Winapp2.ini additions
Winapp2.ini
  • Moderators
Any updates on this issue? It's a pain to launch CCleaner with 2k entries on the winapp2. VOLDEMORT has a trim function but it doesn't preserve the some of the checked item for Google Chrome.
Hi, we don't really use the name of the greyware you mentioned so I placed our usual name for it into your post. However afaik the TRIM function you speak of is trim.bat. do you have items in your ccleaner checked off from the winapp2 file
Could one of the entries in your winapp file lost one of its brakets "]"? because we have a lot of entries with the word "more" in them and I see that is the command you say MSDos is "barfing on"
Please copy the output of your command prompt which shows the error.
Have you attempted to open a command prompt as admin and open the bat from within the CMD.
Link to comment
Hi, we don't really use the name of the greyware you mentioned so I placed our usual...........
Oh... I'm sorry i'm not really active in the forums I didn't know it's not allowed to be mentioned.
Do you have items in your ccleaner checked off from the winapp2 file
None as far as i can tell (or as far as I understood).
I'm still using the default winapp2 directly from the site (winapp2.com) so I assume it didn't lose those brakets.
Yes. Still the same.
Link to comment
  • Moderators
Hi,  Do you have items in your ccleaner checked off from the winapp2 fileNone as far as i can tell (or as far as I understood)..
Well that would be why you get no results. You need to enable the winapp2 entries you want to keep, afaik, before running trim
Link to comment
Ah i think i misunderstood again. I have the items checked (the ones i want to keep on winapp2). As I've always ran trim every time it gets updated i have always kept it that way.
Anyway... I managed to get a screenshot of the error i'm getting before trim.bat closes. It gives those errors every time i try to run it.
http://imgur.com/a/GgjGo
Link to comment
Try putting quotes around the file, like "Winapp2", as it says for step 2 on the site. If that doesn't work, try putting the trim.bat in the exact same place where Winapp2 is (looks like you have it in a folder called TRIMMER now?).
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
Nope... still the same... nothing suggested here are working lol
Link to comment
  • Moderators
@qwerty77 is there a chance you are opening the bat in a text editor, and resaving it. I re-read the batch file in my browser and noticed every "MORE" in the file was directly preceded by a new line
I may be messing this up by doing this but I deleted the new line in front of each more
Attached is that bat, could you run it (from an open admin prompt) I tell me if it barf's.
@Alan_B had returned for a bit, maybe he can help out. most of these commands in the bat go WAY OVER my figuratively tall tech-head.
Link to comment
I kinda have tried that too (deleting the MORE commands but still cmd just closes right after i input O or S.
Link to comment
1) It might be wise to see if
%windir%\system32\more.com
actually exists
2) also might want to try running a full antivirus scan....
1. Yes. I do see "more" on system32.
2. I'm pretty sure i don't have a virus on my pc. I run a quick scan daily and a full scan periodically.
UPDATE:
I think i solved my own issue. It's has something to do with Environment variables. Somehow my system changed it (or i changed it) to a random path. When i changed it to the default path... I actually got the trim.bat working. Wow... sorry about this issue i made which clearly was my fault lol. Thanks for all who assisted me anyway...
Edited by qwerty77
Link to comment
Modified entry:  [Config.msi]
Removed: DetectFile=%SystemDrive%\Config.msi so that this entry shows up when using a Trim.bat even if a Config.msi is NOT present at the time the Trim.bat is executed.  The reason is that the Config.msi folder could be "stuck" at any time when installing a program after the Trim.bat is utilized.
[Config.msi Folder*]
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Config.msi|*.*|REMOVESELF
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
Revised Entry
[store*]
Section=3031
Default=False
Detect1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\WinStore_cw5n1h2txyewy
Detect2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsStore_8wekyb3d8bbwe
FileKey1=%LocalAppData%\Packages\WinStore_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\WinStore_*\AC\INetCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\WinStore_*\AC\INetCookies|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\WinStore_*\AC\INetHistory|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Windows Store\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Windows Store\Data|history.dat
FileKey11=%LocalAppData%\Packages\WinStore_*\AC\PRICache|*.*|RECURSE
FileKey12=%LocalAppData%\Packages\WinStore_*\AC\Temp|*.*|RECURSE
FileKey13=%LocalAppData%\Packages\WinStore_*\LocalState\Cache|*.*|RECURSE
FileKey14=%LocalAppData%\Packages\WinStore_*\LocalState\LiveTile|*.*|RECURSE
FileKey15=%LocalAppData%\Packages\WinStore_*\LocalState\navigationHistory|*.*|RECURSE
FileKey16=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\AppCache|*.*|RECURSE
FileKey17=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetCache|*.*|RECURSE
FileKey18=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetHistory|*.*|RECURSE
FileKey19=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey20=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey21=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Temp|*.*|RECURSE
FileKey22=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalCache\*|*.*|RECURSE
FileKey23=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalState\Cache|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\WinStore_cw5n1h2txyewy\SearchHistory
Added: %LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\AppCache|*.*|RECURSE
Removed:
Deleting files from these locations signs out of the Windows Store and messages start to pop up in Action Center.
