3=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\6.X\Settings|RegistryCleaner.AppLogic.ErrorsRemoved
RegKey4=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\6.X\Settings|RegistryCleaner.AppLogic.ErrorsRemovedTotal
RegKey5=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\6.X\Settings|RegistryCleaner.AppLogic.LastScan
Link to comment
Um, why has the Stardock Fences entry got Steam locations in it???
[Stardock Fences*]
 LangSecRef=3024
 Detect=HKLM\Software\Stardock\Misc\Fences
 Default=False
 FileKey1=%LocalAppData%\VirtualStore\Program Files*\Steam\depotcache|*.*
 FileKey2=%ProgramFiles%\Steam\depotcache|*.*
Link to comment
Register a new account
Sign in
Important Information