%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetCookies|*.*|RECURSE
%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\TokenBroker\Cache|*.*|RECURSE
%LocalAppData%\Packages\Microsoft.WindowsStore_*\TempState|*.*|RECURSE
Changed: %LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalCache\*|*.*|RECURSE
Link to comment
Revised Entry
[Microsoft Edge More*]
LangSecRef=3022
Detect=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!001\INetCookies|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!001\MicrosoftEdge\Cookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!002\INetCookies|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!002\MicrosoftEdge\Cookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!001\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!002\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\Cookies|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Indexed\Data|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AppData\User\Default\Indexed DB|*.*|RECURSE
Added:
Link to comment
Removed:
Are you sure? I am not seeing this happening on my Windows 10.
Link to comment
Removed:
I have done enough testing before I recommend these changes. Looks like Windows 10 build 1607 is affected.
Link to comment
Revised Entries
To make it compatible with Windows 10 build 1607
[Action Center*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\ActionCenterCache|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Checks
RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Providers\EventLog
RegKey3=HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Security and Maintenance\Checks
RegKey4=HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Security and Maintenance\Providers\EventLog
Added:
Removed:
HKCU\Software\Microsoft\Windows\CurrentVersion\Notifications\Current
This is not part of Action Center.
[Notification Cache*]
DetectOS=6.2|
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Notifications\Current
RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm
Added: HKCU\Software\Microsoft\Windows\CurrentVersion\Notifications\Current
Link to comment
What if we moved them to a separate entry called Store More* and put a warning that it will sign you out of Store and such? Store cache and temp files build up quickly if you use the Store often. I am usually never signed into Store to begin with, so I don't see this happening.
Link to comment
  • Moderators
If you dont use the app the way a normal user would, how can you be sure if the entry is good/bad?
Link to comment
I never said I don't use the store, I only said I a, just usually not signed into it. I use the store often, and you don't have to be signed in to use it, either.
Link to comment
  • Moderators
Re-read what you quote that I said (emphasis added) "IF YOU DON'T USE THE APP THE WAY A NORMAL USER WOULD". The implied statement is that most everybody who uses a computer, stays signed into the store, and, unlike websites, rightfully should NOT expect to lose their store login from using an entry provided here. They expect their search history to be removed or things like that.
Besides which, I thought it was recently decided that more* entries should be reserved for entries that double winapp1.ini entries not doubling winapp2 entries (but maybe I made that up idk spoiler alert: it was literally less than a month ago).
Link to comment
New Entries
[Temporary ASP.NET Files*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\.NETFramework
Default=False
FileKey1=%WinDir%\Microsoft.NET\Framework\*\Temporary ASP.NET Files|*.*|REMOVESELF
FileKey2=%WinDir%\Microsoft.NET\Framework64\*\Temporary ASP.NET Files|*.*|REMOVESELF
This "New" entry looks like a duplicate of existing.  (except for the RECURSE changed to REMOVESELF
[ASP.NET*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Microsoft\ASP.NET
Default=False
FileKey1=%WinDir%\Microsoft.net\Framework\*\Temporary ASP.NET Files|*.*|RECURSE
FileKey2=%WinDir%\Microsoft.net\Framework64\*\Temporary ASP.NET Files|*.*|RECURSE
Link to comment
Would "Store Extras*" be acceptable?
Anyways, what I meant by what I was saying was that, since I am not usually logged in, it isn't a problem for my system. That's why I recommended moving to a different entry and add a warning. I mean this is kind of the samething with removing passwords in FireFox/Chrome/Edge/IE/etc (yes I know you said unlike websites).
Link to comment
Register a new account
Sign in
Important Information
